Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Empty Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver
Post by stylelaser.com.my on Fri Jan 25, 2019 12:34 pm
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Brand New. Now Selling At RM6,799. Free Shipping Within West Malaysia.
Unbridled Performance and Function. This 9.2-channel AV receiver harnesses dual ESS SABRE DACs, seven HDMI inputs, three HDMI outputs, Dolby Atmos® and DTS:X, Multi-Zone functionality, Phono input, Wi-Fi®, YPAO with Precision EQ and much more.
  • 9.2-ch Dolby Atmos, DTS:X (7.2.2-ch or 5.2.4-ch) and CINEMA DSP HD3 with Zone 2/3/4
  • Wi-Fi, Bluetooth®, AirPlay®, Spotify Connect and MusicCast multi-room
  • New Surround:AI technology automatically optimizes the sound in real-time
  • 4K Ultra HD support, HDR10, Dolby Vision, Hybrid Log-Gamma and BT.2020
  • HDMI with HDCP 2.2 (7 in/3 out)
  • Dual ESS SABRE ES9007S Premier Audio DACs for high performance conversion
  • Pandora®, Spotify, SiriusXM Internet Radio, TIDAL, Deezer, Napster and more
  • YPAO R.S.C., multipoint, 3D and precision EQ
  • Voice control using your Alexa device like Echo or Echo Dot
  • Phono input
9.2-聲道 AVENTAGE 機型,配備超凡的3D音場播放和最新最先進的 Surround:AI 功能。
  • 9-聲道大功率環繞音效
  • --- 每聲道140 W (8 ohms, 20 Hz-20 kHz, 0.06% THD, 2-ch driven)
  • --- 每聲道 220 W (8 ohms, 1 kHz, 10% THD, 1-ch driven)
  • --- 每聲道 220 W (4 ohms, 1 kHz, 0.9% THD, 1-ch driven)
  • Surround:AI 自動即時優化音效
  • CINEMA DSP HD3 支援 Dolby Atmos® 和 DTS:X™
  • YPAO™-R.S.C. 以及 3D 聲音優化、多點測量和高精準 EQ
  • 可外加無線環繞揚聲器*(* MusicCast 20 或 MusicCast 50)
  • Amazon Alexa 語音控制相容*(*服務因地區而異)
  • 高剛性底盤,包括A.R.T腳座抗振技術
  • 高品質零件,達到最佳音效
  • 使用 ESS DAC 具備真正的專業數位音訊品質
  • MusicCast 多房間技術
  • 內建音樂串流服務
  • HDMI® (7 進 / 3 出) 相容 Dolby Vision™ / Hybrid Log-Gamma
  • 適用播放黑膠唱片的 Phono 輸入功能
Your Cinema
Surround:AI
The AI technology built into the DSP analyses the scene of the entertainment content and then creates the optimal surround effect to reproduce it with the greatest effect. This AI instantaneously analyses scenes by focusing on distinct sound elements such as dialogue, background music, ambient sounds and sound effects, and automatically optimises the surround effect in real time, just as if a Yamaha sound engineer tunes the best sound specifically for you. This creates a compelling sense of realism with expressive power beyond conventional sound field effects, giving you the most profound entertainment experience possible.
您的劇院
Surround:AI
內建於 DSP 的 AI 技術可分析娛樂內容的場景,然後創造出最佳的環繞效果,重現最佳音效。此 AI 技術可透過專注於不同的聲音元素,例如對話、背景音樂、環境音和特效音效,快速分析場景並自動並即時優化環繞效果,宛如 Yamaha 聲音工程師專門為您調音至最佳的音效般。透過超越傳統音場效果的強力表現,創造出震撼且身歷其境的感受,讓您擁有最深刻的娛樂體驗。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Your-cinema-surround-ai_1200x694_41eb49705545b72cb551fb3d054ae034
Thrilling Realism in Surround Sound
Dolby Atmos® and DTS-X™ Playback with CINEMA DSP HD3
This AV receiver supports Dolby Atmos and DTS-X playback with CINEMA DSP HD3, taking the surround sound experience to new heights. The revamped CINEMA DSP HD3 features new signal processing algorithms and three sets of high performance processors. This maximises theatre sound effects, accurately reproducing a new dimension of realism for a sound field with a rich sense of presence and no feeling of boundaries. You will experience a realistic cinema sound field with the sense of truly being immersed in the movie scene.
