Klipsch R-620F Floorstanding Speaker
Klipsch R-620F Floorstanding Speaker Empty Klipsch R-620F Floorstanding Speaker
Post by stylelaser.com.my on Sat Nov 03, 2018 3:03 pm
Klipsch R-620F Floorstanding Speaker Brand New. Now Selling At RM3,799. Free Shipping Within West Malaysia.
The Reference R-620F floorstanding speaker is packed with best-in-class audio technology for an incredible listening experience that is built on over 70 years of Klipsch acoustic experience.
          Klipsch R-620F Floorstanding Speaker Es_kli88
Features:
  • 1" Aluminum LTS tweeter
  • 90x90 Square Tractrix Horn
  • Dual 6.5" Spun-Copper IMG Woofers
  • Bass-Reflex via Rear-Firing Tractrix® ports
  • Dimensions: 40" x 9.4" x 15.2"
     Klipsch R-620F Floorstanding Speaker Es_kli90     Klipsch R-620F Floorstanding Speaker Es_kli89
TRACTRIX®️ HORN TECHNOLOGY
Klipsch exclusive 90x90º Tractrix® horn technology ensures that the R-620F high frequency energy is aimed at the listener and reduces artificial reverb or filtering caused by indirect sound bouncing off of walls. Using this proprietary focused technology gives you the best clarity, dynamics, and detail from your movies and music.
LINEAR TRAVEL SUSPENSION TWEETER WITH KAPTON® SUSPENSION
Klipsch exclusive Linear Travel Suspension (LTS) aluminum tweeter minimizes distortion for enhanced, detailed performances. Using Kapton®, an extremely light and rigid material, in the tweeter suspension provides high efficiency and improve resolution and detail. LTS tweeters are a hallmark of Klipsch speakers, making them some of the best speakers in the world.
SPUN COPPER IMG WOOFERS
Injection Molded Graphite (IMG) woofer cones are exceptionally light while being extremely rigid – providing remarkable low frequency response, with minimal cone breakup and distortion. When paired with the Tractrix Horn-Loaded LTS Tweeter, it provides speaker efficiency highest in its class.
REAR TRACTRIX® PORT
The rear Tractrix port is perfectly matched to the cabinet and woofers, creating ideal airflow with minimal distortion or turbulence even at the lowest frequencies.
SLEEK DESIGN
Exposed fasteners, angled feet, low profile magnetic grilles and a scratch-resistant, textured wood grain vinyl give the R-620F floorstanding speaker a polished, modern appearance.
HIGH QUALITY CABINET DESIGN
Reinforced MDF construction reduces cabinet vibration for less audible coloration and improved sonic accuracy - giving you the ultimate listening experience that's built to last.
Peter  012-2536225
Fong   016-3098668
Klipsch R-620F Floorstanding Speaker Trade
SPECIFICATION
FREQUENCY RESPONSE 38Hz - 21kHz +/- 3dB
SENSITIVITY 96 dB @ 2.83V/1M
POWER HANDLING (CONT/PEAK) 100W/400W
NOMINAL IMPEDANCE 8 ohms Compatible
CROSSOVER FREQUENCY 2,000 Hz
HIGH FREQUENCY DRIVER 1” Aluminum LTS tweeter mated to a 90 x 90 square
Tractrix®️ Horn
LOW FREQUENCY DRIVER Dual 6.5” spun-copper IMG woofers
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass-Reflex via rear-firing Tractrix®️ports
INPUTS Single Gold Plated Binding Posts
HEIGHT INCHES (MM) 40” (1017 mm)
WIDTH INCHES (MM) 9.4” (240 mm)
DEPTH INCHES (MM) 15.2” (386 mm)
PRODUCT WEIGHT LBS (KG) 41 lbs (18.6 kg)
FINISHES Black Textured Wood Grain Vinyl
INCLUDED ACCESSORIES Injection molded feet & screws
BUILT FROM 2018
     Klipsch R-620F Floorstanding Speaker Es_kli91     Klipsch R-620F Floorstanding Speaker Es_kli92
Number of posts : 557
