Furutech E-TP80 AC Power Filter Distributor
Furutech E-TP80 AC Power Filter Distributor Empty Furutech E-TP80 AC Power Filter Distributor
Post by stylelaser.com.my on Fri Jan 18, 2019 10:43 am
Furutech E-TP80 AC Power Filter Distributor Brand New. Now Selling At RM2,549. Free Shipping Within West Malaysia.
e-TP80
-Awards-
Furutech E-TP80 AC Power Filter Distributor Untitled3 Furutech E-TP80 AC Power Filter Distributor SUntitled
-Reviews-
Furutech E-TP80 AC Power Filter Distributor U-audio_link
RATING
GC-303 EMI-Absorbing Internal Coating plus EMI noise filter.
・2 sets EMI noise filter for each of the two duplex Receptacles.
・GC-303 EMI-Absorbing for each of the four duplex Receptacles.
Also available in 230V schuko model (e-TP80E)
FEATURES
The e-TP80 is a sophisticated, luxuriously made power distributor that eliminates many common problems found with audio and video components caused by massively contaminated electrical power.
The AC waveform becomes severely distorted by ground noise, voltage spikes and sags, high frequency power supply noise from other components in your own system,plus radiated high frequency digital noise from processors and digital interconnects.
There are also distortion products at the top and bottom of the AC waveform created by switch-mode power supplies in electronic devices on the same circuit. Additionally, you’re never alone; your residential AC mains supply is shared with other apartments,
homes, and businesses on the same utility transformer. That’s why many audio and video enthusiasts notice their systems are more enjoyable late at night or on weekends!
The beautifully crafted special grade aluminum chassis effectively shields against another common problem, RFI (Radio Frequency Interference), and a layer of Formula GC-303 blocks EMI (Electro Magnetic Interference).
Internal wiring is FURUTECH μ-14 wire(14 AWG) that guarantees low resistance. Furutech Hyper Quality Audio Grade Receptacles are wired to the IEC AC input of the e-TP80. Receptacles feature 24K gold-plated phosphor bronze, non-magnetic conductors for stable, long lasting, optimized power transfer.
・Furutech’s Two-Stage Cryogenic and Demagnetization Alpha Process
The Final Result
The 2-Step Cryogenic and Demagnetizing Alpha Process works in tandem with other design-in features to create the most optimized AC power transfer possible. Furutech’s total awareness and devotion to detail results in a greater sense of power, dynamics, and resolution, with cleaner, blacker backgrounds and a larger, more stable soundstage, vivid tonal colors and deeper extension at both ends of the frequency range. The e-TP80 will allow the delicacy, refinement and nuance of a performance through, along with micro- and macro-dynamics that will leave you breathlessly engaged. Displays of all types will exhibit greater, sharper resolution with less ghosting, color shift, “snow”, or vertical and horizontal lines.
2005年度日本音响业界最高权威杂志Audio Accessory铭机赏
Summary
※本新产品( FURUTECH e-TP80 Filter +GC-303 AC Power Line Receptacle ) 是因应目前的AV器材,因为使用了「污染电源」,而无法将器材的功能完全发挥出来而设计开发的产品。
※结合"AV专用"电源滤波器与"纯音响"专用的电源分配器而设计.
※兼俱 "保护" 与 "音质" 双重优点的产品.
