TEAC AR-650MK II Integrated Stereo Amplifier
TEAC AR-650MK II Integrated Stereo Amplifier Brand New. Now Selling At RM1,899. Free Shipping Within West Malaysia.
高功率集成放大器,使用了复杂的差分输入分离式放大器线路。
The A-R650 MKII amplifier provides up to 2×120W of output power and can be used with speakers of between 4Ω and 16Ω impedance. That makes it the perfect amplifier choice, regardless of whether it's to be used with bookshelf monitor speakers or large floorstanding speakers. Because the amplifier is equipped with two pairs of speaker outputs you can also enjoy simultaneous sound in separate rooms.
Further features include an adjustable microphone input and a headphone output. A Phono input with built-in Phono equalizer amplifier is another attractive feature for traditional audiophiles. A system remote control unit that's able to control the CD-P650 CD Player and any UR-tagged TEAC components also comes as standard. TAPE2 Monitor delivers monitor sound from the TAPE2 input to the speakers, regardless of the input source.
A-R650MKII放大器可以提供高达2×120W的输出功率,可用于 4Ω和16Ω阻抗之间的音箱。这使它成为放大器的理想之选,无论是用于书架监听音箱还是大型的落地式音箱。由于放大器配备了两对音箱输出,所以您还可以在不同的房间同时享受音乐。
其他功能包括可调的麦克风输入和耳机输出。具有内置唱机均衡放大器的唱机输入是吸引传统音响发烧友的另一个功能。能够控制CD-P650 CD播放器和任何带有UR标签的TEAC组件的系统遥控设备也是标准配置。TAPE2 监听器将监听声音从TAPE2输入传送到音箱中,不管输入源。
A discrete circuit design is employed for pre-amplifier section, to deliver a detailed yet abundantly musical quality. Your room will be filled with natural and powerful sound.
差分输入分离式前置放大器电路
前置放大器采用分离式电路设计,以传送详细而丰富的音乐品质。您的房间将充满自然和强大的声音。
FET Differential Input 3-stage Pure Complimental Discrete Power Amplifier Circuit
The power amplifier section employs a Differential Input 3-stage Pure Complimental Discrete circuit with FET (Field Effect Transistor). The circuit design has an optimised layout to minimize interference and signal loss as it travels through the circuit board.
FET差分输入3级纯互补分离式功放电路
功率放大器部分采用具有FET(场效应晶体管)的差分输入3级纯互补分离式电路。这种电路设局具有优化的布局,可以在其穿梭电路板是最小化干扰和信号损耗。
Mic input with mixing function
A mic input on the front panel allows users to stage Karaoke sessions by mix singing voices from a mic input with music from a selected input source. The A-R650MKII also helps users to record their Karaoke performances by sending the blended sound out to an external recording device such as AD-RW900 or CD-RW890.
带混合功能的麦克风输入
前面板上的麦克风输入允许用户通过将来自麦克风输入的声音与来自所选输入源的音乐混合来播放卡拉OK。A-R650MKII还可以通过将混合声音发送到外部录音设备(如CD-RW890MKII)来帮助用户录制其卡拉OK演奏。
Auxiliary AC Output
The A-R650MKII also features a switched auxiliary AC output on rear panel (up to 100w), so users can connect
辅助交流输出
A-R650MKII还有个功能就是在后面板上有开关辅助交流输出(最大100W),因此用户可以连接CD播放器或者组件,从而最大限度地减少所需的插头数量。
Spec description
Amplifier section
Rated Output Power 120W + 120W (4 ohms, 1kHz, T.H.D. 0.5%)
90W + 90W (8 ohms, 1kHz, T.H.D. 0.5%)
Total Harmonic Distortion 0.02% (8 ohms, 1kHz, 45W)
Supported Speaker Impedance
Speaker A or B 4 to 16 ohms
Speaker A + B 8 to 16 ohms
Frequency Response
Overall 10 to 65k Hz
Phono 20 to 20k Hz (+/-1dB RIAA)
Line 5 to 80k Hz (Source Direct, 1W)
S/N Ratio (Input Short)
Phono 65dB
Line 90dB
Tone Control
BASS +/-10dB (100Hz)
TREBLE +/-10dB (100Hz)
Muting -20dB
Audio Inputs/Outputs
Line Input
Connector ×6(RCA, Gold-plated)
Input Level 180mV
Impedance 47k ohms
Phono Input
Connector ×1(RCA, Gold-plated)
Input Level 2.8mV
Impedance 47k ohms
Line Output
Connector ×2(RCA, Gold-plated)
Input Level (TAPE/CD-R) 150mV
Impedance (TAPE/CD-R) 3.3k ohms
Mic Input
Connector 1/4" (6.3mm) Monaural Jack
Phone Out
Connector 1/4" (6.3mm) Stereo Jack
Speaker Terminals A, B (Binding-post)
Auxiliary Power Outlet Euro Socket ×1(Max 100W)
Power
UK/Europe AC230V 50Hz
Power Consumption 300W (0.5W at standby mode)
Dimensions 435(W) × 142(H) × 355(D) mm / 17.1"(W) × 5.6"(H) × 14.0"(D)
Weight 9.2Kg, 20.3lbs
A-R650MKII
A high-powered Integrated Amplifier employing sophisticated differential input discrete amplifier circuitry.高功率集成放大器,使用了复杂的差分输入分离式放大器线路。
A high-performance Stereo Integrated Amplifer
Differential Input Discrete Pre-amplifier CircuitA discrete circuit design is employed for pre-amplifier section, to deliver a detailed yet abundantly musical quality. Your room will be filled with natural and powerful sound.
差分输入分离式前置放大器电路
FET差分输入3级纯互补分离式功放电路
带混合功能的麦克风输入
Auxiliary AC Output
辅助交流输出
Spec description
Amplifier section
Frequency Response
Phono 65dB
Line 90dB
Tone Control
Muting -20dB
Line Input
Input Level 180mV
Impedance 47k ohms
Phono Input
Input Level 2.8mV
Impedance 47k ohms
Line Output
Mic Input
Phone Out
Power
- Number of posts : 1301
» TEAC AX-505 Integrated Stereo Amplifier
» TEAC AP-505 Stereo Power Amplifier
» TEAC AP-505 Stereo Power Amplifier - SOLD
» Teac A-1D Integrated Amplifier
» TEAC AS-100 Integrated Amplifier (Used)
