Musical Fidelity AMS CD Player with Multi Input DAC
Musical Fidelity AMS CD Player with Multi Input DAC Empty Musical Fidelity AMS CD Player with Multi Input DAC
Post by raymond88 on Fri Jan 11, 2019 4:20 am
Item: [size=10][size=13]Musical Fidelity AMS CD Player with Multi Input DAC.
Condition: 8.9/10. Item is in mint condition. Comes with original remote, manual and original double boxes. Selling because give up hifi.
Price: sold
[/size][/size]
AMSCD | CD PLAYER
The AMSCD is a CD Player and multi-input DAC of exceptional quality.
Musical Fidelity AMS CD Player with Multi Input DAC Musica13
Musical Fidelity AMS CD Player with Multi Input DAC Musica14
Quite simply, the AMS CD is the finest digital product we’ve ever made. It combines reference-standard CD playback with a multi-input DAC; it’s the true hi-fi heart of a modern music system.
The AMS CD uses the best possible CD transport mechanism, which is further optimised by being paired with our upsampling DAC design and a unique power-supply suite.
As well as being applied to CD playback, all the sonic benefits of the 24bit/192kHz DAC are available to other digital devices via optical and coaxial and balanced inputs.
From spinning disc to streamed music, digital data is faithfully retrieved and converted, with the absolute minimum of jitter, noise and distortion. The outstanding results are fed on to the amplification of your choice via a pure Class A output stage.
All this plus the premium build quality and fabulous finish found across the entire AMS range. The AMS CD is a reference source you’ll be proud to own and love to listen to.
PERFORMANCE
  • Jitter: <15 picoseconds peak to peak
  • Frequency Response: 10Hz to 20 kHz -0.2dB max.
  • Signal to Noise Ratio: >117dB
  • THD(+ noise): <0.003% 10Hz to 20 kHz
  • Linearity: <0.1dB down to -96dB
  • Channel Separation: 105dB 20 Hz to 20 kHz
HARDWARE
  • DAC: Quad DAC 192 kHz fully balanced over-sampling
INPUTS
  • 1x RCA coaxial connector (SPDIF)
  • 1x TOSLINK optical connector(SPDIF)
  • 1x XLR AES input connector
OUTPUTS
  • 1x line level RCA
  • 1x line level Balanced XLR
  • 1x RCA coaxial connector (Digital SPDIF)
GENERAL
  • Dimensions - WxHxD (mm): 483 x 150 x 385
  • Weight (unpacked / packed): 11.2 kg / 23 kg
https://www.musicalfidelity.com/support/discontinued-products/ams-series/amscd
http://www.audiotuning.com/images/MusicalFidelity/MF-AMSCD-Pi-080809.pdf
Actual item pictures:
Musical Fidelity AMS CD Player with Multi Input DAC Cd310
Musical Fidelity AMS CD Player with Multi Input DAC Cd110
Musical Fidelity AMS CD Player with Multi Input DAC Cd710
Musical Fidelity AMS CD Player with Multi Input DAC Cd410
Number of posts : 4787
Registration date : 2009-05-03
Musical Fidelity AMS CD Player with Multi Input DAC Empty Re: Musical Fidelity AMS CD Player with Multi Input DAC
Post by raymond88 on Thu Jan 17, 2019 7:49 pm
Post by raymond88 on Thu Jan 24, 2019 6:52 pm
Post by raymond88 on Sat Feb 02, 2019 12:47 am
Post by raymond88 on Sun Feb 10, 2019 4:09 am
Post by raymond88 on Sun Feb 17, 2019 11:33 pm
Post by raymond88 on Wed Feb 27, 2019 6:18 am
Post by raymond88 on Tue Mar 12, 2019 4:54 pm
