Klipsch RP-280F Floorstanding Speaker (Sold Out)
Klipsch RP-280F Floorstanding Speaker (Sold Out) Empty Klipsch RP-280F Floorstanding Speaker (Sold Out)
Post by stylelaser.com.my on Sat Nov 17, 2018 4:02 pm
Klipsch RP-280F Floorstanding Speaker Brand New.  Free Shipping Within West Malaysia.
RP-280F FLOORSTANDING SPEAKER
The Reference Premiere RP-280F floorstanding speaker is the largest in the Reference Premiere family, producing cinematic sound from two 8" Cerametallic™ woofers and a Hybrid Tractrix® Horn. It can fill a larger room with theater-quality sound with minimal effort - immersing you in the ultimate listening experience.
          Klipsch RP-280F Floorstanding Speaker (Sold Out) Es_kli94
SENSITIVITY:
ROOM SIZE:
LOW FREQUENCY:
HIGHEST
LARGEST
DEEPEST
Klipsch RP-280F Floorstanding Speaker (Sold Out) Sensitivity_High
Klipsch RP-280F Floorstanding Speaker (Sold Out) Room-Size_Large
Klipsch RP-280F Floorstanding Speaker (Sold Out) Bass_High
Features:
  • 1" Linear Travel Suspension Titanium Tweeter
  • Dual 8" Spun Copper Cerametallic Cone Woofers
  • 90x90 Hybrid Tractrix Horn
  • All New Tractrix Port
  • MDF Cabinet with Brushed Polymer Veneer Baffle Finish
  • Strong, Flexible Removable Grille
  • Dimensions: 43.125” x 10.5” x 16.375”
Reference Premiere RP-280F 落地式音箱是 Reference Premiere 系列中体积最大的一款,通过 2 个 8" Cerametallic 低音单元和 1 个 混合 Tractrix® 号角产生影院般的音效。它可以轻松地让大型房间充满影院般的音效 - 让您沉浸在终极听觉体验中。
灵敏度:
房间大小:
低频:
最高
最大
最深
特色:
  • 1" 磁悬浮式钛合金高音单元
  • 两个 8 英寸旋制铜铝合金电镀陶瓷振膜锥形低音单元
  • 90x90 混合 Tractrix 号角
  • 全新 Tractrix 导向孔
  • MDF 箱体采用拉丝聚合物饰面隔板饰面
  • 坚韧柔软的可拆式网罩
  • 尺寸:43.125” x 10.5” x 16.375”
ALL-NEW TECHNOLOGY
Klipsch Reference Premiere series speakers are completely redesigned from the ground up with the latest acoustic engineering and design.
  • Linear Travel Suspension Titanium Tweeter
  • Spun Copper Cerametallic Woofers
          Klipsch RP-280F Floorstanding Speaker (Sold Out) Es_kli95     Klipsch RP-280F Floorstanding Speaker (Sold Out) Es_kli96
全新技术
Klipsch Reference Premiere 系列音箱经过完全重新设计,采用了最新的声学工程和设计。
  • 全新 Tractrix 导向孔
  • 磁悬浮式钛合金高音单元
  • 旋制铜铝合金电镀陶瓷振膜低音单元
  • 坚韧柔软的可拆式网罩
NEW HORN + GRILLE
We redesigned the Tractrix® horn from a 60×90 horn to a 90×90 horn for a wider dispersion area. This square horn mouth is paired with a circular horn throat for enhanced soundstaging, while maintaining the dynamic, powerful sound of a Klipsch speaker.
Strong, flexible grilles magnetically detach revealing a clean baffle. Unlike the Reference II series, the magnets have been embedded within the baffle for superior high frequency diffraction reduction.
全新号角 + 网罩
我们重新设计了 Tractrix® 号角,从 60×90 的号角变为 90×90 的号角,实现了更宽广的分散区域。方形号角口与圆形号角喉对接,增强了音场,同时又保持了 Klipsch 音箱动态而震撼的声音。
坚固、柔软的网罩通过磁力吸附,拆下后可看到简洁的隔板。与 Reference II 系列不同,磁铁已经嵌在隔板中了,可大大降低高频衍射。
DESIGNED FOR YOUR HOME
We’ve paired an all-new, premium wood grain polymer veneer with a brushed polymer veneer to add a more modern aesthetic for the Reference Premiere system. The clean, seamless lines of these speakers allow them to be incorporated into any decor.
为您的家庭设计
我们将全新顶级木纹聚合物胶合板与拉丝聚合物胶合板相结合,为 Reference Premiere 系统增添了一份更加现代的美感。这些音箱简洁、无缝的线条可以让它们融入到任何装饰中。
DOLBY ATMOS READY
Your Klipsch Reference Premiere floorstanding speaker is the perfect fit to add one of our Dolby Atmos elevation channel speakers to deliver overhead sound to your home theater.
 支持杜比全景声
您的 Klipsch Reference Premiere 落地式音箱十分适合再增加一台杜比全景声仰角声道音箱,从而为您的家庭影院提供覆盖头顶空间的声音。
Peter  012-2536225
Fong   016-3098668
Klipsch RP-280F Floorstanding Speaker (Sold Out) Trade
SPECIFICATION
FREQUENCY RESPONSE
32-25kHz +/- 3dB
SENSITIVITY
98dB @ 2.83V / 1m
POWER HANDLING (CONT/PEAK)
150/600
NOMINAL IMPEDANCE
8 Ohms Compatible
CROSSOVER FREQUENCY
1750Hz
HIGH FREQUENCY DRIVER
1" Titanium LTS Tweeter with Hybrid Cross-Section Tractrix Horn
LOW FREQUENCY DRIVER
Dual 8" Cerametallic Cone Woofers
ENCLOSURE MATERIAL
MDF
ENCLOSURE TYPE
Bass Reflex via rear-firing Tractrix port
INPUTS
Dual binding posts / bi-wire / bi-amp
HEIGHT
43.06” (109.4 cm)
WIDTH
10.55” (26.8 cm)
DEPTH
18.32” (46.5 cm)
WEIGHT
62.5 lbs (28.35 kg)
FINISH
Ebony
     Klipsch RP-280F Floorstanding Speaker (Sold Out) Es_kli97          Klipsch RP-280F Floorstanding Speaker (Sold Out) Es_kli98
Number of posts : 557
