Anti Cable Level 3.2 Reference Interconnect - 1m
Post by raymond88 on Fri Nov 30, 2018 9:54 am
Item: Anti Cable Level 3.2 Reference Interconnect -  1m
Condition: 8.5/10. Item in excellent condition.
Price: RM760
Some info:
The ANTICABLES Analog RCA Interconnects use the same design concept as the award winning ANTICABLES Speaker Wires. They use only the materials needed (solid core wire and connectors). Those materials are of very high sonic quality, and unnecessary materials such as thick plastic jacketing are eliminated. They are simple, cost effective, and perform very very well
Testimonials:
http://anticables.com/testimonials/analog-interconnects-testimonials
Level 3.2 "Reference Series" Analog RCA Interconnects: A stereo pair of Anti-Cable Interconnects which will enable line level analog connections between components.
The Level 3.2 interconnect use Anti-Cables new and better sounding Silver/Gold alloy signal wire which replaces the original Level 3's 100% silver wire. Adding a small amount of Gold eliminates the sonic signature of Silver, leaving only the music to be heard. The price has been kept the same, but the performance is greater.
The Level 3.2 also incorporates the newly available and better sounding Keith Louis Eichmann Copper Harmony plugs, which outperform his original Bullet plugs.
Highlights:
  • Keith Louis EIchmann Copper Harmony RCA Plugs
  • Silver/Gold alloy signal conductors
Sound Improvements over Level 2.2 Performance Series:
  • More resolving of textural and tactile information
  • They allow you to hear not just the musical instruments, but also how they are being played
  • Greater resolution also provides a bigger and deeper soundstage
Sound Improvements over former Level 3 versions:
  • The sonic signature of 100% silver wire is now removed
  • The highs no longer sound a bit "hard", "forward", or "bright"
  • Highs remain naturally "soft" and deep in the soundstage where they belong
  • More resolving of musical information makes music more involving
Additional Features:
  • No thick plastic jacketing, which adds dielectric effect distortion and smears the audio signal
  • Double shielded option is available for use with turntables or when extra RFI/EMI protection may be needed.
  • Sound less like a cable and more like real music than cables costing many times more
Upgrade Paths:
  • The Level 4.2 "Reference PLUS" Analog RCA Interconnects, also utilizes the new Silver/Gold alloy conductors which are more resolving of textural and tactual information, "plus" the new Silver Harmony plugs which are more resolving.
  • The Level 5.2 "PURE Reference" Analog RCA Interconnects, also continues to utilizes the excellent new Silver/Gold alloy signal wire, but also adds the worlds best sounding PURE Harmony RCA plugs
Design Concept:
Typical interconnect cables usually have a signal wire surrounded with a thick plastic dielectric material, which is then surrounded by the ground conductor to shield it from EMI/RFI noise, and then more plastic dielectric material. This typical approach has the usual drawbacks of accumulating a lot of dielectric effect distortion, and an accumulation of shunting capacitance. The Anti-Cable Analog RCA Interconnects use a different approach. Since air is a near perfect dielectric, no extra insulation dielectric material (beyond the thin red coating) is used, and the wires are suspended in free air. Eliminating dielectric effect distortion is what allows these interconnects to sound like music, (not a cable).
http://anticables.com/interconnects/analog-rca-interconnects#!/Level-3-2-Reference-Series-RCA-Analog-Interconnects/p/14644593/category=3682626
https://www.divineaudio.co.uk/anti-cables-level-3-2-reference-series-rca-analog-interconnect-1m
Number of posts : 4056
