HDMI Cable
HDMI Cable
Post by thinaka on Mon Apr 19, 2010 1:00 am
I am currently using an AV system which cost around RM10,000. I am into music and home theatre. I am thinking of investing in some rather expensive QED HDMI cables. There is also some contrasting opinion that expensive HDMI cable does not do any good in enhancing the audio and video. Would appreciate some feedback from readers.
Regards.
Thinaka
thinaka
Male Number of posts: 13
Registration date: 2009-08-03
Re: HDMI Cable
Post by arremie on Mon Apr 19, 2010 1:05 am
If you can afford a 10k system then spending another few hundreds on HDMI cables should not be a problem to try out yourself. I'm not gonna go into QED cables better than generic one but I do like all my QED HDMI cables. They are sturdy and well built. Not to mention they come in my favorite color purple
arremie
Male Number of posts: 411
Registration date: 2009-02-09
Source(s): CD or Lossless
Amplification: Tube
Speakers: Loth
Re: HDMI Cable
Post by DigitalTech on Mon Apr 19, 2010 9:34 am
Arremie, you and your purple fetish.
You must also like Barney, the purple dinosaur.
DigitalTech
Male Number of posts: 299
Registration date: 2009-01-19
http://www.Cable4HT.com
Re: HDMI Cable
Post by jemmi on Mon Apr 19, 2010 11:31 am
I read VDH Flat 1.4 HDMI cable is among cheap & excellent HDMI cable but not cheap in Malaysia. I may try compare VDH Flat with my oem Pioneer HDMI cable during KL AV show or at dealer shop. Hopefully no clone VDH Flat in the market. Anybody know the price for 1.5/2m VDH Flat HDMI cable in Malaysia.
jemmi
Male Number of posts: 185
Re: HDMI Cable
Post by zeebee on Mon Apr 19, 2010 3:04 pm
For what it's worth, do get a good reliable or 'branded' (if you so wish) cable. I had one of the earlier 'freebie' cable when buying my lcd but ended the the metal portion of the connector 'koyak/kopak' and lodged itself inside the HDMI socket affraid.
Tried to pry it out but cannot dislodge, nasib baik got other socket that can be used. The socket/connector has been an issue with a number of hi-fi reviewers, read it at least once in Stereophile, as to it's flimsy connection. I only saw a Wireworld HDMI with two side screws ala PC connector. So just be careful with the freebie ones.. Very Happy
Cheers,
zb
zeebee
Male Number of posts: 321
Registration date: 2009-02-05
Re: HDMI Cable
Post by crittertoo on Thu May 13, 2010 3:59 pm
why not just try blue jeans - belden cables. http://www.bluejeanscable.com/store/hdmi-cables/hdmi-cable.htm
crittertoo
Club Member
Club Member
Registration date: 2010-05-03
Re: HDMI Cable
Post by mugenfoo on Sun May 16, 2010 6:24 pm
Beware of those cheap-crap brandless HDMI cables eventhough they might be rated to "HDMI 1.3" specs (or so they claim on the labels). These are usually sold at Low Yat computer shops.
Once used one of these "generics" to hook up between my TV and the BluRay player. It turned out to be really problematic. Picture freezes, garbled displays. etc. etc. Got fed-up, went to hi-way Laser to get a decent Audioquest HDMI cable... problem solved.
Like all things in this world, u get what u pay for. Razz
mugenfoo
Male Number of posts: 2665
Registration date: 2009-04-04
Source(s): Marantz
Amplification: Exposure
Speakers: Harbeth P3ESR
Re: HDMI Cable
Post by soonthas on Sun May 16, 2010 9:19 pm
thinaka wrote:I am currently using an AV system which cost around RM10,000. I am into music and home theatre. I am thinking of investing in some rather expensive QED HDMI cables. There is also some contrasting opinion that expensive HDMI cable does not do any good in enhancing the audio and video. Would appreciate some feedback from readers.
Regards.
Thinaka
You may consider any Chord Company Hdmi cable especially the latest Chord Active Silver Plus hdmi cable ( I'm using now from previous excellent Chord Silver Plus ) which will greatly and definitely impress you by its video and especially audio quality ( better than my previous Chord Silver Plus and QED brands ).
soonthas
Male Number of posts: 107
Registration date: 2009-01-20
Re: HDMI Cable
Post by thinaka on Fri May 21, 2010 4:50 pm
Thank you for all your responses. May god bless you all.
Regards.
Thinaka
thinaka
