Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver
Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Empty Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver
Post by stylelaser.com.my on Fri Jan 18, 2019 2:30 pm
Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Brand New. Now Selling At RM8,299. Free Shipping Within West Malaysia.
     Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Es_142     Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Es_252
TX-RZ830 9.2-Channel Network A/V Receiver
Entertainment like you’ve never felt it before
Feed your speakers the sound they deserve with the TX-RZ830, Onkyo’s premier mid-class A/V receiver, and unlock complete 7.2.4-ch object-based audio coverage (outboard stereo amp required), universal 4K HDR pass-through, and custom Dynamic Audio Amplification housed in a robust aluminum-fronted chassis. Sound is fluid, expressive, and dynamically faithful to the source, details resolving with astonishing transparency, ideal for high-resolution music including Direct DSD 11.2 MHz, LPs via phono pre-amp, SACD from Blu-ray™ player, or music streamed over AirPlay. Compatibility with popular wireless audio platforms allows the TX-RZ830 to fit in seamlessly with other compatible components for easy multi-room audio. Mobile apps synchronize the content you want in different spaces with Chromecast built-in, DTS Play-Fi® technology, or FlareConnect™. TIDAL, Amazon Music, Spotify, Deezer, and TuneIn are built in for easy navigation. Do your favorites a favor: order the TX-RZ830 and bring what you love to life.
帶來從未體驗過的娛樂享受
Onkyo高級中階A/V擴音機TX-RZ830,讓你的喇叭能夠呈現他們應有的聲音,並且完全解放7.2.4架構物件導向環繞音效(需配合額外立體聲擴音機),並對應直通傳輸各種4K HDR訊號,與及設有裝設於堅固的鋁製前機殼的定制Dynamic Audio Amplification動態音效擴音線路。聲音順滑生動,並忠實重現與訊源一樣的動態、驚人細節及通透感,適合重現包括原生DSD 11.2MHz、透過Phono前級擴音之黑膠專輯、從Blu-ray™播放機播放之SACD等高解像音訊,或者AirPlay串流音樂。兼容各種著名無線音訊平台,讓TX-RZ830能夠與其他相容裝置無縫配合,輕鬆使用多房間音響。透過Chromecast built-in、DTS Play-Fi®或FlareConnect™,流動apps可在不同使用空間中同步你想要的音樂內容。內置Tidal、Spotify、Deezer及TuneIn,即可更輕鬆登入並使用。做你想做的事:只需指令TX-RZ830,即可讓你的生活充滿樂趣。
Introducing the TX-RZ830
The TX-RZ830 brings a high-end approach to build and sound to the middle of our A/V receiver range. Our top-of-the-line high-current digital architecture is deployed with spectacular results: fluency, frequency range, transient response, and detail resolution are unassailable at the price. With sheer high-current power needed for edge-of-the-seat movie thrills and joyful stereo listening, the TX-RZ830 presents as a high-fidelity reference component loaded with connections needed for a custom install lasting well into the future.
為你介紹TX-RZ830
TX-RZ830將發燒級造工及聲音帶至我們的中階A/V擴音機產品線。我們開發之頂級高電流數碼架構帶來驚人結果:流暢度、頻率響應、瞬態響應及細節分析力,均是同價位中無可挑剔之作。配備能夠應付「埋身」的電影刺激感及令人投入的立體聲聆聽的高電流功率,TX-RZ830同時是一款配備可以持續於未來作定制安裝之豐富連接介面的高保真示範級器材。
THX® Certified Select™ cinema-reference audio
THX Certified Select guarantees cinema-reference sound in your home. To gain certification, amplifiers must pass severe bench-tests covering every aspect of performance. THX Certified Select components suit rooms where screen-to-seat distance is about 3 meters and volume 57 cubic meters.
