Mark Levinson No.38S Pre-amp & No.332 Dual Mono Power Amp
Post by superfi on Sat Dec 29, 2018 4:56 pm
On sale here is a highly sought after combination of the Mark Levinson No. 38S Pre-amplifier (which is an upgraded design and much more expensive that it's previous 38 model) and the Dual Mono
No. 332 Power amplifier with a hefty 200 watts/channel, power enough to drive the most difficult loads. As a combination, the sonics are a sheer delight to listen to: great sound staging with images way behind the confines of the loudspeakers; cavernous depth with tactile placements of singers and instruments; the music reproduced by this high-end set up is extremely refined, gentle despite it's huge reserves of power, unfatiquing and palpable which will lure you to listen to your music for hours on end! These are the hallmarks, among others, of truly high-end hifidelity!
(Mark Levinson No.38S Pre)
(Mark Levinson No.332 Power Amp)
No. 38S Pre-Amplifier
Gain: –73.1dB to +18.9dB plus "off."
Inputs: two stereo balanced (XLR), four single-ended (RCA), one Mark Levinson Link communications connector, one 1/8" minijack for external IR repeater.
Outputs: one balanced stereo main output pair (XLR), one single-ended stereo main output pair (RCA), two stereo record outputs (RCA), one Mark Levinson Link communication connector. Input impedance: 100k ohms.
Weight: 35 lbs (16kg).
No. 332 Dual Mono Power Amp:
200 w/ch continuous rms power @ 8Ω
400 w/ch continuous rms power @ 4Ω
800 w/ch continuous rms power @ 2Ω
Weight: 150 lbs. (68.2kg)
Power consumption: 325W (±5%) at idle, 200W (±5%) in standby
Both items are in excellent condition, well kept and used by the owner and is now available for less than half of their original prices.
Asking for RM30,000 for the combination (nego) - separate sale of Pre & Power can be considered
Contact: Greg at 03-76104466 or 011-39300083 to deal or to set up an appointment for audition
avatar
superfi
Number of posts : 488