環繞音效震撼的臨場感
CINEMA DSP HD3 支援 Dolby Atmos® 和 DTS-X™ 播放
此 AV 收音擴大機,透過 CINEMA DSP HD3,支援 Dolby Atmos 和 DTS-X,更提升您環繞音效的體驗。升級後的 CINEMA DSP HD3 提供了新的訊號處理計算以及三組高性能處理器。以展現最佳的劇院效果,精準的重現擬真音場、真實感與無邊界的感覺。您將會感受到真實的劇院音場與身歷其境的效果。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Thrilling-realism-in-surround-sound_800x344_79feed5edc978f8617211cb94e593baa
For Sound Purity
Highly Rigid Construction
The AVENTAGE model RX-A2080 features a sleek, clean design, with an elegant aluminium front panel. Even more importantly, the unit is exceptionally sturdy, with an interior reinforced with cross members in an H-shape. It also features the Anti Resonance Technology (A.R.T.) Wedge, which is a fifth foot in the centre of the unit that dampens vibrations from the power transformer and elsewhere. Thanks to these, installation stability is improved and  chassis resonance is dispersed, effectively eliminating external vibration, maintaining the highest audio quality.
純淨音質
高剛性底盤
AVENTAGE RX-A2080 機型以其優雅的鋁質前面板,散發時尚俐落的設計感。更重要的是,內部使用橫向 H 型交叉框架加強固定,讓裝置非常穩固。同時配備抗振技術 (A.R.T.)楔型腳座,裝置中央配備五支支腳,可抑制來自變壓器或他處的震動。因有配備此科技,得以提升安裝穩定度並分散底盤共振,有效消除外部震動以維持最佳音質。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver 201803_RXA3010_side_800x580_491dc6d33a15c02eaeb3824d696b0b91Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Op_2080_800x580_67e575bad55c8c736e31f8a138991197Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver RXA70_leg_U_800x580_9e7c9ed5485b5bfe5e1f5825b61051b2
Optimum Performance
High Quality Parts
Every single part in an AV receiver affects the sound quality. For AVENTAGE models, extra time is taken to carefully select the most exacting, high-quality parts — including a large-capacity power amplifier unit with damping heat sink, a custom large power transformer, high-performance DSP devices, and so on — in order to achieve the highest performance possible. Moreover, sound technicians employ rigorous testing processes to optimally “tune” the receiver’s sound.
最佳性能
高品質零件
AV 收音擴大機的每個零件都會影響音質。針對 AVENTAGE 機型,特別花費額外心力,選擇最嚴苛且最優質的零件 — 包括配備減震散熱器、定製的大型變壓器、高性能 DSP 裝置以及許多其他功能的大型功率擴大機 — 以達到最佳性能。此外,聲音技師落實嚴格的測試流程,完美「調音」收音擴大機的音質。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Ax080_col3_fig3-1_792x580_0493d7ad1f6cf8509aa12fc7542607eaYamaha RX-A2080 9.2Ch Atmos Network Av Receiver Ax080_col3_fig3-2_792x580_1a0980d82d0270a085b71daee3fe43f4Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Ax080_col3_fig3-3_792x580_aa401ce266fdd4a8af84f1d4b127b0c4
Professional Grade
ESS SABRE™ ES9007S Premier DACs
Incorporating the SABRE ES9007S Premier Audio DACs from ESS Technology to achieve an exceptionally good signal-to-noise ratio and up to 120 dB of dynamic range, this AV receiver produces professional quality digital audio.
專業級音質
整合 ESS 技術的 SABRE ES9007S Premier Audio DACs,達到無比優異的訊噪比和最高 120 dB 的動態範圍,此款 AV 收音擴大機具備真正的專業數位音訊品質。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver A1080_professional-grade-ess-sabre-pro-9007a-premier-dac_800x397_a4b42b97b31336bd5f3d5aa22117da1f
Ideal Sound Optimisation
YPAO™ - R.S.C. with 3D, Multi-Point Measurement and Precision EQ
YPAO-R.S.C. (Reflected Sound Control) analyses the room acoustics with the included YPAO microphone to tune your system for the best sound in your unique room. It employs R.S.C. to correct early reflections for studio-quality surround sound. YPAO 3D provides automatic sound parameter optimisation that maximises the 3D sound field effectiveness of CINEMA DSP HD3 as well as Dolby Atmos and DTS:X. Precision EQ calculation achieves the most natural room acoustics possible.