THX® Select™ 認證戲院示範級音效
THX Select認證保證在你的家中,都可體驗到與戲院相同的高質素聲音。為獲取認證,擴音機必須通過業界最嚴格、涵蓋多方面聲音表現的測試。THX Select認證器材非常適合由屏幕到座位觀賞距離約3米、而體積約為57立方米的房間中使用。
Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Wps5CAE.tmp
Dynamic Audio Amplification (DAA)
The DAA philosophy places less emphasis on lab measurements and more on how the sound actually feels in real life. High-current drive and expert tuning deliver natural transient response, the key to involving sound. A deep power reserve arrives instantly when action explodes on screen, adding adrenaline to the film experience. Accuracy and control is maintained with custom transformer and custom block capacitors, aluminum heat sink, non-phase-shift amp circuitry, and discrete output transistors. With VLSC™ noise filtering (Front L/R) for improved fidelity, DAA is built for compelling sound.
動態音效放大線路(DAA)
DAA理念是不只著眼於實驗室測量,更多關注於在現實生活中的實際聲音體驗。高電流驅動及專業級調聲提供自然的動態瞬變,亦是影響聲音質素高低的關鍵因素。當屏幕上出現爆炸場面,深厚的能量儲備能夠即時送達,為觀影體驗更加刺激。定制變壓器、大型電容、非相位平移擴音線路及離散式輸出晶體管,帶來準確及妥善控制力。借助VLSC™噪聲濾波(前置L/R)去改善保真度,DAA是為出眾的聲音而開發。
Dolby Atmos® and DTS:X® at up to 7.2.4 channels
Hear Dolby Atmos and DTS:X soundtracks through 7.2.2 or 5.2.4 channels. Connect an outboard power amp via 11.2-multichannel pre-outs for even more expansive 7.2.4-ch playback. Enjoy seamless top-to-bottom, side-to-side, and front-back coverage with in-ceiling speakers and floor-standing speakers. Individual sounds aren’t tied to channels and move around your audience.
最高7.2.4架構之Dolby Atmos®及DTS:X®
可以7.2.2或5.2.4架構聆聽Dolby Atmos及DTS:X聲軌。透過11.2聲道Pre-out輸出端子連接一部外置功率擴音機,即可享受由4個天花喇叭及7個底層喇叭組成,從上至下、左至右及前至後全方位無縫覆蓋的環繞聲效。獨立聲音物件不受聲道束縛,可以自然地圍繞聆聽者移動。
Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Wps3A00.tmp
Dolby® and DTS® solutions for 3D sound
DTS Neural:X™ technology and Dolby Surround find cues in legacy soundtracks and upmix for playback through systems with height channels. Cross-compatible with Dolby® and DTS® formats, enjoy spatially realistic and natural sound from your existing DVD and Blu-ray Disc™ library or streaming service.
DTS Neural:X™技術及Dolby Surround可以識別多聲道聲軌中的空間效果,並配合高空喇叭,向上轉換成3D音效播放。與Dolby®及DTS®格式交叉支援,可從現有的DVD及Blu-ray Disc™片庫或電影串流服務中,享受空間感真實而自然的聲音。
Chromecast built-in works with the Google Assistant
Stream any music from your smartphone, laptop, or PC to the receiver with ease. Control playback with Chromecast-enabled apps from your iPhone, iPad, Android™ phone or tablet, Mac or Windows laptop, or Chromebook™. If you have a device with the Google Assistant built-in, you can control music on the TX-RZ830 by voice.
Chromecast built-in並兼容Google Assistant
將智能電話、手提電腦或電腦中任何音樂,流暢地串流至擴音機。從iPhone、iPad、Android 電話或平板電腦、Mac®或 Windows®手提電腦或Chromebook™中,透過Chromecast兼容Apps操控音樂投放。如果你擁有支援Google Assistant之裝置,你可以透過語音指令操控TX-RZ830播放之音樂。
Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Wps9570.tmp
Ready for DTS Play-Fi® multi-room audio technology
DTS Play-Fi technology allows you to enjoy quality music from online services, media server, and mobile device to any number of compatible products using Onkyo Music Control App. DTS Play-Fi technology can synchronize music in every room.
