Mark Levinson No.38S Pre-Amplifier & No. 332 Power Amplifier
Post by superfi on Tue Feb 12, 2019 6:22 pm
On sale here is the combination of the awesome Mark Levinson No. 38S Pre-amplifier (which is an upgraded design and much more expensive that it's previous 38 model) and the Dual Mono No. 332 Power amplifier with  200 watts/channel, doubling it's output at 4 Ohms & 800 watts/channel down to 2 Ohms.  This is serious power to drive the most difficult of loudspeaker loads. As a combination, the sonics are a sheer delight to listen to: great sound staging with images way beyond the confines of the loudspeakers; cavernous depth with tactile placements of singers and instruments; the music reproduced by this high-end set up is extremely refined, gentle, and with great image palpability. These are the hallmarks, among others, of high-end hifidelity!
(Mark Levinson No.38S Pre)
(Mark Levinson No.332 Power Amp)
No. 38S Pre-Amplifier
Gain: –73.1dB to +18.9dB plus "off."
Inputs: two stereo balanced (XLR), four single-ended (RCA), one MarkLevinson Link communications connector, one 1/8" minijack for external IR repeater.
Outputs: one balanced stereo main output pair (XLR), one single-ended stereo main output pair (RCA), two stereo record outputs (RCA), one MarkLevinson Link communication connector. Input impedance: 100k ohms.
Weight: 35 lbs (16kg).
No. 332 Dual Mono Power Amp:
200 w/ch continuous rms power @ 8Ω
400 w/ch continuous rms power @ 4Ω
800 w/ch continuous rms power @ 2Ω
Weight: 150 lbs. (68.2kg)
Power consumption: 325W (±5%) at idle, 200W (±5%) in standby
Both items are in excellent condition, well kept and carefully used by the owner in a smoke-free air-conditioned environment.
Asking for RM30,000 for the combination
Contact: Greg at 03-76104466 or 011-39300083 to deal or to set up an appointment for audition
superfi
superfi
Number of posts : 497