理想的音效優化
YPAO- R.S.C.(反射聲音控制功能)使用內建的 YPAO 麥克風,分析室內聲學條件,校正您的系統,達到室內環境的最佳音效。配備 R.S.C. 矯正早期反射音以達到錄音室音質。YPAO 3D 提供自動音質優化功能,可展現 CINEMA DSP HD3 以及 Dolby Atmos 和 DTS:X 的 3D 音場效果。高精準 EQ 計算室內聲學條件,達到最自然的環繞音效。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver YPAO_2080_800x464_99f379ddd2d353600c89034480a8b57a
Free and Easy Placement
Wireless Surround Speakers
Combine this AV receiver with the MusicCast 50 or MusicCast 20 wireless streaming speaker and enjoy the amazing convenience of creating a home theatre with wireless rear speakers. What’s more, you get stunningly realistic sound with a clean, clutter-free setup. Easily turn your current living room into a special entertainment environment where you can fully enjoy movies and music.
  • MusicCast 50 product page
  • MusicCast 20 product page
  • MusicCast SUB 100 product page
自由隨意擺放
無線環繞揚聲器
結合 AV 收音擴大機以及 MusicCast 50 或 MusicCast 20 無線串流揚聲器,搭配無線後置揚聲器,方便您建立家庭劇院。不僅如此,可享有無比真實的音效,且仍保有清爽不雜亂的環境。輕鬆將現在的客廳變成可觀賞電影和欣賞音樂的影音娛樂場所。
  • MusicCast 50 產品頁
  • MusicCast 20 產品頁
  • MusicCast SUB 100 產品頁
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Free-and-easy-placement-2_d485_v485_s602_v585_v685_800x448_a4693601c2531ac3e4962bbba717a83b
Multi-room Audio
MusicCast
MusicCast takes the headache out of multi-room audio. Simply connect all MusicCast devices to the same network and start sharing audio throughout the home. Take MusicCast for a test drive by downloading the free MusicCast app and using it demo mode.
  • *For more details, please visit MusicCast special page
多房間音訊技術
MusicCast
MusicCast 讓多房間音訊技術與眾不同。只需將所有 MusicCast 裝置連接到相同網路就可開始在家中共享音樂。下載免費 MusicCast app 並使用試用模式。
  • * 如需更多資訊,請前往 MusicCast 特別專頁
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Your-music-everywhere_d485_v485_s602_v585_v685_800x428_869c14dea9dfb7f10d99a73cafba2e84
A World of Music
Streaming Services
Explore a world of music with music streaming services* built-in. Syncing your playlists and song likes from your smart phone or computer to the RX-A2080, music streaming services make it impossibly easy to either listen to your faves or discover new music.
* Music streaming service availability varies by region.
音樂世界
串流服務
使用內建的音樂串流服務*,探索音樂世界。將您的智慧型手機或電腦的播放清單和喜愛歌曲同步至 RX-A2080,音樂串流服務讓您可輕鬆聆聽最愛的音樂或探索新的音樂。
* 音樂服務因地區而異。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Explore-new-musical-worlds_d485_v485_s602_v585_v685_800x373_7d9659e54bf51303afcd8ab709fe6fbc
Easily Experience 11-channel Realism
Virtual Speaker Technology
The RX-A2080 is equipped with three Yamaha original high performance DSP devices, achieving high speed and large capacity audio signal processing. As a result, CINEMA DSP HD3 playback can reproduce up to 11-channel sound — on even a 7-channel system. The total reproduction of spatial data, including the vertical axis, helps create an overwhelmingly realistic sound field.
* Requires connection to a front presence speaker. Dolby Atmos and DTS: X signals cannot be used with these virtual features.