為DTS Play-Fi®多房間音響技術作好準備
DTS Play-Fi技術讓你可以從任何兼容產品上,透過Onkyo Music Control app享受線上串流服務、多媒體伺服器及流動裝置中的高質素音樂。DTS Play-Fi技術更可在所有房間中同步播放音樂。
FlareConnect™ wireless multi-room audio
FlareConnect shares audio from network and external audio input sources between compatible components. Enjoy effortless multi-room playback of LP records, CDs, network music services, and more with supported components and speaker systems. Music selection, speaker grouping, and p
Playback management across the home are built into the Onkyo Controller app.
FlareConnect™無線多房間音響功能
FlareConnect可在兼容的裝置中共享網絡及外置音訊輸入訊源的音樂內容。在支援的器材及喇叭系統上,輕鬆享受多房間播放LP黑膠唱碟、CD、網絡音樂服務等等。透過Onkyo Controller app,就可作橫跨各房間的音樂選播、喇叭群組及播放管理。
Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver WpsEB32.tmp
Powered sound in three zones
With a 5.2-ch cinema layout in Zone 1 (Main), the remaining four channels can drive speakers in Zone 2 and Zone 3. As well as analog distribution, dedicated DACs enable digital sources* to be synced across rooms simultaneously, or a unique source to be played in every zone at once. Zone 2 and Zone 3 pre-/line outputs are ideal for sharing sources to existing hi-fi systems.
* Audio via HDMI inputs and S/PDIF audio not supported in Zone 3.
三區有源聲音
除Zone 1(Main)的5.2聲道家庭影院佈局外,其餘4個聲道可以用作驅動Zone 2及Zone 3的喇叭。可分配模擬音訊之餘,搭載專屬DAC可以令數碼訊源*在各個房間之間同步播放,或者不同區域同時間播放不同的訊源。Zone 2及Zone 3 Pre-out/線性水平輸出,非常適合分享訊源至現有Hi-Fi系統。
* Zone 3不支援HDMI輸入音訊及S/PDIF音訊。
Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Wps6F38.tmp
AccuEQ Advance for Accurate Calibration
AccuEQ sets speaker distance, SP level, and crossover. In addition, AccuEQ Advance employs multi-point measurement to remove standing waves from your listening space, which compromise audio quality and bass response. The technology also detects and compensates for background noise, such as the hum from an HVAC, to ensure accurate equalization.
AccuEQ Advance精準校正
AccuEQ設定喇叭距離、SP音壓及分頻。此外,AccuEQ Advance採用多點測量,以消除你的聆聽空間內影響聲音質素及低頻響應之駐波問題。此技術還可檢測及補償背景噪音,例如來自HVAC的嗡聲,確保精確的均衡度。
Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver WpsC557.tmp
Wi-Fi® and Bluetooth® wireless connectivity
Built-in 5 GHz/2.4 GHz Wi-Fi provides network stability for streaming, Onkyo Controller app, and multi-room audio. Bluetooth wireless technology is also on board for easy mobile or laptop connection.
Wi-Fi®及Bluetooth®無線連接
內置5 GHz/2.4 GHz Wi-Fi,為串流播放、Onkyo Controller app及多房間音訊提供穩定網絡連接。內置藍牙無線技術也方便連接流動裝置或手提電腦,AirPlay、串流服務及網絡電台同樣已經預載其中。透過AirPlay無線音訊平台,從iPad、iPhone、Mac及電腦搜尋及串流音樂。除此之外, Spotify、TIDAL、Deezer及TuneIn亦全部整合至系統的GUI介面之中,透過Onkyo Controller或Onkyo Music Control app就可輕鬆地選播音樂。
AirPlay, streaming services, and internet radio built in
Find and stream music from iPad, iPhone, Mac, and PC over the Apple AirPlay wireless audio platform. Further, Amazon Music, Spotify, TIDAL, Deezer, and TuneIn are all baked into the system GUI, making selection easy using Onkyo Controller or Onkyo Music Control App.
Supports 4K HDR, BT.2020, 4K/60 Hz, and HDCP 2.2
Welcome film-like 4K video bursting with bright and vibrant colors enabled by High Dynamic Range (HDR) to your supported TV display or projector. The receiver’s HDMI® inputs, Main Out, and Sub/Zone 2 Out pass HDR10, HLG, and Dolby Vision™ formats through to compatible displays. These terminals support the BT.2020 4K video standard, 4K/60 Hz playback, and HDCP 2.2.
