Klipsch R-51M 5.1 Speaker Package
Klipsch R-51M 5.1 Speaker Package Empty Klipsch R-51M 5.1 Speaker Package
Post by stylelaser.com.my on Tue Jan 22, 2019 11:16 am
Klipsch R-51M 5.1 Speaker Package Brand New. Now Selling At RM5,399. Free Shipping Within West Malaysia.
      Klipsch R-51M 5.1 Speaker Package Es_kl114
The Klipsch R-51M 5.1 Speaker Package  includes 1 Pair  R-51M Bookshelf Speaker, 1 Pair Klipsch R-41M Bookshelf Speaker, 1 Unit Klipsch R-52C Center Speaker and the 1 Unit Klipsch R-100SW Subwoofer .
Klipsch R-51M Bookshelf Speaker
Leveraging a 1" aluminum tweeter matted to our proprietary Tractrix horn-loaded technology - the R-51M bookshelf speaker delivers incredible acoustics to fill your home with loud, crystal-clear sound and robust bass that no ordinary bookshelf speaker can.
Features:
  • 1" Aluminum LTS tweeters
  • 90x90 Square Tractrix Horns
  • Dual 5.25" Spun-Copper IMG Woofers
  • Bass-Reflex via Rear-Firing Port
  • Dimensions: 13.3" x 7" x 8.5"
     Klipsch R-51M 5.1 Speaker Package Es_kl115
The R-41M bookshelf speakers offer maximum versatility without sacrificing performance from a small, yet elegant audio solution. Designed as main speakers for a compact living space or surround sound to support a Reference speaker system, the R-41M bookshelf speakers are the ideal choice for your home theater system.
Features:
  • 4" Spun-Copper IMG Woofers
  • Dimensions: 11.3" x 5.75" x 7.9"
Get crystal-clear sound for your movie dialogue and music lyrics with the incredible acoustics from the R-52C center channel speaker. Our proprietary Tractrix® horn-loaded technology gives you a lifelike, front-row listening experience unlike any other.
Features:
  • Closed Back Design for Flexible Placement
  • Dimensions: 7.3" x 18.75" x 7.6"
Klipsch R-100SW 10" Powered Subwoofer
The Klipsch R-100SW subwoofer delivers incredibly deep bass via a 10" front-firing driver featuring a spun-copper IMG woofer and all digital amplifier.
Features:
  • 10" Front-Firing Spun-Copper IMG Woofer
  • All-Digital Amplifier with 300 Watts Peak Power
  • Volume, Low Pass Crossover and Phase Control
  • Line Level/LFE RCA Inputs for Maximum Receiver Compatibility
  • Dimensions: 14.5" x 12.5" x 16.4"
  • Black Textured Wood Grain Vinyl
     Klipsch R-51M 5.1 Speaker Package Es_kl116
Klipsch R-51M
FREQUENCY RESPONSE 62Hz - 21kHz +/- 3dB
SENSITIVITY 93 dB @ 2.83V/1M
POWER HANDLING (CONT/PEAK) 85W/340W
NOMINAL IMPEDANCE 8 ohms Compatible
CROSSOVER FREQUENCY 1,660 Hz
HIGH FREQUENCY DRIVER 1” Aluminum LTS tweeter mated to a 90 x 90 square
Tractrix®️ Horn
LOW FREQUENCY DRIVER Single 5.25” spun-copper IMG woofer
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass-Reflex via rear-firing ports
INPUTS Single Gold Plated Binding Posts
HEIGHT INCHES (MM) 13.3” (338 mm)
WIDTH INCHES (MM) 7” (178 mm)
DEPTH INCHES (MM) 8.5” (215 mm)
PRODUCT WEIGHT LBS (KG) 11 lbs (5 kg)
FINISHES Black Textured Wood Grain Vinyl
INCLUDED ACCESSORIES Rubber Feet (4)
BUILT FROM 2018
       Klipsch R-51M 5.1 Speaker Package Es_kl117
Klipsch R-41M
FREQUENCY RESPONSE 68Hz - 21kHz +/- 3dB
SENSITIVITY 90 dB @ 2.83V/1M
POWER HANDLING (CONT/PEAK) 50W/200W
CROSSOVER FREQUENCY 1,730 Hz
Tractrix®️ Horn
LOW FREQUENCY DRIVER Single 4” spun-copper IMG woofer
HEIGHT INCHES (MM) 11.3” (287 mm)
WIDTH INCHES (MM) 5.75” (146 mm)
DEPTH INCHES (MM) 7.9” (200 mm)
PRODUCT WEIGHT LBS (KG) 7 lbs (3.2 kg)
BUILT FROM 2018
Peter  012-2536225
Fong   016-3098668
Klipsch R-51M 5.1 Speaker Package Trade
Klipsch R-52C
FREQUENCY RESPONSE 89Hz - 21kHz +/- 3dB
SENSITIVITY 95 dB @ 2.83V/1M
POWER HANDLING (CONT/PEAK) 100W/400W
CROSSOVER FREQUENCY 1,630 Hz
Tractrix®️ Horn
LOW FREQUENCY DRIVER Dual 5.25” spun-copper IMG woofers
ENCLOSURE TYPE Sealed
HEIGHT INCHES (MM) 7.3” (185 mm)
WIDTH INCHES (MM) 18.75” (476 mm)
DEPTH INCHES (MM) 7.6” (194 mm)
BUILT FROM 2018
Klipsch R-100SW
FREQUENCY RESPONSE 32Hz - 120Hz +/- 3dB
MAXIMUM ACOUSTIC OUTPUT 112 dB
AMPLIFIER All Digital
AMPLIFIER POWER (CONT/PEAK) 150W/300W
AMPLIFIER FEATURES Volume, Low-pass, 0/180 phase, Auto Power On
DRIVER COMPONENTS 10” high excursion spun-copper IMG woofer
INPUTS Line level/LFE RCA jacks
HEIGHT 14.5” (368 mm)
WIDTH 12.5” (318 mm)
DEPTH 16.4” (417 mm)
WEIGHT 24 lbs (10.9 kg)
BUILT FROM 2018
       Klipsch R-51M 5.1 Speaker Package Es_kl118
Number of posts : 557
