Cayin MT-45 MKII Vacum Amplifier (Used)SOLD
Features:
- Pure vacuum tube integrated amplifier
- Handmade soldering, no PCB.
- It uses two high-quality broadband sound output transformer EI
- It uses the toroidal power transformer, which was developed specifically.
- Voltage amplification and Voltage pushing use one 12AX7 vacuum tube and one 12AU7 vacuum tube
- It uses four KT88 vacuum tubes to be the Class AB push-pull power amplifier
- It provides triode and ultra- linear selection function.
- Triode working mode suits for soft music.
- Superlinear working mode suits for the passionate music.
- It is set power tube current adjustment knob and BIAS meter,which could be monitored power tubes working state easily
- It is set headphone output jack
- It chooses the thick layer of silver-plated signal leads.
- It's detachable tube shield is very convenient to install.
Specification:
Rated output power: 18W + 18W (RMS Triode)
35W + 35W (RMS Ultra-Linear)
Frequency Response: 8Hz ~ 50kHz (-3 dB)
Total Harmonic Distortion: 1% (1kHz)
SNR: 90 dB
Input Sensitivity: 300 mV
Input impedance: 100kΩ
Output Impedance: 4Ω, 8Ω
Use vacuum tube: 12AX7 × 1,12AU7 × 2, KT88 × 4
Input terminals: 3 groups of RCA
Volume: 295mm × 395mm × 185mm (W × D × H)
Weight: 16.5kg
Gross Weight: 19kg
Maximum Consumption Power: 230W
Power supply: AC 230V / 50Hz (± 10%)
Conditions: 8/10 (USED)
Last edited by choyaudiovisual on Sat Jun 29, 2019 12:32 am; edited 1 time in total
- Number of posts : 5622
» Cayin MT-35 MKII Vacuum Tube Integrated Amplifier (PL)
» Cayin A88-T Mk1 Integrated Tube amplifier (SOLD)
» BLADELIUS THOR MKII AMPLIFIER + BLADIUS FREJA MKII CD PLAYER(SOLD)
» Audiolab 8000c mkII preamplifier & 8000p mkII power amplifier (Used)SOLD
» Cayin A88-T MK2 Amplifier (SOLD)
