Yamaha YAS-706 Powered Sound Bar Without Subwoofer
Yamaha YAS-706 Powered Sound Bar Without Subwoofer Empty Yamaha YAS-706 Powered Sound Bar Without Subwoofer
Post by stylelaser.com.my on Sat Mar 02, 2019 12:08 pm
Yamaha YAS-706 Powered Sound Bar Without Subwoofer Brand New. Now Selling At RM2,399. Free Shipping Within West Malaysia.
       Yamaha YAS-706 Powered Sound Bar Without Subwoofer Es_353
Escape into your favorite movies and TV shows like never before. This high-performance sound bar delivers the fidelity, depth and spline-tingling sonic details that put you in the middle of the action. MusicCast provides versatile wireless connectivity (Wi-Fi®, Bluetooth®, AirPlay® and Spotify Connect), access to streaming services and music libraries, and wireless multiroom audio control using a simple app on your smartphone or tablet.
  • Clear, dynamic and spacious sound
  • HDMI® inputs with 4K Ultra HD pass-through for best performance
  • Slim design fits in front of TV or can be wall-mounted
  • Versatile connectivity – Wi-Fi, Bluetooth, AirPlay and Spotify Connect
  • MusicCast provides access to Pandora®, Napster, TIDAL, Deezer, Spotify, SiriusXM Internet Radio and more
  • Add audio in up to 9 additional rooms with MusicCast
YAS-706 透過輕巧時尚的機身達到優異的臨場感以及環繞音,支援MusicCast,將擴增你的音響系統娛樂。
  • AIR SURROUND XTREME 提供強勁 7.1 聲道環繞音
  • MusicCast 提供每個房間的音樂享受
  • 總瓦數285 W(中置單元210 W+超低音75 W)
  • 無線超低音
  • 內建超低音 x 2, 低音反射孔 x 2 提供更深沉的超低音 (中置單元)
  • HD audio 格式解碼(Dolby® TrueHD, DTS-HD®)
  • 支援 192 kHz / 24-bit 高解析音訊播放 (Flac / WAV / AIFF)
  • Bluetooth® 提供無線音樂串流
  • 支援 Bluetooth 輸出,提供 YAS-706 與其他支援藍牙的產品配對。
  • AirPlay® 提供由Mac, PC, iPod®, iPhone®, iPad®串流音樂的功能
  • 支援網路電台及多種音樂串流服務
  • HDMI® (2 進/1 出) 搭載 4K60p 直通與 HDCP2.2
  • 聲音模式 (MUSIC, MOVIE, SPORT, GAME and TV)
  • 人聲清晰模式 (Clear Voice) 讓人聲清晰易聽
  • 藍牙功能的壓縮音樂增強(Compressed Music Enhancer)模式
  • 簡易操作的APP(MusicCast CONTROLLER)
  • 易懂的螢幕菜單顯示
  • 彈性的安裝方式:可壁掛
  • Control4 認證
Dynamic and Enveloping Sound
來自任何地方的強勁環繞音
Yamaha YAS-706 Powered Sound Bar Without Subwoofer A67202F67D8E414CA19A64BD8CBDB66D_12074_900x361_de0f1da4d8a0f972b11a1e76945d4b70
Employing eight speaker drivers and two bass reflex ports, the YAS-706 delivers immersive and well-balanced sound. The included wireless subwoofer works with subwoofer drivers built into the bar to produce remarkably rich, deep bass. Sound equalization is automatically adjusted for tabletop or wall mount orientation.
YAS-706 內含2個超重低音單體,提供強勁低音輸出,再加上獨特的低音反射孔更加延展低音效果。YAS-706 也搭載兩個中型尺寸的低音單體與高音單體,傳達良好平衡的中音域與清晰的高音音調。不管是水平、垂直或是壁掛於牆上,都可以接收到強大的低音輸出與大迫力的動態環繞體驗。
Triple Amplifier Drive
三擴大機驅動
Yamaha YAS-706 Powered Sound Bar Without Subwoofer 22E44D7CDE754BD18A3BCC12F9BA8A77_12074_500x266_c60ac37562b039d03999ca3cf982e8c8
The YAS-706 features separate amps for treble, midrange and bass frequencies. These dedicated amps reduce interference, allowing the sound bar to produce exceptionally clear sound.
