Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer
Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer Empty Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer
Post by stylelaser.com.my on Thu Jan 10, 2019 12:56 pm
Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer Brand New. Now Selling At RM999. Free Shipping Within West Malaysia.
         Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer Es_pio37
Pioneer SBX-301
Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer Adda_1
Upgrade audio from your home TV simply with the 2.1-channel speaker bar speaker system from the prestigious Pioneer brand. Wireless subwoofers can easily be positioned in the most appropriate position for a deep deep bass range without the hassle of wiring. Enjoy surround sound effects with a slim-designed speaker bar that easily connects to your TV with just one signal wire. Built-in Bluetooth:registered: wireless technology allows you to stream music from mobile devices like smartphones, tablets. USB connector for direct lossless music play is a worthwhile function along with a series of common connections and 3 modes for selecting specific sound qualities optimized for Music - Movies or News.
Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer SBX-301
Powerful surround sound with simple installation
The SBX-301 system consists of a loudspeaker and a wireless subwoofer. This is the sound system that is ideal for performing small to medium sized rooms with the simplest setup. Instead of the monotonous sound from built-in TV speakers, the SBX-301 system will give the surround sound quality while the wireless subwoofer reproduces the powerful deep bass range.
Connect the TV with an HDMI cable via Audio Return Channel (ARC)
HDMI input enhances the ability to connect to home entertainment devices, not only easily connecting to HDMI (ARC) ports, but also very convenient for advanced sources such as Bu-ray players. .
Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer Htjt
The slim speaker bar fits neatly under the TV screen
With a height of only 60 mm, the loudspeaker unit can be placed under the TV screen without obscuring the infrared image or eye from the TV's remote controller. USB / Line joystick and connector Print layout on the side of the speaker bar for easy manual control and make the speaker front design keep an elegant look that matches the room interior.
Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer PIONEER_SBX-301
Wireless subwoofers simply install in any position
Equipping a subwoofer in the home entertainment system is the best way to get a powerful low frequency band in movie effects. The SBX-301 system with a removable wireless subwoofer lets you wear whatever layout of the listening room without having to worry about connecting cables.
Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer SBX-301_2
Dolby Audio :tm: technology for multi-channel surround sound effects
Dolby Audio :tm: technology was designed by Dolby Lab to reproduce digital audio quality in home movie files that are almost identical to real theater sound. Dolby Audio :tm: technology also allows 5.1 channel multi-channel surround signals to be blended and converted to fit the configuration of the SBX-301 speaker system.
Music streaming with Bluetooth:registered: wireless technology
You can stream high resolution digital music from mobile devices such as smartphones or tablets to the SBX-301 speaker system and enjoy high-quality audio.
The hidden LED light shows all the status of the system
Behind the loudspeaker protection bar is the LED display unit so users can easily know the current working status of the system and display the response signal from the remote control hand.
Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer SBX-301_3
Peter  012-2536225
Fong   016-3098668
Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer Trade
     Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer Es_242
SPECIFICATION
- Total power: 145W - 6 ohms
- Audio format: Dolby Audio :tm:
- Wireless technology: Bluetooth:registered: / Wireless
- Broadcast format: MP3 (.mp3), WMA (.wma), AAC (.m4a), WAV (.wav), FLAC (.flac), Monkey's Audio (.ape)
- Input port: USB / Line / Optical / AUX / HDMI
- Voltage: AC 100 ~ 240 V, 50/60 Hz
- Size:
   Bar: 960 (R) x 55 (C) x 80 (S) mm
   Wireless subwoofer: 210 (R) x 340 (C) x 250 (S) mm
- Total weight: 5.5 kg
     Pioneer SBX-301 Soundbar Bluetooth Soundbar With Wireless Subwoofer Es_436
Number of posts : 611