支援4K HDR、BT.2020、4K/60 Hz及HDCP 2.2
讓支援的電視或投影機迎接如電影般的4K影像,並以高動態範圍(HDR)帶來明亮及顏色鮮艷的畫面。擴音機之HDMI® 輸入、主輸出及副/Zone 2輸出,均可直通傳輸HDR10、HLG及Dolby Vision™至兼容的顯示器。上述端子同時對應播放BT.2020 4K影像規格、4K/60Hz訊號及HDCP2.2。
Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver WpsA0AE.tmp
          Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Es_534
Peter  012-2536225
Fong   016-3098668
Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Trade
          Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Es_623     Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Es_253
Channels    9.2
Power Output per Channel    120 W per channel (8 Ohms, 20 Hz to 20 kHz, 0.08% THD, 2-channels driven, FTC)
250 W per channel (6 Ohms, 1 kHz, 10% THD, 1-channel driven)
Dynamic Power per Channel    130 W (8 Ohms, front)
220 W (4 Ohms, front)
250 W (3 Ohms, front)
THD & Noise    0.08% (20 Hz to 20 kHz, half power)
Input Sensitivity and Impedance    200 mV/47 kOhms (Line)
3.5 mV/47 kOhms (Phono MM)
RCA Output Level and Impedance    Subwoofer Pre-Out, Rated: 1.0 V/470 Ohms
Zone Pre-Out, Rated: 1 V/2.3 kOhms
Zone Pre-/Line-Out, Rated: 1 V/200 mV/470 Ohms
Frequency Response    5 Hz to 100 kHz / +1 dB, -3 dB (Direct Mode)
Tone Control    Bass: ±10 dB, 20 Hz
Treble: ±10 dB, 20 kHz
Signal-to-Noise Ratio    106 dB (line, IHF-A)
80 dB (phono, IHF-A)
Speaker Impedance    4 to 16 Ohms
Processing
Dolby    Dolby Atmos, Dolby TrueHD, Dolby Surround
DTS    DTS:X, DTS-HD Master Audio, DTS Neural:X
Video Section
Input Sensitivity/Output Level and Impedance    Component Y: 1.0 Vp-p/75 Ohms
Component B/R: 0.7 Vp-p/75 Ohms
Composite: 1.0 Vp-p/75 Ohms
Tuner Section
Tuning Frequency Range    FM: 87.5 to 107.9 MHz
AM: 530 to 1710 kHz
FM/AM Preset Memory    40 stations
Connectivity
Wi-Fi    Dual-band 2.4 / 5 GHz
Bluetooth    Version: 4.1 + LE
Profiles: A2DP v1.2, AVRCP v1.3
AirPlay    Yes
Inputs    7 x HDMI (1 front)
2 x RCA component video
2 x RCA composite video
2 x optical TOSLINK
1 x digital coaxial
6 x stereo RCA
1 x stereo RCA phono with ground screw
Outputs    2 x HDMI
1 x stereo RCA zone 2 pre-/line-out
1 x stereo RCA zone 3 / height 2 pre-/line-out
2 x subwoofer pre-out
1 x 1/4" / 6.35 mm headphone (front)
Other Interfaces    1 x RJ45 Ethernet LAN
1 x 1/8" / 3.5 mm setup mic in (front)
1 x 1/8" / 3.5 mm IR in
1 x RS-232 in
1 x 1/8" / 3.5 mm 12 V trigger out
1 x AM antenna
1 x FM antenna
1 x USB 5 V / 1 A
Speaker Connectors    11 x binding post pairs
General
Power Requirements    120 VAC, 60 Hz
Power Consumption    Typical: 870 W
On, No Sound: 70 W
Standby: 0.15 W
Dimensions (W x H x D)    17.1 x 7.9 x 15.7" (435 x 201.5 x 398 mm)
Weight    30.9 lb (14 kg)
Packaging Info
Package Weight    36.35 lb
Box Dimensions (LxWxH)    22.0 x 19.0 x 13.0"
     Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver Es_447
Number of posts : 557