YAS-706 的中置單元內建三個擴大機單體,具有單獨的高音、中音與低音擴大器。這樣的結構減少擴大機間的干擾,達到容易聆聽的乾淨聲音。
AIR SURROUND XTREME Provides Superior Virtual Surround
Yamaha-exclusive AIR SURROUND XTREME reproduces virtual 7.1-channel surround sound with excellent imaging and rich presence far superior to other virtual surround technologies. You’ll experience an extremely realistic and impressive sound field with clear dialogue in the front and dynamic sound action effects from behind.
AIR SURROUND XTREME 提供廣闊的家庭劇院體驗
Yamaha 在Soundbar的環繞聲音系統 AIR SURROUND XTREME的進一步發展,Yamaha新增了獨特的24 kHz HRTF(頭部頭部相關傳輸函數) 環繞科技。它讓你能夠聽見來自前方的清晰對話或是其他聲音、來自側方以及後方的其他聲道特定聲音以及環繞你的聲音的平順移動感。你不會相信聲音是來自於同一個Soundbar!
Yamaha YAS-706 Powered Sound Bar Without Subwoofer 772EC5AA7EAB4C2CA8F36B200FC2D4EC_12074_1200x480_75fc2124efff7ad1266e7f488eed661a
Five Sound Programs
The YAS-706 offers a choice of five sound programs that enhance different types of content to give you a greater sense of “being there.”
Yamaha YAS-706 Powered Sound Bar Without Subwoofer F1_740x300_98869fdc4ba38e7768a55fa220a4413c
Ultra Slim and Wall Mountable
At less than 3-inches tall, the YAS-706 fits neatly in front of most TVs or can be placed on the shelf of a TV stand. Its flexible orientation and built-in keyholes make it easy to wall mount with a sleek look that perfectly complements your TV.
時尚機身與美化空間的安裝
圓弧形的機身設計以及側邊的黑色電鍍,符合家中的裝潢擺設。中置單元可以放置於架上或是壁掛,你可以輕鬆選擇你喜愛的安裝方式。搭配簡易設計的超低音,YAS-706自然地融入你家中的空間
Yamaha YAS-706 Powered Sound Bar Without Subwoofer 6B7BE137BAF34E69AEB30B43C343C8FE_12074_1200x431_140b4b14a858a845502de302e1f052f4
Wireless Subwoofer for Flexible Placement
The subwoofer eliminates the need to connect cables, so setup and placement are faster and easier. This convenient subwoofer delivers powerful, high-quality bass sound.
無線超低音提供彈性安裝
此款的無線超低音無須連接線材,對於安裝以及擺設都會更加快速與容易。此超低音便利卻能傳達強勁、高品質低音。
Yamaha YAS-706 Powered Sound Bar Without Subwoofer 1771B112C05C4452BAD3EF88AEAEC79A_12074_1200x491_ff767089403710cbcbf298ae373c1916
MusicCast
Access all of your music with a simple app and wirelessly stream it throughout your home using your existing Wi-Fi® network.
  • Stream it all. Listen to Pandora®, Spotify, Napster, SiriusXM Internet Radio, TIDAL, Deezer, thousands of free internet radio stations and the music stored on your smart devices and computers.
  • Wireless connectivity. All MusicCast products are fully loaded with Wi-Fi, Bluetooth® and AirPlay®.
  • Expand to a whole home audio experience. When you’re ready, add MusicCast wireless speakers, sound bars or other devices in up to 9 other rooms and listen throughout your home.
  • No wires, easy installation. By using MusicCast, you don't need to fuss with placing wires through walls into other rooms.
