Klipsch R-610F 5.0 Speaker Package
Klipsch R-610F 5.0 Speaker Package Empty Klipsch R-610F 5.0 Speaker Package
Post by stylelaser.com.my on Tue Jan 22, 2019 11:37 am
Klipsch R-610F 5.0 Speaker Package Brand New. Now Selling At RM4,999. Free Shipping Within West Malaysia.
The Klipsch R-610F 5.0 Speaker Package includes 1 Pair Klipsch R-620F Floorstanding Speaker, 1 Pair Klipsch R-41M Bookshelf Speaker, and the 1 Unit Klipsch R-52C Center Speaker.
Klipsch R-610F Floorstanding Speaker
Standing at only 37" tall, yet able to produce deep bass extension, The R-610F floorstanding speaker takes your movies and music to another level by delivering incredible sound from our signature Klipsch horn-loaded tweeter and a spun-copper IMG woofer.
        Klipsch R-610F 5.0 Speaker Package Es_kl119
Features:
  • 1" Aluminum LTS tweeter
  • 90x90 Square Tractrix Horn
  • Single 6.5" Spun-Copper IMG Woofers
  • Bass-Reflex via Rear-Firing Tractrix® ports
  • Dimensions: 37" x 9.4" x 15.1"
The R-41M bookshelf speakers offer maximum versatility without sacrificing performance from a small, yet elegant audio solution. Designed as main speakers for a compact living space or surround sound to support a Reference speaker system, the R-41M bookshelf speakers are the ideal choice for your home theater system.
Features:
  • 1" Aluminum LTS tweeters
  • 90x90 Square Tractrix Horns
  • 4" Spun-Copper IMG Woofers
  • Bass-Reflex via Rear-Firing Port
  • Dimensions: 11.3" x 5.75" x 7.9"
      Klipsch R-610F 5.0 Speaker Package Es_kl120
Get crystal-clear sound for your movie dialogue and music lyrics with the incredible acoustics from the R-52C center channel speaker. Our proprietary Tractrix® horn-loaded technology gives you a lifelike, front-row listening experience unlike any other.
Features:
  • Dual 5.25" Spun-Copper IMG Woofers
  • Closed Back Design for Flexible Placement
  • Dimensions: 7.3" x 18.75" x 7.6"
        Klipsch R-610F 5.0 Speaker Package Es_kl121
Peter  012-2536225
Fong   016-3098668
Klipsch R-610F 5.0 Speaker Package Trade
Klipsch R-610F
FREQUENCY RESPONSE 45Hz - 21kHz +/- 3dB
SENSITIVITY 94 dB @ 2.83V/1M
POWER HANDLING (CONT/PEAK) 85W/340W
NOMINAL IMPEDANCE 8 ohms Compatible
CROSSOVER FREQUENCY 1,800 Hz
HIGH FREQUENCY DRIVER 1” Aluminum LTS tweeter mated to a 90 x 90 square
Tractrix®️ Horn
LOW FREQUENCY DRIVER Single 6.5” spun-copper IMG woofer
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass-Reflex via rear-firing Tractrix®️ports
INPUTS Single Gold Plated Binding Posts
HEIGHT INCHES (MM) 37” (940 mm)
WIDTH INCHES (MM) 9.4” (240 mm)
DEPTH INCHES (MM) 15.1” (384 mm)
PRODUCT WEIGHT LBS (KG) 36 lbs (16.3 kg)
FINISHES Black Textured Wood Grain Vinyl
INCLUDED ACCESSORIES Injection molded feet & screws
BUILT FROM 2018
Klipsch R-41M
FREQUENCY RESPONSE 68Hz - 21kHz +/- 3dB
SENSITIVITY 90 dB @ 2.83V/1M
POWER HANDLING (CONT/PEAK) 50W/200W
CROSSOVER FREQUENCY 1,730 Hz
Tractrix®️ Horn
LOW FREQUENCY DRIVER Single 4” spun-copper IMG woofer
ENCLOSURE TYPE Bass-Reflex via rear-firing ports
HEIGHT INCHES (MM) 11.3” (287 mm)
WIDTH INCHES (MM) 5.75” (146 mm)
DEPTH INCHES (MM) 7.9” (200 mm)
PRODUCT WEIGHT LBS (KG) 7 lbs (3.2 kg)
INCLUDED ACCESSORIES Rubber Feet (4)
BUILT FROM 2018
Klipsch R-52C
FREQUENCY RESPONSE 89Hz - 21kHz +/- 3dB
SENSITIVITY 95 dB @ 2.83V/1M
POWER HANDLING (CONT/PEAK) 100W/400W
CROSSOVER FREQUENCY 1,630 Hz
Tractrix®️ Horn
LOW FREQUENCY DRIVER Dual 5.25” spun-copper IMG woofers
ENCLOSURE TYPE Sealed
HEIGHT INCHES (MM) 7.3” (185 mm)
WIDTH INCHES (MM) 18.75” (476 mm)
DEPTH INCHES (MM) 7.6” (194 mm)
BUILT FROM 2018
          Klipsch R-610F 5.0 Speaker Package Es_kl122
Number of posts : 592