Rating
电压 AC 125V 50/60Hz
电流 15 A
承载瓦数 (全部插座合计)1875 W
插座 8 孔
超载保护方式 超载自动断路、手动复原式
绝缘耐压 AC 1500V 1 分钟 5mA
漏泄电流 1.0 mA以下
绝缘电阻 300MΩ 以上 DC 500V
电源指示灯 LED.液晶灯泡
跟机带电源线
Features
GC-303的天线效应即是把经由各部配件传导而来的电磁波以非接触性方式,有效的吸收消除,所谓天线效应意即GC-303能够如天线一般具有接收的功能,并且巧妙的避免传统电源滤波器经过一串被动式组件产生音质劣化的弊病。
GC-303采用特殊EPOXY树脂与机壳底部固定,完全不脱落绝对安全无虞。
*GC-303为铺在机壳底部之特殊电磁波吸收材料。
*大电流用插座,绝对不采用对于音质有害的直列式NOISE FILTER及对音质有不良副作用的并列式NOISE FILTER. 因为当电流通过时,量能受到压抑而造成跃动感的衰减,产生无力感。
*本产品采用全新学理来处理NOISE的方式乃是以GC-303作非接触性的NOISE吸收及消除,对于幅射性NOISE则以强韧的特殊级铝合金为基材,完全隔绝外来NOISE的入侵,达到纯净电源的效果。
特殊级铝合金:完全隔绝幅射性NOISE的入侵。
GC-303:吸收及消除经由配件及导线传入的传导性NOISE。
□ 防止噪声的干扰与突波的抑制
各种AV视听教材、仪器、或信息系统之主机、终端机等…对于突波雷击、电源噪声,造成的伤害可能会非常的严重,轻则造成错误的作业传输,或影响视听品质的完美,重则损坏整个系统设备,因此这些无孔不入的噪声与随时而来的突波,必需予以层层的过滤与抑制,始能提供一个“安全而无污染的净化电源”。
□ 突波/雷击/电源噪声的发生来源
突波(SURGE)的发生时常是输配电路上的大负载(如马达)之瞬间起动或关闭,甚至日常家用电器的一开一关也会造成突波与尖波之现象(SURGE OR SPIKES)至于雷击经由电线的侵入也一样造成强烈的突波(SURGE),虽其冲击时间常仅短至数百万分之一秒,但其电压或电流之强度,则高至数十万伏特或安培,相当可怕。
至于电线的噪声则大都来自附近产业机器或电源控制设备所造成的各种不规则之频率噪声,俗称电磁波(EMI或RFI NOISE)如点焊机、熔接机、马达、继电器或汽车发生的SPIKES附载于电线而传入者。
至于一般的电子波干扰,俗称射频(RF NOISE)则非本产品所能抑制,如电台、通信等电波干扰,甚至摩托车火星塞点火所发生的高频电波均是。
 类 别  滤波器
 型 号  e-TP-80
 滤波方式  2 回路独立滤波LC 网络 , 非接触性的NOISE吸收及消除
Furutech E-TP80 AC Power Filter Distributor E-tp80-1_xbn0
     Furutech E-TP80 AC Power Filter Distributor Es_351     Furutech E-TP80 AC Power Filter Distributor Es_251
Peter  012-2536225
Fong   016-3098668
Furutech E-TP80 AC Power Filter Distributor Trade
     Furutech E-TP80 AC Power Filter Distributor Es_141     Furutech E-TP80 AC Power Filter Distributor Es_533
SPECIFICATIONS
・VOLTAGE         AC 125V 50/60Hz
・FUSE CURRENT 15 A
・LOADING WATT 1875 W
・GROUNDING OUTLET 8 Holes
・OVERLODE PROTECTIVE TYPE         AUTOMATIC CIRCUIT
・INSULATION VOLT         AC 1500V 1 MINUTE 5mA
・LEAKAGE CURRENT         UNDER 1.0mA
・INSULATION RESISTANCE 300MΩ ABOVE DC 500V
・BODY MATERIAL AL. ALLOY PLATE (PAINTED)
・OUTWARD SIZE 400X130X60 mm
・WEIGHT 1.72Kgs
・Formula GC-303
・GC-303 is a special material that Furutech layers and bonds to the interior bottom-plate of the chassis.
 It actually absorbs EMI (Electromagnetic Interference) generated by the internal fittings of the unit.
 The e-TP80 uses no other filtering besides GC-303 so AC resistance is kept to a minimum, allowing a more resolving,
 powerful, dynamic, and colorful performance from your components.
本体材质 铝合金面板+铝合金成型
外型尺寸 400X130X60 mm
重量 1.72Kgs
          Furutech E-TP80 AC Power Filter Distributor Es_e-t10
Number of posts : 557
