Furutech e-TP60 AC Power Distributor
Furutech e-TP60 AC Power Distributor Empty Furutech e-TP60 AC Power Distributor
Post by stylelaser.com.my on Fri Jan 18, 2019 10:31 am
Furutech e-TP60 AC Power Distributor Brand New. Now Selling At RM1,419. Free Shipping Within West Malaysia.
e-TP60
     Furutech e-TP60 AC Power Distributor Es_etp10
RATING
GC-303 EMI-Absorbing Internal Coating.
How can you tell you’re a victim of polluted AC power? Listen and look for these symptoms:
Flat, hard, and grainy high frequencies, a thick and bloated midrange, fat, uncontrolled bass, and loss of air and soundstage stability.
On video displays the picture resolution is less than sharp, with “ghosting”, color shift, “snow”, or vertical and horizontal lines.
If this looks and sounds familiar, you need Furutech!
Also available in 230V schuko model (e-TP60E)
FEATURES
The e-TP60 is a sophisticated, luxuriously made power distributor that eliminates many common problems found with audio and video components caused by massively contaminated electrical power.
The AC waveform becomes severely distorted by ground noise, voltage spikes and sags,high frequency power supply noise from other components in your own system, plus radiated high frequency digital noise from processors and digital interconnects.
There are also distortion products at the top and bottom of the AC waveform created by switch-mode power supplies in electronic devices on the same circuit. Additionally, you’re never alone; your residential AC mains supply is shared with other apartments, homes, and businesses on the same utility transformer. That’s why many audio and video enthusiasts notice their systems are more enjoyable late at night or on weekends!
The beautifully crafted special grade aluminum chassis effectively shields against another common problem,
RFI (Radio Frequency Interference), and a layer of Formula GC-303 blocks EMI (Electro Magnetic Interference).
Internal wiring is FURUTECH μ-14 wire(14 AWG) that guarantees low resistance.
Furutech Hyper Quality High Performance Receptacles are wired to the IEC AC input of the e-TP60.
Receptacles feature 24k gold-plated phosphor bronze, non-magnetic conductors for stable, long lasting, optimized power transfer.
Furutech’s Two-Stage Cryogenic and Demagnetization Alpha Process
The Final Result
The 2-Step Cryogenic and Demagnetizing Alpha Process works in tandem with other design-in features to create the most optimized AC power transfer possible.
Furutech’s total awareness and devotion to detail results in a greater sense of power, dynamics, and resolution, with cleaner, blacker backgrounds and a larger, more stable soundstage, vivid tonal colors and deeper extension at both ends of the frequency range.
The e-TP60 will allow the delicacy, refinement and nuance of a performance through, along with micro- and macro-dynamics that will leave you breathlessly engaged. Displays of all types will exhibit greater, sharper resolution with less ghosting, color shift, “snow”, or vertical and horizontal lines.
荣获2005年度日本BEST COMPO杂志奖项
Summary
本新产品( FURUTECH e-TP60 +GC-303 AC Power Distributor ) 是因应目前的AV器材,因为使用了「污染电源」而无法将器材的功能完全发挥出来而设计开发的产品。
Rating
电压 AC 125V 50/60Hz
电流 15 A
Features
GC-303的天线效果即是把经由各部配件传导而来的电磁波以非接触性方式有效的吸收消除,所谓天线效果意即GC-303能够如天线一般具有接收的功能,并且巧妙的避免传统电源滤波器经过一串被动式组件产生音质劣化的弊病。
GC-303采用特殊EPOXY树脂与机壳底部固定,完全不脱落绝对安全无虞。
*GC-303为铺在机壳底部之特殊电磁波吸收材料。
大电流用插座,绝对不采用对于音质有害的直列式NOISE FILTER及对音质有不良副作用的并列式NOISE FILTER,因为当电流通过时,因量能受到压抑而造成跃动感的衰减,产生无力感。
‧本产品采用全新学理来处理NOISE的方式乃是以GC-303作非接触性的NOISE吸收及消除,对于幅射性NOISE则以强韧的特殊级铝合金为基材,完全隔绝外来NOISE的入侵,达到纯净电源的效果。
特殊级铝合金:完全隔绝幅射性NOISE的入侵。
GC-303:吸收及消除经由配件及导线传入的传导性NOISE。
*GC-303可增加系统的解析力及透明度,对高频段的细节如
泛音、堂音的声音线条刻画有立竿见影的效果.
