TEAC UD-505 USB DAC & Headphone Amplifier
TEAC UD-505 USB DAC & Headphone Amplifier Empty TEAC UD-505 USB DAC & Headphone Amplifier
Post by stylelaser.com.my on Fri Jan 11, 2019 12:13 pm
TEAC UD-505 USB DAC & Headphone Amplifier Brand New. Now Selling At RM6,299. Free Shipping Within West Malaysia.
USB DAC/Headphone Amplifier
     TEAC UD-505 USB DAC & Headphone Amplifier Es_15210
USB DAC/耳机放大器
UD-505
Dual monaural USB DAC/headphone amplifier supporting DSD512 and PCM32/768
The UD-505 is a flagship dual monaural USB DAC with an integrated fully-balanced headphone amplifier, that fuses high-end audio design concepts and TEAC’s decades of audio design experience, in an A4-sized footprint.
双单声道USB DAC/耳机放大器, 支持DSD512和PCM32/768
UD-505是一款旗舰双单声道USB DAC,可容纳全平衡耳机放大器,它将高端的音频设计理念及TEAC几十年的音频设计经验压缩到一个A4尺寸的机箱中。
TEAC UD-505 USB DAC & Headphone Amplifier Ud-505-b_main
TEAC UD-505 USB DAC & Headphone Amplifier Logo_w_bulkpet TEAC UD-505 USB DAC & Headphone Amplifier Logo_w_ldac TEAC UD-505 USB DAC & Headphone Amplifier Logo_w_bluetooth  TEAC UD-505 USB DAC & Headphone Amplifier Logo_w_dsd TEAC UD-505 USB DAC & Headphone Amplifier Logo_w_hi-res TEAC UD-505 USB DAC & Headphone Amplifier Logo_w_pentaconn
TEAC UD-505 USB DAC & Headphone Amplifier Logo_w_aptx TEAC UD-505 USB DAC & Headphone Amplifier Logo_w_aptx_hd
Like its predecessor models, the UD-501 and UD-503, it employs a dual monaural circuit design to process audio signals with even greater purity, with the latest VERITA AK4497 DAC chip used on each of the two channels. This improves the S/N (signal to noise) ratio by processing each channel individually in monaural mode, as well as delivering DSD512 (22.5MHz) native and 768kHz/32-bit PCM playback capabilities.
The Analog section, which is one of the keys to sound quality, includes four TEAC-HCLD buffer amp circuits process different drive modes, - fully-balanced drive for balanced output, and parallel drive mode for unbalance output, - to achieve enhanced acoustic expressive.
The headphone section is remarkable. A totally new 4.4mm headphone jack, called Pentaconn, is employed, allowing balanced and active ground connections within a single jack, while conventional 1/4" phone jacks are also provided.
In addition to a wide range of digital and Analog inputs, a Bluetooth:registered: receiver supporting LDAC:tm: and Qualcomm:registered: aptX HD:tm: allows you to enjoy high-quality wireless audio streaming from your smartphone on this flagship USB DAC.
The UD-505 is a compact and high-spec USB DAC and headphone amplifier that supports today’s high sampling rate Hi-Res formats.
如其前作UD-501和UD-503,它采用了双单声道线路设计来处理更纯净的音频信号,左右声道各配置有最新的DAC芯片VERITA AK4497,并通过各单声道方式处理达到更好的S/N比,同时实现了 DSD512 (22.5MHz) 和768kHz/32位PCM的原生播放。
模拟部分是音质的关键,包括4个TEAC-HCLD缓冲放大器电路处理不同的驱动模式——用于平衡输出的全平衡驱动和用于非平衡输出的并行驱动模式,以实现优异的音乐表现。
耳机部分尤其显著。采用全新的4.4毫米的Pentaconn 耳机插孔,可以通过这个插孔,实现平衡和有源接地的连接,同时也采用了传统的1/4"耳机插孔。此外,除了各种各样的数字和模拟输入外,还具备蓝牙:tm: 接收功能,支持LDAC:tm:和Qualcomm:registered: aptX HD:tm:,允许您透过智能手机在这台旗舰USB DAC上享受高音质的无线音频流。
UD-505是一款紧凑型的高规格的USB DAC和耳机放大器,支持当下高采样率高分辨率的格式。
     TEAC UD-505 USB DAC & Headphone Amplifier Es_15211     TEAC UD-505 USB DAC & Headphone Amplifier Es_15212
Peter  012-2536225
Fong   016-3098668
TEAC UD-505 USB DAC & Headphone Amplifier Trade
     TEAC UD-505 USB DAC & Headphone Amplifier Es_15214     TEAC UD-505 USB DAC & Headphone Amplifier Es_15213
Spec description
Supported formats
USB input
PCM    16/24/32 bit
44.1k/48k/88.2k/96k/176.4k/192k/352.8k/384k/705.6k/768k Hz
