Shunyata Research HYDRA 6 Power Conditioner with a Matching Shunyata Research HYDRA HC VTX 20Amp Power Cable from USA
Post by meridian-506 on Mon Feb 11, 2019 10:16 pm
For your consideration, in excellent condition, a paired Shunyata Research HYDRA 6 Power Conditioner, with a matching original factory-terminated 1.8m length Shunyata Research HYDRA HC VTX 20Amp Power Cable, selling at RM4.1k.
( New was US $1599 / RM 6512. - US$999 for the HYDRA 6 Power Conditioner & US$600 for the HYDRA HC VTX Power Cable )
This Shunyata Research HYDRA 6 Power Conditioner has 6 Rear AC outlets, sporting USA-type Outputs to power up to 6 equipment.
( NOTE : Hydra Power conditioners do NOT come with power cords. This is because Shunyata believes that power cords are a component not a throw-away. We highly recommend that a Shunyata Hydra 6 be used with a 20Amp Shunyata AC cable to the wall for best performance.)
This original, factory-terminated 1.8m length Shunyata Research HYDRA HC VTX 20Amp Power Cable (US$600) was specially designed to partner the HYDRA series of Power Conditioners and is the High Current (HC) version to provide ample "juice" to power the Shunyata Research Power Conditioners.
This Shunyata Research HYDRA 6 Power Conditioner, with a matching original factory-terminated 1.8m length Shunyata Research HYDRA HC VTX 20Amp Power Cable are in Excellent Condition & are Made in the USA.
Pictures :
*** Apologies, currently I am having some issues posting the Pictures.
For Pictures of the actual unit, please send a Whatssap message to +65-82494702. ***
Overview / Specifications :
https://www.musicdirect.com/power/shunyata-hydra-6
https://www.musicdirect.com/cables/shunyata-hydra-hc-vtx-20amp-power-cable-ashunhhc6ft20amp
Shunyata Research Hydra 6 :
Description :
Hear the Difference Pristine Power Makes !
The Shunyata Hydra Model-6 incorporates all of the innovative design and technical elements--save Shunyata’s FeSi-1000 compounds-- that have earned the Hydra 8 its unprecedented array of critical awards and professional endorsements. Shunyata’s six proprietary cryogenically treated outlets are connected to the Hydra 6’s massive solid copper buss system, eliminating all point-to-point wiring.
The Hydra Model-6 Trident Defense System provides noise-reduction with Shunyata’s best five-element Venom filter array, isolating and protecting each duplex outlet as independent power-sources. Statement-making surge and spike protection is passively implemented and totals a line-popping 60,000-amps of peak current protection. Rounding out the Hydra six package is enormous over-current protection in the form of Carling’s best hydraulic electromagnetic breaker.
Features
6,000 volts and 60,000 amps of surge protection
NextGen thermally protected TMOVs
Shunyata designed Venom filters (5-element)
Hydraulic electromagnetic circuit breaker (over current protection)
Each outlet individually filtered
Solid copper power distribution buss
Equivalent to an incredible 7-gauge wire
No point-point wiring
Detachable 20-amp power inlet
Power Rating: 2400 watts continuous, 20-amps continuous
14 gauge all metal chassis
Professional rack mount faceplate
Threaded footers for after-market cones
All inlets and outlets mounted on back .
Matching Shunyata Research HYDRA HC VTX 20Amp Power Cable :
Description :
The Ideal Mate for Any Component !
The Hydra HC VTX power cord is a purpose built, high performance cord specifically engineered to satisfy even the most current hungry of components. capable of delivering a staggering amount of power virtually instantaneously, HHC VTX was originally intended to be the anchoring cable for Shunyata’s Hydra power conditioners.
Surprisingly, the same characteristics which make HHC VTX so fantastic for power conditioners also make it an excellent cable for amplifiers, preamps, even source components.
Design :
A massive 9AWG cable, the HHC VTX delivers outstanding electrical characteristics and massive current capability.
HHC VTX supercharges any component, unleashes true dynamic range, improves transient capability and delivers greater low-frequency control and slam.
The HHC VTX uses Shunyata's ultra-pure CDA-101 copper conductors, which offer far lower distortion, sweeter purity of tone and far greater conductivity than any other copper conductors on the market.
Shunyata's proprietary Virtual Tube Geometry (VTX) geometry greatly reduces noise and vastly improved current delivery, delivering superior imaging, clearer detail, richer tonal balance, smoother frequency response and far better depth of image.
Virtual Tube Geometry (VTX) :
World renowned for ultra-complex wire geometries which measurably improve conductivity and other desirable characteristics, Shunyata has developed Virtual Tube Geometry (VTX).
Testing using DTCD determined that the ideal conductor is a hollow tube, but this is wildly impractical in the real world.
VTX construction allows Shunyata cables to mimic the performance of a hollow tube and greatly reduces inductance and “skin-effect”.
Construction :
The HHC VTX is built slightly differently than other Shunyata cords.
Designed for durability and functionality, rather than aesthetic beauty, the Hydra HC has a sturdy PVC jacket which allows Shunyata to offer this cable at a shockingly low price given the high-value of the ingredients in this over-achieving cable.
Shunyata's proprietary termination techniques and the same custom IEC and Wall Plugs which grace all upper Shunyata cords are used as well.
Originally purchased from the Local Agents in Singapore, this paired Shunyata Research HYDRA 6 Power Conditioner, with a matching original factory-terminated 1.8m length Shunyata Research HYDRA HC VTX 20Amp Power Cable is the 240 version and is safe for local usage.
Actual set as pictured above, this paired Shunyata Research HYDRA 6 Power Conditioner, with a matching original factory-terminated 1.8m length Shunyata Research HYDRA HC VTX 20Amp Power Cable is in Excellent Condition.
Payment mode will be on a C.O.D. basis.
This paired Shunyata Research HYDRA 6 Power Conditioner, with a matching original factory-terminated 1.8m length Shunyata Research HYDRA HC VTX 20Amp Power Cable is currently in KL.
Collection can be done in JB, KL, Ipoh, Penang or Butterworth at no extra charge - for other collection locations, kindly contact me.
Shipping via PosLaju is NOT available.
If you are interested :
please Whatsapp +65-82494702
or respond via a PM
or send an e-mail with your contact number to
meridian-506@hotmail.com
Thank You for viewing my ad. Smile
Last edited by meridian-506 on Tue Feb 19, 2019 12:21 pm; edited 2 times in total (Reason for editing : Cosmetic Changes)
meridian-506
Number of posts : 952
Re: Shunyata Research HYDRA 6 Power Conditioner with a Matching Shunyata Research HYDRA HC VTX 20Amp Power Cable from USA
Post by meridian-506 on Tue Feb 19, 2019 12:26 pm
No Trades, Thank You.
Bring Up My Post.
meridian-506
