TEAC UD-301 D/A Converter with USB Streaming
TEAC UD-301 D/A Converter with USB Streaming Brand New. Now Selling At RM2,199. Free Shipping Within West Malaysia.
Capable of 5.6MHz DSD native playback
The USB input facility allows DSD native playback which converts 5.6MHz DSD files directly into analog signals without needing first to convert it to PCM. It supports both the ASIO2.1 and DoP (DSD over PCM) conversion methods. Using the AI-301DA in conjunction with the TEAC HR Audio Player* high-resolution playback computer software application, anyone can easily explore the world of high-rez digital audio, including 5.6MHz DSD or 32bit/192 kHz PCM files, without having to grapple with complex settings etc.
USB輸入能以DSD低失真播放,可將5.6MHz DSD檔案直接轉換成類比訊號,不須先轉換成PCM檔案。亦支援ASIO2.1與DoP (DSD over PCM)轉換方式,同時使用UD-301與TEAC HR Audio Player*高解析電腦播放應用程式,任何人都能夠輕鬆地探索高解析數位音頻的世界,包含5.6MHz DSD或32bit/192 kHz PCM檔案,且不需要費力的進行複雜的設定。
Asynchronous mode-capable USB input
When receiving digital audio signals from a computer via USB cable, the unit can operate in asynchronous mode, controlling the timing of the input signal using the UD-301's internal clock (which is identical to the one used in the UD-501). With asynchronous transmission over USB, signal compromising jitter is effectively eliminated, allowing digital audio signals to be transmitted in a pure, unadulterated state.
非同步USB輸入
透過USB線,從電腦接收數位音頻訊號時,機器能夠以非同步模式操作,使用UD-301的內部時鐘(與UD-501當中所使用的時鐘相同)控制輸入訊號的時序,透過USB非同步傳輸,能有效的刪除訊號傳輸的相位移動,能以乾淨、純粹的方式傳遞數位音頻訊號。
Up to 192kHz up-conversion option.
When handling digital signals of 96kHz and less, users have the option to upconvert to double or quadruple the original signal sampling frequency. Even when playing back a 44.1kHz sound source (equivalent to CD sound quality) a smoother analog audio signal can be obtained in order to convert to a higher resolution digital signal. Naturally, this up-conversion facility can be switched in or out, according to the user's preference.
升頻最高可達192kHz
處理96kHz以下的數位訊號時,使用者可選擇兩倍或四倍升頻原始訊號的取樣率,即使播放44.1kHz訊源時(與CD聲音品質相同),類比音頻訊號也更加順暢,能以高解析數位訊號升頻,當然,使用者可根據自身喜好,選擇開啟或關閉升頻設備。
Dual monaural design eliminates interference between the left and right channels
In order to process the audio signal from a high-resolution sound source in a purer state, we adopt a dual monaural circuit design whereby each of the left and right channels comprises its own single monaural circuit. This avoids mutual interference between the left and right channels and enables pure stereo playback.
雙單聲道設計,能夠刪除左右聲道之間的干擾
為了在純淨的狀態下,從高解析訊源處理音頻訊號,我們使用雙單電路設計,也就是左右聲道都擁有獨立的單聲道電路,可以避免左聲道與右聲道之間互相干擾,確保純淨的立體聲播放。
High-performance BurrBrown PCM1795 digital-analog converter
The two internal BurrBrown 1795 digital-to-analog converter units each work on a single channel (left or right) for true dual monaural operation. They are capable of 32-bit processing and so have the capacity to process 5.6MHz DSD data in large quantities, making them indispensible for faithful and accurate playback of high-resolution sound sources.
高性能BurrBrown PCM1795 數位─類比轉換器
每個聲道(左聲道或右聲道)各採用一個BurrBrown PCM 1795 D/A轉換器,以確保準確的雙單聲道操作。它們能夠進行32-bit處理,所以能大量處理5.6MHz DSD檔案,是進行忠實與準確的高解析訊源播放不可或缺的部分。
MUSE operational amplifier enables highest quality analog signal processing
We use these in the analog circuit, they are a vital element in determining the final sound quality. They transform the electrical current output of the D/A converter into a voltage signal. We opted for a dual monaural configuration for the operational amplifiers, employing two MUSES8920 operational amplifier units, one on each of the left and right channels. These devices are made by New Japan Radio and are designed especially for hi-fi audio.
MUSE運算放大器,擁有最高品質的類比訊號處理
我們將這些材料用於類比電路當中,它們是決定最終聲音品質的關鍵,能將D/A轉換器的電流輸出轉換成電壓訊號。我們為運算放大器選用了雙單聲道設計,左右聲道各採用一個MUSES8920運算放大器元件。此外,這些裝置都是由New Japan Radio特別為hi-fi音響所製造的。
Even the headphone amplifiers used in the CCLC circuits are of dual monaural design
The 100mW + 100mW output (at 32 ohms load) headphone amplifier uses CCLC (Coupling Capacitor Less Circuit) technology. In conventional headphone output circuits, a capacitor is used for output-stage coupling, and so the sound is unavoidably colored. When the capacitor is combined with a high-pass filter this often results in phase lags, or low frequency level degradation. With CCLC the negative impact of capacitors on sound quality is eliminated, providing full low-frequency sound and a responsive headphone listening environment with great spatiality.