DSD    2.8M/5.6M/11.2M/22.5M Hz
Coaxial digital input
PCM    16/24 bit
32k/44.1k/48k/88.2k/96k/176.4k/192k Hz
DSD    2.8MHz(supported with 176.4kHz/24-bit DoP format)
Optical digital input
PCM    16/24 bit
DAC section
USB DAC    Asahi Kasei Microdevices AK4497×2
Up-conversion    up to 384kHz/32-bit PCM, 22.5MHz DSD
Digital filters
PCM filters    Sharp Roll Off, Slow Roll Off, Short Delay Sharp, Short Delay Slow, Low Dispersion, off
DSD cutoff frequencies    Narrow : 39kHz (at 2.8M), 78kHz (at 5.6M), 156kHz (at 11.2M) or 312kHz (at 22.5M)
Wide : 76kHz (at 2.8M), 152kHz (at 5.6M), 304kHz (at 11.2M) or 608kHz (at 22.5M)
Audio inputs
USB    USB B port, USB 2.0, asynchronous mode transfer, bulk transfer
Compatible Software    TEAC HR Audio Player (Windows, Macintosh)
COAXIAL digital (rear)    RCA pin×1 (gold-plated)
Input level    0.5Vp-p
Input impedance    75Ω
Optical digital (rear)    TOS-link×1
Input level    -24.0 to -14.5dBm peak
Coaxial digital (front)    1/8” (3.5mm) mini*×1 (combined with optical digital input, detected automatically)
Input level    0.5Vp-p
Input impedance    75Ω
* 1/8” Mini - RCA conversion cable included.
Optical digital (front)    1/8” Mini Optical*×1 (combined with coaxial digital input, detected automatically)
Analog (rear)    RCA pin×1 pair (gold-plated)
Input impedance    24kΩ
Input sensitivity    130mV
Bluetooth®
Bluetooth® version    4.0
Output class    Class2 (Range: approx. 33ft/10m)
Supported profiles    A2DP, AVRCP
Content protection    SCMS-T
Supported codec    LDAC™, Qualcomm® aptX™ HD, aptX™, AAC, SBC
No. of paired device    maximum 8 devices
Audio outputs
XLR balanced    XLR×1 pair (gold-plated)
Output level    Fixed (0dB), fixed (+6dB), variable, output off (selectable)
Maximum output leve    2.0Vrms (1kHz, full scale, into 10kΩ, when set to fixed (0dB))
4.0Vrms (1kHz, full scale, into 10kΩ, when set to fixed (+6dB))
12.0Vrms (1kHz, full scale, into 10kΩ, when set to variable)
Output impedance    188Ω
RCA unbalanced    RCA pin×1 pair (gold-plated)
6.0Vrms (1kHz, full scale, into 10kΩ, when set to variable)
Output impedance    150Ω
Headphone outputs
Connector 1    1/4” (6.3mm) TRS stereo jacks×2 (gold-plated)
Polarity (balanced)    Tip: HOT, Ring: COLD, Sleeve: NC (GND)
Polarity (unbalanced)    Tip: L, Ring: R, Sleeve: GND
Connector 2    4.4mm 5-pole Pentaconn×1 (gold-plated)
Polarity (balanced)    Tip: L+, Ring1: L-, Ring2: R+, Ring3: R-, Sleeve: GND
Maximum output
Balanced    700mW + 700mW (into 32Ω)
Unbalanced    500mW + 500mW (into 32Ω×1)
350mW + 350mW(into 32Ω×2)
Active ground    500mW + 500mW (into 32Ω)
Supported impedances    16 to 600Ω
Clock section
Internal clock
Type    Crystal oscillator
Number of clocks    2 (44.1kHz and 48kHz)
External clock input
Connector    BNC (gold-plated)
Input frequency    10MHz
Input impedance    50Ω
Input level    Rectangle wave: equivalent to TTL levels
Sine wave: 0.5 to 1.0 Vrms
Audio performance
Frequency Response    10 to 80,000 Hz (+1/-3 dB, 192kHz PCM input, RCA output, digital filter off)
Total harmonic distortion    0.002% or less (192kHz PCM input, RCA output, digital filter off)
S/N ratio    110dB or higher (192kHz PCM input, RCA output, digital filter off)
Power supply
US/Canada    AC 120V 60Hz
UK/Europe    AC 220 to 240V 50Hz
Power consumption    18W (0.4W in standby)
dimensions (including protrusions)    290(W)×84.5(H)×248.7(D) mm / 11.4”(W)×3.3”(H)×9.8”(D)
Weight    4.2kg / 9.3lbs
Number of posts : 592