輕鬆體驗 11-聲道身歷其境的感受
虛擬揚聲器科技
RX-A2080 配備三個 Yamaha 原創高性能的 DSP 裝置以達到高速且大資料量的音訊信號處理。因此,CINEMA DSP HD3即使在 7-聲道系統播放,也能重現最多 11-聲道音效。空間資料的重現包括垂直軸,可協助創造具震撼性的身歷其境的音場。
* 需連接至前臨場揚聲器。Dolby Atmos 和 DTS:X 訊號無法與這些虛擬功能搭配使用。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Easily-experience-11.1-channel-realism_800x598_7b45683ce845bd03be7dccc7147a2350
Convenient Enjoyment
Three HDMI Outputs
Since the RX-A2080 has three HDMI output terminals, simultaneous connection to the TV, LCD projector and other devices, is possible. Which means, for example, that you can use your TV as usual but use the projector for your favourite movies and special programming, or have the same main room content shown in other rooms as well — easily and without having to change any connections. Naturally, the built-in HDMI functionality is of the latest specifications, corresponding also to HDR (Dolby Vision Compatible, Hybrid Log-Gamma), 4K / 60p passthrough, 4K upscaling, and so on.
便利享受
三組 HDMI 輸出
因 RX-A2080 有三組 HDMI 輸出端子,因此可同步連接至電視、LCD 投影機和其他裝置。這代表,您可如常使用電視,並使用投影機播放最愛的電影和特別節目或輕鬆在其他房間播放與主房間相同的內容 - 且不須變更任何連線。內建 HDMI 功能是最新的規格,還有 HDR(Dolby Vision 相容、Hybrid Log-Gamma)、4K/60p 直通、4K 升頻等等。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Ax080_convenient-enjoyment-three-hdmi-outputs_800x466_61403028d7712002d66d5ccc85e0f68b
The Joys of Vintage Vinyl
Phono Input
This AV receiver provides phono input terminals, letting you connect a turntable and enjoy music from your vinyl collection.
便利享受
三組 HDMI 輸出
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver The-joys-of-vintage-vinyl_v685_800x476_ad08739eb408db2f3e78c79a26532b3b
Enhanced Home Theatre Sound
7.2-channel Pre-outs
You can add an external power amplifier (pre-main amplifier) to this AV receiver to improve and enhance the sound of your speakers. For example, using a power amplifier to drive the important front channel in home theatre gives you the added flexibility of building a system with an emphasis on sound quality
更強化的家庭影院效果
7.2-聲道 Pre-outs
您可在此 AV 收音擴大機外接功率擴大機(前置主擴大機),提升和改善揚聲器音效。例如,使用功率擴大機,驅動家庭劇院的重要前聲道,讓您更彈性建置系統同時強化音質。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver A3080_enhanced-home-theatre-sound-11.2-channel-pre-outs_800x393_63d8e2cb7fe7e4bf38ca9d32a2e659cb
Enjoy Digital Radio
DAB/DAB+ Tuner
Digital Audio Broadcasting capability, with DAB and the enhanced DAB+, offers a large selection of radio stations with high sound quality. Other benefits include automatic selection of available stations from a convenient list, and helpful information display, including station name and music genre.
* Availability of DAB / DAB+ tuner function varies by region.
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Enjoy-digital-radio_d485_s602_800x118_043285965af6a13fadc0789c60796c8f
Let’s Talk
Alexa on MusicCast
“Alexa, ask MusicCast to play Favourite 1 in the Kitchen.” With Alexa voice control integration, all you have to do is ask. The RX-A2080 name offers full compatibility with Amazon’s range of voice control devices. Welcome to the smart home.
* Availability of voice command control via Amazon Alexa varies by region.
開口說話
MusicCast 支援 Alexa
「Alexa,要求 MusicCast 播放在廚房中最愛的音樂 1。」有了 Alexa 聲音控制整合,您要做的只是開口問。RX-A2080 機型與 Amazon 的一系列語音控制裝置完整相容。歡迎來到智慧家庭。
* 透過 Amazon Alexa 的語音指令控制服務因地區而異。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Say-hello-to-voice-control_d485_v485_s602_v585_v685_800x284_2fa821aaa4a0e6b31bf8d129dc414dec
Easy Operation, Detailed Settings
AV Controller App
This easy-to-use app lets you conveniently and ‘smartly’ control your AV receiver’s power, volume, input selections, DSP modes — and much, much more — from an iOS or Android™ device. You can also use as many as 23 different languages and customise the interface by hiding unused icons and renaming functions. A tablet version is also available.
