Naim N-cent centre speaker (used)
Post by Tubeezator on Sun Nov 18, 2018 12:40 pm
cherry wood finish Naim rare Centre speaker for sale was using with Napv 175 flawlessly!  Rolling Eyes  Rolling Eyes
The Naim N-System is an extremely high quality loudspeaker system that's designed to offer exceptional performance and versatility. Home cinema isn't about enormous speakers and flashy systems, it's about bringing the excitement and thrill of the cinema to your living room, and that's just what the Naim N-Systems are designed to do.
The n-CENT centre has been uniquely designed to complement the n-SATs as part of a multi-channel audio or AV system using technology developed for the Naim Ariva range of centre speakers giving an impressive heritage to the system. With matching 130mm bass/mid units and an Ariva style high-frequency driver mounted in a robust cabinet chamber, the n-CENT delivers a level of sound quality few others can match. As with all Naim loudspeakers each driver is fitted into its own separate chamber for optimum performance.
As with all of the n-System speakers the n-CENT is magnetically shielded to it can be placed under your television, LCD or Plasma display alongside you other components with absolutely no interference. And it all comes in a compact yet stylish five litre (available in a variety of finishes) fit smoothly into any room's décor.
If your looking for a simple multi channel solution without compromising the quality of your music and films the a Naim AV system will be just what you looking for. Partner the Naim n-SYSTEM with the AV2 amplifier with a NAP175 and NAIT amplifiers for a system that will be the envy of anyone, even your local cinema complex.
Naim's unique mass damping system is incorporation to control and reduce panel resonance
An asymmetric enclosure helps minimize internal standing waves and creates a contemporary and visually stunning form
Careful design to optimize performance in real world domestic spaces.
Designed as part of the Naim n-SYSTEM
Excellent sound reproduction for both movies and multi-channel music
Two 150mm bass/mid drivers with Pulp cone and a19mm annular radiator HF driver as used in the Ariva speaker
Product Specifications
Frequency Response at 3dB
50Hz - 20kHz
Dimensions (HxWxD) in mm
160x430x300
Maximum Power Handling
120W
Weight
10kg
Sensitivity
87dB/1W/1m
Impedance
6 Ohms (minimum)
Selling @  RM1700
avatar
Tubeezator
Number of posts : 356
Registration date : 2011-06-19
Source(s): MCD Pro 古军碟机
Amplification: SOLID State 经典佳机
Speakers: Harbeth/Linn Sara/Dynaudio
http://www.hifi4sale.net/t32755-no-money-no-tweak-no-talk
Re: Naim N-cent centre speaker (used)
Post by Tubeezator on Sun Dec 09, 2018 12:06 pm
bounce price reasonable and negotiable
bounce
avatar
Tubeezator
