Pioneer Blu-ray Disc Player BDP-51FD (SOLD)
2 posters
PERFORMANCE FEATURES
Spectacular 1080p Picture Quality: The BDP-51FD provides up to 1920 x 1080p resolution for an unrivaled picture quality. And with True24FPS, now see your movies as the director intended.
Single-Wire Connection: One HDMI 1.3a digital connection is all you need from the BDP-51FD to output both HD audio and video signals to your HDMI-capable A/V receiver or HD flat panel. Compared to typical connections, the HDMI interface replaces multiple cords without degradation in signal quality between components. HDMI 1.3a also provides 12-bit deep color support, improving subtle gradations between colors.
HDMI Control: Master your home theater universe. The BDP-51FD supports HDMI Control, which allows you to seamlessly control all your HDMI Control-equipped Pioneer A/V equipment with a single remote.
Wolfson Audio DACs: Each DAC features a signal-to-noise ratio of 117db. Wolfson DACs provide top-notch audio performance from music and movie soundtracks.
Exclusive Jitter Reduction Circuit: Utilizing a Pioneer developed IC, this circuit digitally reshapes the waveform of the audio clock to greatly reduce jitter for all content.
Frequency Control Circuit: By tuning the low-pass filter, waveform distortion of the coaxial digital output is greatly reduced for improved audio performance.
Picture Control Suite: 13 different video adjustments (Progressive Motion, PureCinema, YNR, CNR, BNR, MNR, Detail, White Level, Black Level, Black Setup, Gamma Correction, Hue, and Chroma Level)
3 Different Noise Reduction Circuits: 3D Noise Reduction: ––based on pixel-per-pixel basis to reduce Gaussian Noise without blurring the image.
lock and Mosquito Noise Reduction: to enhance poorly created content.
BonusView Support: Independent High-Definition simultaneous video streams. Watch your Blu-ray disc movies while watching the bonus features at the same time. (Picture-in-Picture)
7.1 Channel Analog Audio Outputs: for compatibility with non-HDMI equipped receivers and preamps.
Internal Audio Decoders: The BDP-51FD features internal decoding of all advanced audio formats including Dolby Digital Plus, Dolby TrueHD, DTS-HD High Resolution, and DTS-HD Master*. The BDP‑51FD also provides bit-stream audio over the HDMI jack of all of the above formats.
Easy Operation and Setup: New Advanced HD GUIs for easy navigation.
Latest Generation PureCinema Deinterlacer: Multi-Format Compatibilty: The BDP-51FD is compatible with BD‑ROM, BD-R, BD-RE, DVD-Video, DVD-R (Video Mode) / RW (Video Mode), and CD media.
TERMINALS
HDMI Output
Component Video Output*Composite Video Output*
S-Video Output*
7.1-Channel Audio Output*
2-Channel Audio Output
Coaxial Digital Output*
Optical Digital Output
SR Input
*Gold Plated
With remote control, box and manual. Still in working condition. Very good 7.1 analog output with 4 units of Wolfson WM8740 DAC, good as a CD player as well (with dedicated 2 channel analog output).
SOLD.
TERMINALS
HDMI Output
S-Video Output*
SR Input
*Gold Plated
SOLD.
Anwar- Frequent Contributor
- Number of posts : 148
Registration date : 2011-01-08
Source(s): AAMS+, Marantz SA-10, Oppo UDP-205, TW Raven Two + TW 10.5 with Benz LP-S + Triplanar VII with Quintet Black, Audio Research REF Phono 2SE
Amplification: Bent Audio silver slagleformer preamp, Bryston 10B-SUB, McIntosh MC452 for front, MC303 for center and rear
Speakers: Focal Diablo Utopia III for LCR, Focal IW 1002 Be for rear, 2 x JL Audio Fathom f113 subs
Re: Pioneer Blu-ray Disc Player BDP-51FD (SOLD)
Cinavia free ke boss
Saharuddin- New Member
- Number of posts : 6
Registration date : 2013-12-13
Original factory firmware (updated to the latest version)
» (Sold) Pioneer Blu-ray Disc Player BDP-51FD
» Pioneer BDP-51FD Blu-ray Player (sold)
» Pioneer BDP-51FD Bluray Player (NOW SOLD)
» Pioneer Bluray player Bdp 51fd (sold)
» pioneer BDP-51FD Bluray player( Sold)