輕鬆操作、詳盡的設定
AV Controller App
此款易於使用的 App 讓您可方便並「輕鬆」的透過 iOS 或 Android™ 裝置控制您的 AV 收音擴大機電源、音量、輸出選擇、DSP 模式 - 還有許多選項。您可使用多達 23 種語言並隱藏不使用的圖示並重新命名功能,自訂介面。同時提供平板版本。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Easy-operation-detailed-settings_d485_v485_s602_v585_v685_800x378_dd0132f840ed7a3603cefbb9010b6bf5
Easy to Use and Multilingual
Advanced Graphical User Interface
The latest graphical user interface from Yamaha has a high-resolution display with clear, easy-to-use menus and includes a selectable status bar that shows input source, volume level, DSP mode and audio format. The GUI provides a choice of eight languages: English, French, German, Spanish, Italian, Russian, Japanese and Chinese and can be displayed over both normal and 3D pictures.
易於使用且多語言
進階圖示化使用者介面
Yamaha 的最新圖示使用者介面 (GUI) 有高解析度顯示的操作簡易選單,另外還有一個可選狀態功能條,顯示輸入源、音量、DSP 模式與音訊格式。GUI 共有 8 種語言任您選擇:英文、法文、德文、西班牙文、義大利文、俄文、日文和中文,可選擇以正常或 3D 圖片顯示。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Easy-to-use-and-multilingual_d485_v485_s602_v585_v685_800x383_e99757e8bca3cf45a396b7ce52b94c40
Playback in Multiple Zones
Advanced HDMI Zone Switching
You can transmit the video or audio content (not only HDMI input, but also other audio sources, such as digital or analogue audio, network content and FM/DAB radio) to a TV or home theater system in another room (Zone 2/4). This lets you enjoy viewing and listening to the same main room content (where the AV receiver is installed), or even different content. An on-screen graphical user interface makes it easy to browse and select content from the second zone no matter what is being played in the main zone.
多區域播放
先進的HDMI Zone 切換
您可傳輸影像或音訊內容(不僅是 HDMI 輸入,也可以包括其他音訊來源,如數位或類比音訊、網路內容和 FM/DAB 收音機)至其他空間的電視或家庭劇院系統(Zone 2/4)。這讓您可享受與主空間相同的影音內容(安裝 AV 收音擴大機的空間)或甚至是不同的內容。螢幕顯示的圖示使用者介面,讓您輕鬆瀏覽並從第二區域選擇內容,無論主區域播放的內容為何。
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver A1080_playback-in-multiple-zones-advanced-hdmi-zone-switching_800x399_75f06971393012828e540868f55611c0
Even Higher Quality Sound
Bi-amp Connection
This AV receiver features bi-amping capability, driving the treble and bass ranges of the front speakers (L, R) with independent amplifiers, making it possible to enjoy even higher quality sound from the front channels — an important consideration in home theatre setups.
更高品質的音效
Bi-amp 連接端子
此特殊的 App 可協助您進行 AV 收音擴大機及訊源設備中的接線。此外,可引導您做許多設定如揚聲器連結、電視以及來源設備的連結以及分配功率擴大機。
Brilliant and Lively
Music Enhancer
The Compressed Music Enhancer from Yamaha is now optimised for Bluetooth audio transmissions to ensure that your music will have vivid, energetic sound quality during wireless playback.
精彩而生動
音樂增強裝置
Yamaha 的壓縮音樂增強裝置現已優化,可進行藍牙音訊傳輸,無線播放音樂時,享有更生動、更有活力的聲音品質。
Install with Ease
AV Setup Guide
This special app assists you with cable connections between the AV receiver and source devices. Additionally, it guides you through various settings such as speaker connections, TV and source device connections and power amplifier assignments.