相关评论
Furutech e-TP60 电源排插
高优质电源生力军
一套系统是否会有够水准的表现,我想电源处理的妥当与否,是仅次于空间第二大的影响因素。在费心的处理过电源之后,若是没能使用质优的插座,那也是功亏一匮。以往音响迷仅有医院级的插座可供选择,音响室的电源部分若使用医院级插座,在大多数人眼中即可算是相当发烧的做法,但在越来越多的「Audio Grade」插座问世之后,医院级插座已不再是音响迷的第一选择,导体质精声音纯美的「发烧级」插座成为他们的新宠。
「发烧级」电源插座先锋
  若要说到「发烧级」电源插座,Furutech可算是此领域的先锋与个中好手。前几年当众人仍在迷恋医院级插座时,他们便率先推出「AudioGrade」级的Pro28电源排插,它比起医院级插座更为细致干净的表现,迅速在音响迷心中建立起了绝佳的口碑(笔者也曾是PRO.28N的疯狂爱用者,两套系统加起来共享了5个),PRO.28N停产之后仍有许多音响迷找寻这款电源排插的二手品,从此点也可看出它受欢迎的程度。虽然Furutech在PRO.28N停产后推出了RTP-6排插,但基于价格的原因,让许多音响迷无法亲身体会它的诸多优点,幸好Furutech推出了承接PRO.28N的新产品-e-TP60,让荷包不丰的朋友有了新选择。
用料讲究
  若要说e-TP60是简化版的RTP-6,可说是一点也不为过。笔者本想将e-TP60与RTP-6比较一下,看看两者的表现如何,不过代理商告知Furutech将e-TP60定位在承继PRO.28N,所以参考的对象就由e-TP60改为PRO.28N。
  e-TP60与PRO.28N的不同处在于,首先它采用三组共六位插座,这较PRO.28N多一组。e-TP60的外壳虽然与PRO.28N相同皆为铝合金材质,但PRO.28N所用者为Hubell电源盒代工品,上盖板也为不锈钢材质,而e-TP60所用铝材的阻绝性较佳,且上盖板与外壳材质相同,更可将干扰减到最低。另外,配在线两者也有不同,e-TP60所用者为线径14AWG的μ导体单股配线,与PRO.28N的多蕊细无氧铜线不同。最值得一提的是,e-TP60插座底部贴有一层名为「Formular GC303」的特殊物质,它可以将透过导线穿入的噪声吸除,让整体的声音表现更上曾楼。
声音纯净速结,细节丰富
  从外观上看来,e-TP60与PRO.28N所用的插座并无不同,皆为外表透明的制品。大概是拜特殊吸波材之赐,我觉得在声音干净的程度上,e-TP60比起PRO.28N要好上一层,背景的宁静度也较PRO.28N好了许多。有了更为深沉黑暗的背景,最为明显的好处就是细节一一清楚地浮现,老录音中因母带受损的嘶嘶声,显得格外的清晰明白,弦乐演奏时弓弦摩擦产生的细节,也显得较为丰富。e-TP60的声音较PRO.28N来得速结,笔者猜想这应该与e-TP60以单股导线有关。较为速结的表现,让大鼓的敲击除了有丰沛的能量之外,鼓皮的韧度与弹性也都能清楚的展现,鼓点亦显得扎实凝聚。
  承继PRO.28N的e-TP60电源排插,虽然价位稍高于PRO.28N,但在各方面表现均较PRO.28N要好上许多。若是您无法接受RTP-6将近两万元的身价,却又苦于找不到好的电源排插可用,我想这款e-TP60绝对能满足您在价位与声音两方面的要求。
焦点….虽然Furutech将e-TP60定位为接续PRO.28N的产品,但它的细节、背景宁静度、声音的纯度、速度与冲击感等各方面表现,比起PRO.28N更为精进,是无法负担RTP-6者的最佳选择。
     Furutech e-TP60 AC Power Distributor Es_fur10
Peter  012-2536225
Fong   016-3098668
Furutech e-TP60 AC Power Distributor Trade
SPECIFICATIONS
・VOLTAGE AC 125V 50/60Hz
・CURRENT 15A
・Outlets 6 Outlets
・Dimensions 200X130X60 mm
・WEIGHT 0.94Kgs
・Formula GC-303
GC-303 is a special material that Furutech layers and bonds to the interior bottom-plate of the chassis. It actually absorbs EMI (Electromagnetic Interference) generated by the internal fittings of the unit. The e-TP80E uses no other filtering besides GC-303 so AC resistance is kept to a minimum, allowing a more resolving, powerful, dynamic, and colorful performance from your components
本体材质 铝合金面板+铝合金成型
外型尺寸 200X130X60 mm
重量 0.94Kgs
          Furutech e-TP60 AC Power Distributor Es_fur11
Number of posts : 592