即使是CCLC電路中的耳機擴大機,亦採用雙單聲道設計
100mW + 100mW輸出(於32Ω時)的耳機擴大機採用CCLC (Coupling Capacitor Less Circuit耦合低電容線路) 科技。傳統的耳機輸出電路,輸出級耦合的部分採用了電容器,因此聲音很難不被染色,當電容器與高通濾波器結合時,通常會造成相位延遲或是低頻音量降低,藉由使用CCLC,就能刪除電容器對聲音所造成的負面影響,且提供豐沛的低音,及富有空間感的耳機聆聽環境。
Doubles as a no-compromise, high-performance headphone amp
In addition to the dual monaural headphone circuits, there are options to switch off the XLR and RCA outputs on the rear panel. By cutting the power supply and isolating those circuits that are unrelated to the headphone output, the performance of the UD-301's headphone output can be maximized. This feature also makes the headphone amp very easy to use as the volume control for the headphones is completely separate from the output mode (Fixed, Adjustable or Off) on the rear panel.
亦能成為不妥協、高性能的耳機擴大機
除了雙單聲道耳機電路外,亦可選擇將後背板的XLR與RCA輸出關閉,透過切斷電源供應並將與耳機輸出無關的電路獨立,UD-301耳機輸出的表現就能夠發揮到淋漓盡致。很簡單地,這個特色就能將耳機擴大機作為耳機的音量控制,且與後背板的輸出模式(FIX, VARI, OFF固定、可變或關閉)完全分離。
Toroidal core power transformer provides stable power flow
A high-efficiency toroidal core power transformer with low magnetic flux leakage is used to guarantee the stable operation of the twin left and right D/A converters that are so essential to the UD-301's high-speed signal processing. This transformer provides a stable power supply even in situations where a sudden surge of power is required, such as when starting up at very high volume.
環形鐵芯變壓器,能提供穩定的電流
高效率環形鐵芯變壓器,外漏的磁通量低,D/A轉換器對UD-301的高速訊號處理是相當重要的,且這個變壓器能確保左右D/A轉換器的操作穩定,甚至是在需要大量電流,像是以很高的音量啟動時,仍能夠穩定的供應電源。
Well-engineered aluminum enclosure, compact proportions
Following on from our development of the 501 series concept (small high-performance audio components that can be fitted on a desktop) we decided, at the outset, that the 301 series would be an even more compact design. Now, the casework has been shrunken to just 215mm wide, allowing greater freedom in positioning the amplifier. External highlights include aluminum panels and a motor-driven volume knob with the tactile feel you'd expect from controls found in high end full-size hi-fi components. At the same time, the solid enclosure underpinned by the metal chassis, is impressively inert, minimizing the effects of vibration on the unit's sound quality.
設計優良的鋁製外殼,體積小巧
延續我們501系列的研發概念(高性能小型音響配件,能輕鬆地置於桌面),我們決定在一開始的時候,301系列的設計應該更加小巧,因此將機箱的尺寸降到215mm寬,放置擴大機時就能夠有更多自由。外觀的點綴包含鋁製面板、電機驅動音量旋鈕,旋鈕的觸感與您期待在hi-end音響產品上所找到的相同,同時外殼以金屬機板支撐,相當穩固,能夠將震動對聲音品質所造成的影響降到最低。
XLR balanced output
The UD-301 is equipped with an XLR balanced output that can be connected not only to other domestic hi-fi components but also to professional audio equipment. As a highly versatile, high-performance D-A converter, the UD-301 offers a high degree of interoperability with devices ranging from those used by discerning consumers all the way up to those used in the professional domain.
XLR平衡輸出
UD-301配有一個XLR平衡輸出,除了能與一般hi-fi音響設備連接,也能夠與專業音響相連。作為多功能、高性能的D-A轉換器,UD-301提供相當高的互用性,能與不同等級的音響設備連接,從一般客人所使用的器材到專業領域所使用的音響設備,都能互相連接。
Connectable to a power amp in pre-amp mode
The XLR balanced output and RCA unbalanced outputs on the rear panel can both be set at Fixed, Adjustable or Off. Using the Adjustable setting, the UD-301 can be connected to a power amplifier to create a system with a separate pre amp and power amp or, alternatively, can be directly connected to an active speaker.