輕鬆安裝
AV Setup Guide
此特殊的 App 可協助您進行 AV 擴大機及來源設備中的接線。此外,可引導您做許多設定如揚聲器連結、電視以及來源設備的連結以及配置後級擴大機。
Save Energy by 20%
Eco Mode
When ECO Mode is turned on it can reduce power consumption by about 20 percent*, thanks to an advanced energy saving design. *Compared to power consumption when ECO mode is off (Yamaha measurement)
最多可節省電力 20%
ECO 節能模式
開啟 ECO 節能模式,有了先進的省電設計,可節省耗電量約20%。*與 ECO 節能模式關閉時比較耗電量(Yamaha 測量)。
     Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Es_g0211     Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Es_g0212
Peter  012-2536225
Fong   016-3098668
Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Trade
Specifications:
RX-A2080
Amplifier Section Channel 9.2
Rated Output Power (1kHz, 2ch driven) 155 W (8 ohms, 0.9% THD)
Rated Output Power (20Hz-20kHz, 2ch driven) 140 W (8 ohms, 0.06% THD)
Maximum Effective Output Power (1kHz, 1ch driven) (JEITA) 220 W (8 ohms, 10% THD)
Dynamic Power / Ch (Front L/R, 8/6/4/2 ohms) 165 / 210 / 285 / 405 W
Surround Sound Processing Surround:AI Yes
Cinema DSP Yes (HD3)
DSP Programs 24
Dialog Level Adjustment Yes
Virtual Presence Speaker Yes
Virtual Surround Back Speaker Yes
Dialogue Lift Yes (no presence speakers required)
SILENT Cinema / Virtual Cinema DSP Yes (Virtual CINEMA FRONT)
Dolby Atmos Yes
Dolby TrueHD Yes
Dolby Digital Plus Yes
Dolby Surround Yes
DTS:X Yes
DTS-HD Master Audio Yes
Audio Features File Format MP3 / WMA / MPEG-4 AAC: up to 48 kHz / 16-bit, ALAC: up to 96 kHz / 24-bit, FLAC: up to 192 kHz / 24-bit, WAV / AIFF: up to 192 kHz / 24-bit, DSD: up to 11.2 MHz
Pure Direct Yes (with video on mode)
Compressed Music Enhancer Yes
High-resolution Music Enhancer Yes
YPAO Multi-point Measurement Yes with R.S.C. (Reflected Sound Control), 3D, Precision EQ Calculation and Angle Measurement
YPAO Volume Yes
Adaptive DRC (Dynamic Range Control) Yes
Initial Volume and Maximum Volume Setting Yes
A.R.T. Wedge Yes
Bi-amp Capability Yes
Audio Delay Yes (0-500 ms)
DA Converter ESS 384 kHz / 32-bit SABRE Premier DAC ES9007S x 2
Video Features 4K Ultra HD Pass-through and Upscaling Yes (4K / 60p, 4:4:4)
HDMI 3D Pass-through Yes
HDMI eARC Yes (via future firmware update)
HDMI Audio Return Channel Yes
HDMI Upscaling Yes (Analog to HDMI®️ / HDMI to HDMI)
Video Adjustment Yes
Deep Color / x.v.Color / 24Hz Refresh Rate / Auto Lip-Sync Yes
Connectivity MusicCast Surround Yes (via future firmware update)
Wi-Fi Yes (2.4 / 5 GHz)
AirPlay Yes
Bluetooth Yes (SBC / AAC)
Phono Input Yes
Component Video Input/Output 2 / 0
Extensive Connection HDMI Input/Output 7 / 3 (HDCP 2.2, HDR10 / Dolby Vision / HLG and BT.2020 compatible)
HDMI CEC Yes (SCENE, device control)
USB Input USB memory
Network Port Yes
Front AV Input USB / analog audio
Digital Audio Input / Output: Optical 3 / 0
Digital Audio Input / Output: Coaxial 3 / 0
Analog Audio Input / Output 9 (front 1) / 0
Composite Video Input / Output 4 / 0
Preout 7.2-ch
Headphone Output 1
Tuner Section FM / AM Tuner Yes
User Interface On-Screen Display Graphical User Interface
SCENE SCENE PLUS (8 sets)
App Control Yes (iPhone / iPad / Android phone / tablet)
Web Browser Control Yes
Remote Control Unit Yes
Zone Control Zone 2 Audio Output Preout / HDMI
Zone 3 Audio Output Preout
Zone 4 Audio Output HDMI
Powered Zone Zone 2 / 3
Zone Video Output HDMI / component / composite
Zone HDMI Yes (advanced HDMI zone switching)
Zone B Output HDMI
Zone GUI Yes
RS-232C Interface Yes
+12V Trigger Output 2
Remote (IR) Input/Output 1 / 1
Party Mode Yes
General Standby Power Consumption (IR only) ≤ 0.1 W
Auto Power Standby Yes
ECO Mode Yes
Dimensions (W x H x D) 17-1/8" x 7-1/2" x 18-5/8" (with antenna up: 17-1/8" x 10-5/8" x 18-5/8")
Weight 37.5 lbs.
     Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Es_yam57     Yamaha RX-A2080 9.2Ch Atmos Network Av Receiver Es_yam58
Number of posts : 592
