Musical Fidelity X-DAC Digital-to-Analog Converter
Post by superfi on Fri Jan 11, 2019 4:06 pm
Greetings to all, up for sale here is a Musical Fidelity X-DAC Digital-to-Analog converter.
First up, some general description:
The X-DAC uses an 18 bit Burr-Brown "Co-phase" DAC which combines bitstream conversion for the lowest bits and R-2R multibit for the higher bits, subjectively this gives both the low level detail resolution and smoothness of bitstream with the solid bass response and timing of multibit. The special HDCD compatible digital filter used incorporates 8 times oversampling (which allows a simple and phase-coherent analog filter), digital domain de-emphasis and automatic decoding of HDCD encoded disks.
Though marked as an entry level offering, there are plenty of rave reviews clamoring the performance of this little device. Some even call it mandatory!
Drop by for an audition to hear it for yourself!
Price: RM 1450 (nego)
Condition: 8.5/10
Technical Specifications:
THD < 0.02% 20Hz-20kHz Unweighted
< 0.008% 20Hz-20kHz "A" weighted
Frequency response : + 0.2dB 20Hz-20kHz
S/N ratio better than -90dB Unweighted
better than -100dB "A" weighted
Conversion type : 18 bit Co-phase 8x oversampled
Power requirement : 12V AC 500mA (via mains
adaptor supplied)
Dimensions (mm) : 110 x 110 x 220 (W x H x D)
If you are looking for a great CD-player, check out our Rega Planet for sale thread! <- Click to view
Visit us at Amcorp Mall for an audition, at Lot 2-23 (2nd floor) - or call (Greg/George) for inquiries. Whatsapp - 011-39300083 / 012-2955266
superfi
superfi
Number of posts : 500
Re: Musical Fidelity X-DAC Digital-to-Analog Converter
Post by superfi on Sun Jan 20, 2019 3:07 pm
bump.
superfi
superfi