MusicCast
MusicCast是新的網路音訊革命技術,可以單獨或一起使用。只需要透過一個簡單易用的App就能控制。依照你的需求單獨會搭配soundbar、無線喇叭、AV接收擴大機或HiFi裝置擴大你的MusicCast系統。來自Yamaha全新的MusicCast系統,適合所有人、所有地方。
享受所有的音訊來源
MusicCast使用高效能無線網路傳送音訊,他可以從你的智慧型手機、電腦或NAS串流音樂至家中其他MusicCast裝置,還可以分享連接至YAS-706例如電視或藍光播放器的外部裝置。透過藍牙連線的智慧型手機或平板電腦也可以透過MusicCast串流播放音樂至多個空間。
Yamaha YAS-706 Powered Sound Bar Without Subwoofer Avr_enspire-musiccast2_35ade05fecf3ff8a5bf11e219b299427Learn more about MusicCast wireless multiroom audio
Stream via Bluetooth or AirPlay®
You can hear all the music sources from your smartphone via Bluetooth or AirPlay connection. You can play music from music apps, radio apps, or video hosting services.
從Bluetooth®以及AirPlay®串流音樂
你可以由你的智慧型手機透過無線Bluetooth®或AirPlay®連結傳送音樂.你也可以由音樂App,電台App或是像YouTube™等的視訊託管服務中傳送音樂。
Yamaha YAS-706 Powered Sound Bar Without Subwoofer 3BA0C9AEF0C34D18BC24A0C9DF8B66D2_12074_1200x460_2956db1ef7d3b5201da01174e2c53544
Bluetooth Output for Convenient Music Streaming
The YAS-706 is equipped with the latest Bluetooth wireless technology, making wireless operation more convenient than ever. With Bluetooth, stream music from the YAS-706 to headphones, for private listening, or to speakers.
方便音樂串流的藍牙音訊輸出
YAS-706具備最新最方便的藍牙技術。你可以透過YAS-706傳送音樂到藍牙耳機獨自聆聽,或者到藍牙喇叭上播放。
Yamaha YAS-706 Powered Sound Bar Without Subwoofer 35FE48B17C2742478364F8B89E78CF8E_12074_1200x319_b69bd1172378986f4b6aeb2a927d9ee6
壓縮音樂增強裝置
Yamaha YAS-706 Powered Sound Bar Without Subwoofer 5B53A009D04A4720893568FC3F177AD7_12074_400x203_4a9a3a6508ec6be842e26bf82b38b3e2
The Compressed Music Enhancer restores frequency response lost during digital compression, so your music sounds the way it should. It is optimized for Bluetooth audio transmission for vivid, lively sound quality during wireless playback. The function engages automatically when a compressed source is played.
音樂壓縮增強器可以恢復音樂在壓縮過程中所減損的頻率響應,讓音樂聽起來如同原本該有的音質。它適用於藍牙音樂傳輸的壓縮內容,帶給你生動、有生命力的聲音品質。當壓縮音樂播放時,此功能會自動運作。
HD Audio Decoding
Yamaha YAS-706 Powered Sound Bar Without Subwoofer 3FDEDE4BBEB144FB96C9D7E33A03E36B_12074_400x108_2e65d4ee02aaf4ab42d01754e7e20361
The YAS-706 decodes HD Audio signals to ensure that you hear the best possible sound from Blu-ray Disc™ players, as well as from other digital sources.
HDMI® Terminals with 4K Ultra HD Support
The YAS-706 has two HDMI input terminals and one HDMI output terminal, and supports 4K/60p video signal pass-through. It’s also compatible with HDCP 2.2 digital copy protection. This gives it extensive expandability, so you’ll be able to use it far into the future.
HDMI®端子支援4K Ultra HD
The YAS-706 has two HDMI® input terminals and one HDMI® output terminal, and supports 4K/60p video signal pass-through. It’s also compatible with HDCP2.2 digital copy protection. This gives it extensive expandability, so you’ll be able to use it far into the future.
Yamaha YAS-706 Powered Sound Bar Without Subwoofer 13C404DD9FE0456AADFE279F63D2CD48_12074_1200x426_ac81a0d11034e4a8a6632aed6914404d
Other Notable Features
・Clear Voice makes dialogue and narrations easy to hear.
・HDMI CEC feature lets you use your TV remote or set-top box remote to control volume.
・TV Remote Repeater allows commands from remote controls to reach your TV even if the TV’s IR sensor is blocked by the bar.
