Mark Levinson No. 38S Pre & No. 332 Power
Post by superfi on Fri Nov 23, 2018 5:34 pm
Mark Levinson, together with other High-end brands, needs no introduction in this forum in as much as many here have owned them & on a few occasions, they have reluctantly released them for sale here as well.
On sale here is a proven combination of the Mark Levinson No. 38S Pre-amplifier (which is an upgraded design and much more expensive that it's previous 38 model) and the Dual Mono
No. 332 Power amplifier with 200 watts/channel.
(Pic of actual unit - Mark Levinson No.38S Pre-amplifier)
(Pic of actual unit - Mark Levinson No.332 Power Amp)
No. 38S Pre-Amplifier
Gain: –73.1dB to +18.9dB plus "off."
Inputs: two stereo balanced (XLR), four single-ended (RCA), one Mark Levinson Link communications connector, one 1/8" minijack for external IR repeater.
Outputs: one balanced stereo main output pair (XLR), one single-ended stereo main output pair (RCA), two stereo record outputs (RCA), one Mark Levinson Link communication connector. Input impedance: 100k ohms.
Output impedance: <6 ohms. Input overload: >16V. Maximum output: 16V RMS, balanced. Power consumption: 40W.
Dimensions: 15.75" (400mm) W by 14.3" (363.2mm) D by 3.84" (97.5mm) H.
Weight: 35 lbs (16kg).
Price: US$6495
No. 332 Dual Mono Power Amp:
200 w/ch continuous rms power @ 8Ω
400 w/ch continuous rms power @ 4Ω
800 w/ch continuous rms power @ 2Ω
Frequency response: within 0.1 dB from 20 Hz to 20 kHz
Signal to Noise ratio (main outputs): better than –80 dB (ref. 1 w)
Input impedance: 100kΩ (balanced)  / 50kΩ (single-ended)
Voltage gain: 26.8 dB
Input sensitivity (2.83V output): 130 mV (all models)
Input sensitivity (full output): 2.25V for Nº333
- 1.80V for Nº332
- 1.30V for Nº331
Shipping weight: 150 lbs. (68.2kg)
Power consumption (Nº332): 325W (±5%) at idle, 200W (±5%) in standby
Price: US$6995
Asking for RM28,500 for the combination - separate sale of Pre & Power can be considered
Contact:  Greg 011-39300083 to deal & for private audition
avatar
superfi
Number of posts : 468
Re: Mark Levinson No. 38S Pre & No. 332 Power
Post by superfi on Fri Nov 30, 2018 10:46 pm
For the weekend
avatar
superfi
