Bada LB5500 Power Conditioner (Used) SOLD
Bada LB5500 Power Conditioner (used)
① Use design of two-ways, each way has an independent power switch and filter network, when working, one way can be used for preamp and source, another way is for the power amp, not interference.
② Access of current filter and the sectional area of the coil is as big as possible, use high-quality high-purity copper wire to reduce the transmission loss and improve the speed of energy supply.
③ Use high-quality low lose WIMA-MKP10 capacitive to filter, filter pulse interference.
④Use professional-grade power outlet, thick copper sheet, good flexibility, close contact, effectively reduce the current reflection and loss of the contacts, this is also an important guarantee for good sound quality.
⑤ Use detachable power cord can upgrade in accordance with your own personality.
⑥ With Lightning and over-current protection devices, safety use.
Specifications: Rated voltage: ~ 220V/50Hz
Maximum power: 3000W
Maximum current: 15A
Conditions: 7/10 (USED)
Last edited by choyaudiovisual on Sat Jun 13, 2020 9:40 am; edited 7 times in total
- Number of posts : 5622
» SOLD - BADA LB 3300 Power Conditioner (Used)
» Bada LB-5500 power conditioner (Used) SOLD
» BADA LB-3300 Power Conditioner (SOLD)
» (Sold) - Bada LB3300 power filter/conditioner
