Klipsch RP-8060FA Dolby Atmos Floorstanding Speaker
Klipsch RP-8060FA Dolby Atmos Floorstanding Speaker Empty Klipsch RP-8060FA Dolby Atmos Floorstanding Speaker
Post by stylelaser.com.my on Sat Jan 12, 2019 11:38 am
Klipsch RP-8060FA Dolby Atmos Floorstanding Speaker Brand New. Now Selling At RM10,999. Free Shipping Within West Malaysia.
RP-8060FA DOLBY ATMOS FLOORSTANDING SPEAKER
The Reference Premiere RP-8060FA Dolby Atmos® enabled floorstanding speaker includes a built-in elevation channel speaker integrated into the top of the speaker to reflect sound off the ceiling to deliver the overhead Dolby Atmos® experience in addition to stereo sound towards the listener.
 Klipsch RP-8060FA Dolby Atmos Floorstanding Speaker Es_621     Klipsch RP-8060FA Dolby Atmos Floorstanding Speaker Es_1110
Features:
  • Built-in Elevation Channel for Dolby Atmos®
  • 1” Titanium LTS Vented Tweeter with Hybrid Tractrix® Horn
  • Main Channel: 8" Spun Copper Cerametallic™ Woofers
  • Height Channel: 6.5" Spun Copper Cerametallic™ Woofer
  • Bass-Reflex via Rear-Firing Tractrix® port
  • Dual binding posts for bi-wire/bi-amp
  • Dimensions: 43.12” x 10.90” x 19.80”
DOLBY ATMOS
To put it simply, Dolby Atmos® is the greatest advancement in home and cinema audio since surround sound. The addition of elevation speakers reflects sound from the ceiling to put sound anywhere in your room - making you feel like you’re truly in the middle of the action.
HYBRID TRACTRIX® HORN TECHNOLOGY
Klipsch proprietary Tractrix® horn loading technology ensures high-frequency energy of the RP-8060FA is aimed directly at the listener and reduces unwanted, artificial reverb - meaning you experience the most clear, detailed, lifelike sound possible.
HORN ANATOMY
Klipsch Reference Premiere series speakers feature a compressed molded silicon face thats matted to the 90x90 Tractrix horn to reduces horn resonance for a smoother frequency response. Klipsch computer modeled phase plugs acts as a mechanical filter to further ensure a smooth, flat frequency response while protecting the tweeter from damage.
ALL-NEW VENTED TWEETER
A vented tweeter design reduces standing waves behind the tweeter diaphragm for a smoother high frequency reproduction.
The titanium tweeter diaphragm's light weight yet rigid composition exceeds the performance of aluminum, polymer or silk tweeters.
Klipsch award-winning Linear Travel Suspension technology leverages a piston motion of the titanium diaphragm that lowers distortion and delivers real-to-life sound.
A ceramic magnet housing provides premium performance, Klipsch Reference Premiere tweeters set the standard in acoustic reproduction.
CERAMETALLIC™ WOOFERS
Klipsch Proprietary Cerametallic™ woofers are the RP-8060FA signature statement for both sound and aesthetics. This extremely light, rigid materials holds its shape while being able to deliver lower frequencies with maximum efficiency.
WOOFER ANATOMY
Klipsch Cerametallic™ cones are matted to a dual-layer, copper-wound voice coil for exceptional conductivity.
Reference Premiere woofers are housed in a non-resonating, stamped-steel basket that’s secured to a large magnet motor for exceptional efficiency and low distortion, and matched to our horn-loaded tweeters for optimal acoustic execution.
TRACTRIX® PORT + DUAL TERMINALS
The rear Tractrix port is perfectly matched to the cabinet and woofers, creating ideal airflow with minimal distortion or turbulence even at the lowest frequencies.
The RP-8060FA floorstanding speaker features dual input terminals so you can bi-wire or bi-amp your speakers for a custom, high-performance experience.
FINISHED TO PERFECTION
The RP-8060FA ebony and walnut finishes boast satin painted baffles with a scratch resistant finish. The cast aluminum feet provides a modern look with less resonance than MDF or ABS plastic. It is mechanically designed to minimize surface area in contact with the floor, decoupling the speaker for faster, tighter low frequencies and more detail.
     Klipsch RP-8060FA Dolby Atmos Floorstanding Speaker Es_1010     Klipsch RP-8060FA Dolby Atmos Floorstanding Speaker Es_911
Peter  012-2536225
Fong   016-3098668
Klipsch RP-8060FA Dolby Atmos Floorstanding Speaker Trade
     Klipsch RP-8060FA Dolby Atmos Floorstanding Speaker Es_1310     Klipsch RP-8060FA Dolby Atmos Floorstanding Speaker Es_811
SPECIFICATIONS - MAIN CHANNEL
FREQUENCY RESPONSE 32-25kHz +/- 3dB
SENSITIVITY 98dB @ 2.83V / 1m
POWER HANDLING (CONT/PEAK) 150W / 600W
NOMINAL IMPEDANCE 8 Ohms Compatible
CROSSOVER FREQUENCY 1750Hz
HIGH FREQUENCY DRIVER 1” Titanium LTS Vented Tweeter with Hybrid Cross-Section
Tractrix®️ Horn
LOW FREQUENCY DRIVER Dual 8” Cerametallic Cone Woofers
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass Reflex via rear-firing Tractrix®️ Port
INPUTS Dual Binding Posts
HEIGHT 43.12” (109.5 cm)
WIDTH 10.90” (27.7 cm)
DEPTH 19.80” (50.3 cm)
WEIGHT 71 lb (32.2 kg)
FINISH Ebony, Walnut, Piano Black
BUILT FROM 2018
SPECIFICATIONS - HEIGHT CHANNEL
FREQUENCY RESPONSE Conforms to Dolby Atmos Specifications
SENSITIVITY Conforms to Dolby Atmos Specifications
POWER HANDLING (CONT/PEAK) 75W / 300W
CROSSOVER FREQUENCY 2kHz
HIGH FREQUENCY DRIVER 1” Titanium LTS Tweeter with Hybrid Tractrix Horn
LOW FREQUENCY DRIVER 6.5” Cerametallic Cone Woofer
ENCLOSURE TYPE Acoustic Suspension
INPUTS Single Binding Posts
Number of posts : 592