・Subwoofer output terminal allows for wired connection.
Yamaha Eco-Product
Yamaha YAS-706 Powered Sound Bar Without Subwoofer D0CCD25915174733B47DAD56771F1BC8_12074_240x139_759d97f4822c68499b4fae08f64e9967
With an advanced energy saving design, this product achieves a low power consumption of not more than two watts when in Network Standby mode.
     Yamaha YAS-706 Powered Sound Bar Without Subwoofer Es_148     Yamaha YAS-706 Powered Sound Bar Without Subwoofer Es_yas10
[th]YAS-706[/th][th]Front Surround System[/th][th]General[/th][th]Drivers[/th][th]Output Power[/th][th]Power Consumption[/th][th]Standby Power Consumption[/th][th]Dimensions (W x H x D)[/th][th]Weight[/th][th]Input / Output[/th][th]HDMI[/th][th]Digital Optical[/th][th]Digital Coaxial[/th][th]Analog Audio[/th][th]Subwoofer output[/th][th]HDMI[/th][th]4K Pass-through[/th][th]3D Pass-through[/th][th]ARC[/th][th]CEC[/th][th]Auto Lip-Sync[/th][th]Sound Technology[/th][th]Surround Technology[/th][th]Surround Mode[/th][th]Compressed Music Enhancer[/th][th]Bass Extended[/th][th]Audio Formats[/th][th]HD Audio Format Decoding[/th][th]Dolby TrueHD[/th][th]Dolby Digital Plus[/th][th]Dolby Digital[/th][th]Dolby Pro Logic II[/th][th]DTS-HD Master Audio[/th][th]DTS-HD High Resolution[/th][th]DTS Digital Surround[/th][th]DTS[/th][th]DTS 96/24[/th][th]File Format[/th][th]Connectivity[/th][th]Wireless Music Streaming[/th][th]Wi-Fi[/th][th]AirPlay[/th][th]Bluetooth Version/Profile[/th][th]Bluetooth Maximum Communication Range[/th][th]Wireless Subwoofer[/th][th]Ethernet[/th][th]Other Features[/th][th]On-Screen Display[/th][th]On-Screen Display Languages[/th][th]App Control[/th][th]TV Remote Repeater[/th][th]Learnig Function[/th]
(Center Unit) : Dual 5.5 cm (2-1/8”) woofers, Dual 7.5 cm (3") built-in subwoofers, Four 1.9 cm (3/4") tweeters, (Subwoofer) : 14 cm (5-1/2”) cone woofer
285 W total power: 210 W + 75 W subwoofer
(Center Unit) : 38 W, (Subwoofer) : 75 W
(Center Unit) : 0.3 W (HDMI control, LAN, Wi-FI, Wireless Direct, Bluetooth off), 2.5 W (HDMI control, Wireless Direct, Bluetooth on, LAN, Wi-FI off), (Subwoofer) : 1.5 W (Wireless)
(Center Unit) : 950 x 72 x 131 mm; 37-3/8” x 2-7/8” x 5-1/8”, (Subwoofer vertical): 295 x 297 x 307 mm; 11-5/8” x 11-3/4” x 12-1/8”
(Center Unit) : 5.4 kg; 11.9 lbs, (Subwoofer) 9.1 kg; 20 lbs
2 in / 1 out
1 in
1 in
1 in
Yes
Yes (50 / 60 Hz YCbCr=4:4:4, HDR, HDCP2.2)
Yes
Yes
Yes
Yes
AIR SURROUND XTREME
Music, Movie, Sport, Game, TV
Yes (for Bluetooth)
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
MP3, WMA, MPEG4 AAC, Apple LossLess(*1), WAV(*2), FLAC(*2), AIFF(*2) --- (*1) up to 96 kHz (*2) up to 192 kHz
Yes
Yes
Yes
(Version) Ver. 2.1 + EDR / A2DP, AVRCP; (Codec) SBC, AAC
10 m ; 33 ft (*without obstructions)
Yes
Yes
Yes
English, French, Spanish
Yes
Yes
Yes
Number of posts : 557