能以前級模式連接後級擴大機
後面板XLR平衡輸出與RCA非平衡輸出,可以FIX,VARI或OFF (固定、可變或關閉) 進行設定。使用可變設定,UD-301就能與後級連接,以創造一個前級與後級分離的系統,亦可直接與主動式喇叭連接。
Features at-a-glance
· 2.8MHz/5.6MHz DSD native playback (via USB input)
· 24bit/192kHz PCM file playback
· Asynchronous mode capability
· 192kHz up-conversion option (with On/Off selection)
· 2 x BurrBrown PCM1795 digital-to-analog converters
· Dual monaural design
· 2 x MUSES8920 operational amplifier units
· Dual monaural CCLC headphone output circuit
· Toroidal core power transformer
· Full metal housing
· 1×USB input (USB B type)
· 1×coaxial digital input
· 1×optical digital input
· 1×XLR balanced output (Fixed/Adjustable/Off)
· 1×RCA balanced output (Fixed/Adjustable/Off)
· Headphone output (standard stereo jack)
· Three-pin IEC AC power socket
· Auto Power Save function
· DSD 2.8M/5.6MHz 低失真播放
· 24bit/192kHz PCM檔案播放
· 非同步傳輸模式
· 可選擇升頻至192kHz(可選擇On/Off)
· BurrBrown PCM1795 D/A 轉換器×2
· 雙聲道電路設計
· MUSES8920 運算放大器×2
· 雙聲道CCLC耳機輸出電路
· 環形鐵芯變壓器
· 全金屬機身
· USB輸入(USB B類型)×1
· 同軸數位輸入×1
· 光纖數位輸入×1
· XLR平衡輸出(固定/可變/關閉×1
· RCA平衡輸出(固定/可變/關閉)×1
· 耳機輸出(標準立體聲插孔)
· 三插針式IEC AC電源插孔
· 自動省電功能
UD-301 SPECIFICATIONS
DAC Section
D/A Converter BurrBrown PCM1795×2
Up-conversion 192kHz (user defeatable)
Digital audio inputs
USB
Connector USB Type B (USB2.0)
Transmission mode Asynchronous mode
DSD data
sampling frequency 2.8M/5.6M Hz
PCM data
sampling frequency 32k/44.1k/48k/88.2k/96k/176.4k/192k Hz
Bit rates 16/24/32 bit
COAXIAL
Connector RCA jack
PCM data
Bit rates 16/24 bit
Input level 0.5Vp-p
Input impedance 75 ohms
OPTICAL
Connector Optical digital connector
PCM data
sampling frequency 32k/44.1k/48k/88.2k/96k Hz
Bit rates 16/24 bit
Input level -24 to -14.5dBm peak
Analog audio outputs
XLR
Connector XLR-3-32
Maximum output level +14dBu(1kHz, full-scale, 10k ohms with load, 0dB when set)
Output impedance 200 ohms
RCA
Connector RCA jack
Maximum output level 2.0Vrms(1kHz, full-scale, 10k ohms when loaded)
Output impedance 100 ohms
Headphone output
Connector 6.3mm(1/4") stereo phone jack
Maximum output 100mW + +100mW (32 ohms with load, distortion rate 0.1%)
Compatibility impedance 8 ohms to 600 ohms
Power supply
USA/Canada AC 120V, 60Hz
Europe AC 230V, 50Hz
Power consumption 10W
Dimensions
(including protrusions) 215(W)×61(H)×238(D)mm
8.5"(W)×2.4"(H)×9.4"(D)
Weight 2.0kg
4.4 lbs
Accessories Power cord, Instruction Guide (including Warranty)
Audio performance
Frequency response 5Hz to 55kHz (-3dB, in the case of 192kHz sampling frequency)
S/N ratio 105dB
Distortion 0.0015%(1kHz, in the case of 192kHz sampling frequency)
UD-301
A new standard in high-resolution audio, delivering high performance audio from a desktop component
Main Features
Dual monaural design, compatible with high-resolution DSDCapable of 5.6MHz DSD native playback
非同步USB輸入
升頻最高可達192kHz
亦能成為不妥協、高性能的耳機擴大機
環形鐵芯變壓器,能提供穩定的電流
設計優良的鋁製外殼,體積小巧
XLR balanced output
XLR平衡輸出
能以前級模式連接後級擴大機
· 非同步傳輸模式
· 雙聲道電路設計
· MUSES8920 運算放大器×2
· 雙聲道CCLC耳機輸出電路
· 環形鐵芯變壓器
· 全金屬機身
· USB輸入(USB B類型)×1
· 同軸數位輸入×1
· 光纖數位輸入×1
· 耳機輸出(標準立體聲插孔)
· 三插針式IEC AC電源插孔
· 自動省電功能
DAC Section
USB
DSD data
PCM data
COAXIAL
Connector RCA jack
PCM data
Bit rates 16/24 bit
Input level 0.5Vp-p
OPTICAL
PCM data
Bit rates 16/24 bit
XLR
Connector XLR-3-32
RCA
Connector RCA jack
Headphone output
Power supply
Dimensions
Weight 2.0kg
4.4 lbs
Audio performance
S/N ratio 105dB
- Number of posts : 1250
» TEAC UD-301 D/A Converter with USB Streaming
» Teac UD-501 Dual Monaural D/A Converter with USB Streaming, Black
» TEAC UD-501 Dual Mono D/A converter (New)
» TEAC UD-H01 DAC-Digital to Analogue Converter
