Klipsch SPL-120 12" Powered Subwoofer
Klipsch SPL-120 12" Powered Subwoofer Empty Klipsch SPL-120 12" Powered Subwoofer
Post by stylelaser.com.my on Sat Nov 03, 2018 6:03 pm
Klipsch SPL-120 12" Powered Subwoofer Brand New. Now Selling At RM3,699. Free Shipping Within West Malaysia.
The SPL-120 subwoofer is a step up from the Klipsch Reference series. Featuring a high-efficiency Class-D amplifier and spun copper Cerametallic™ woofer, the Klipsch SPL series subwoofers deliver best-in-class low frequency output.
          Klipsch SPL-120 12" Powered Subwoofer Es_g7127
Features:
  • 12" Spun Copper Cerametallic™ Woofers
  • Bass-Reflex via Exclusive Front-Firing Internal Flare Port
  • Class D Amplifier with 300W RMS / 600W Peak
  • Premium Scratch-Resistant Finish
  • Dimensions: 17.75” x 14.7” x 19.9”
HIGH EFFICIENCY CLASS D AMPLIFIER
The built-in, high efficiency amplifier features an analog preamp design, which maintains the original signal path for cleaner, true-to-source reproduction. The Class D output stage ensures maximum efficiency for maximum output, detail, and low frequency power.
SPUN COPPER CERAMETALLIC WOOFERS
Cerametallic™ woofers are exceptionally light and extremely rigid, providing remarkable low frequency response with minimal cone breakup and distortion for higher, cleaner output using less amplifier power.
WOOFER ANATOMY
Klipsch Cerametallic™ cones are matted to a dual-layer, copper-wound voice coil for exceptional conductivity.
Reference Premiere woofers are housed in a non-resonating, stamped-steel basket that’s secured to a large magnet motor for exceptional efficiency and low distortion, and matched to our horn-loaded tweeters for optimal acoustic execution.
EXCLUSIVE PORT TECHNOLOGY
Klipsch SPL subwoofers leverages proprietary internal-flare geometry that minimizes port noise for clean undistorted low frequencies. The front-firing design allows for placement flexibility to reduce unwanted resonance from your walls or furniture behind the subwoofer.
TAKE CONTROL
Low Pass Crossover and Variable Phase control allows you to tune the subwoofer to your Klipsch speakers and to your room, establishing the ideal level of bass. Line Level / LFE RCA inputs ensure compatibility with home theater receivers.
Both the RCA and wireless inputs can be utilized, giving you the ability to use a single subwoofer with multiple system in the same room. For example, you can use the wireless input for your home theater set up and the RCA input for your 2-channel system, without needing to switch inputs when changing between systems.
ULTRA-DURABLE DESIGN
Klispsch SPL subwoofers feature a scratch resistant ebony finish that looks like real wood and covers the entire cabinet. Shock-absorbing rubber feet, steel grille posts and a woven cloth grille give the SPL subwoofers a premium look and feel.
          Klipsch SPL-120 12" Powered Subwoofer Es_g7131          Klipsch SPL-120 12" Powered Subwoofer Es_g7132
Peter  012-2536225
Fong   016-3098668
Klipsch SPL-120 12" Powered Subwoofer Trade
Klipsch SPL-120 12" Powered Subwoofer Es_g7128
SPECIFICATION
FREQUENCY RESPONSE 24Hz - 125Hz
MAXIMUM ACOUSTIC OUTPUT 118dB
AMPLIFIER TYPE Class D with Analog Preamp Stage
AMPLIFIER POWER 300W RMS / 600W Peak
WOOFER 12” Long-Throw Cerametallic
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass Reflex via Front-Firing Slot Port
INPUTS Dual RCA/LFE Line In, WA-2 Wireless Port
HEIGHT 17-3/4” (451mm)
WIDTH 14-11/16” (374mm)
DEPTH 19-7/8” (506mm)
WEIGHT 45 lbs (20.4kg)
FINISH Ebony Vinyl
BUILT FROM 2018
          Klipsch SPL-120 12" Powered Subwoofer Es_124     Klipsch SPL-120 12" Powered Subwoofer Es_g7130
Number of posts : 557
