TEAC TN-180BT Turntable with Bluetooth Transmitter
TEAC TN-180BT Turntable with Bluetooth Transmitter Brand New. Now Selling At RM989. Free Shipping Within West Malaysia.
Bluetooth Turntable
具有唱机EQ和蓝牙的3速模拟唱盘
The TN-180BT brings you a totally new way of listening to vinyl records with its Bluetooth capability. No extra cost for hi-fi components or complicated wiring is required. Only Bluetooth speakers or headphones you might have for iPhones are required to enjoy the world of vinyl records.
Designed for music enthusiasts, the belt-drive motor ensures a clearer sound than direct-drive DJ players, while selectable outputs, Phono, Line or Bluetooth allow you to connect any type of amplifiers, powered speakers or Bluetooth devices.
Unlike many budget turntables, the TN-180BT employs a single wooden board cabinet with high-density MDF to dampen vibrations and provide clearer and richer sound, while 3-speed and auto-return turntable mechanism.
For music lovers who have been collecting vinyl records for decades or those just starting out, TEAC’s TN-180BT delivers the true sound of vinyl records.
TN-180BT为您带来了一种全新的蓝牙功能的黑胶唱片收听方式。 高保真组件或复杂的布线不需要额外的费用。 只要有蓝牙音箱或耳机,就可以享受唱片的世界。
专为音乐爱好者设计,皮带驱动电机确保比直接驱动的DJ播放器更清晰的声音,而可选输出,Phono,Line或蓝牙则允许您连接任何类型的放大器,有源扬声器或蓝牙设备。
与许多廉价唱盘不同,TN-180BT采用单层木板箱体和高密度纤维板来抑制振动,并提供更清晰和更丰富的音质,且具有3速和自动返回转盘机构。
对于几十年来一直在收集黑胶唱片或刚刚起步的音乐爱好者而言,TEAC的TN-180BT提供了黑胶唱片的真实声音。
Built-in Bluetooth® transmitter
The TN-180BT delivers the sound wirelessly via built-in Bluetooth® transmitter, in addition to conventional RCA output in analog Line or Phono format. The pairing button is located at the tone-arm base, which illuminates when the connection with BT speakers/headphone is made successfully.
除了传统的模拟线路或唱机格式的RCA输出之外,TN-180BT还通过内置蓝牙发射器无线传输声音。 配对按钮位于音色臂底座,当与蓝牙扬声器/耳机连接成功时亮起。
MM-type cartridge pre-installed for quick start
An MM-type cartridge is already installed to the straight-type tone-arm at the factory, so you can start playing records as soon as you open the box.
The authentic belt-drive turntable is driven by a high torque DC motor, while precision stainless steel spindle and durable brass spindle holder maintain accurate rotation speed.
TN-180BT播放LP,EP和SP唱片。 播放结束后,音色臂自动返回到原始位置。 在工厂中,直型音调臂上已经安装了MM型卡式磁带,因此只要打开盒子就可以开始播放唱片。
High-density MDF cabinet construction
Unlike others with plastic chassis, a single wooden board with high-density MDF minimizes vibrations and resonance to playback of your vinyl record library with clearer sound.
与其它塑料底盘不同的是,采用高密度纤维板的单块木板可以最大限度地减少振动和共鸣,从而以更清晰的声音播放黑胶唱片库。
Built-in MM-type Phono EQ amplifier
Enjoy vinyl playback with any amplifier regardless type of inputs. The TN-180BT supports both PHONO and LINE outputs that allow you to play vinyl with or without Phono equalizer.
无论输入类型如何,均可使用任何放大器欣赏黑胶唱片播放。 TN-180BT同时支持唱机和线路输出,使您可以使用或不使用唱机均衡器播放黑胶唱片。
Motor DC Motor
Speed 33 1/3 RPM, 45 RPM, 78 RPM
Wow and Flutter 0.25%
Signal-to-Noise Ratio 64dB or higher (A-weighted, 20kHz LPF)
Platter Plastic
Diameter of Platter 12", 30cm
Tonearm section
Type Static Balance, Straight
Effective Arm Length 7.9", 200mm
Stylus Pressure Range 0 to 5g
Cartridge section
Type MM-type
Output Voltage 2.4mV (±3dB)
Analog Output section
Connectors RCA Pin x 1 pair (Chrome-plated)
Output Voltage
PHONO 2.4mV (±3dB)
LINE 149mV (–16.5dBV)
Bluetooth section
Range Approx. 30ft. / 10 meters
Supported Codec SBC
General
Power AC 100 to 240V, 50/60Hz
Power Consumption < 1.5W (< 0.2W at Standby)
Overall Dimensions
(W x H x D) 16.5" x 4.1" x 14.0"
420 x 105 x 356 mm
Weight Approx. 10.8 lbs. 4.9 kg
Bluetooth Turntable
TN-180BT
The simplest way of enjoying vinyl records具有唱机EQ和蓝牙的3速模拟唱盘
Motor DC Motor
Platter Plastic
Tonearm section
Cartridge section
Type MM-type
Output Voltage
PHONO 2.4mV (±3dB)
Bluetooth section
Supported Codec SBC
General
Overall Dimensions
420 x 105 x 356 mm
- Number of posts : 1301
» (SOLD) Teac TN-180BT Turntable Bluetooth MM Phono PreAmp 3-speed Vinyl Record Player
» TEAC MC-D800-CH All-In-One Turntable Speaker System with Bluetooth
» Arylic B50 Bluetooth Stereo Amplifier With Audio Transmitter
» TEAC AI-301DA int amp with DAC & BLUETOOTH (SOLD)
» TEAC AI-301DA Integrated Amplifier Dac & Bluetooth
