B&W Bower & Wilkins DM602 England Standmount Stereo Speaker
B&W Bower & Wilkins DM602 England Standmount Stereo Speaker Empty B&W Bower & Wilkins DM602 England Standmount Stereo Speaker
Post by HiFiLab on Wed Mar 06, 2019 9:40 am
SOLD
Made In England
D M™6 0 2
Stand- mount/Bookshelf loudspeaker system
Product Summary
● The DM 602 is twice the size of the small DM 601 and incorporates the larger 180mm,
(7-inch) Kevlar® mid/bass unit. The Kevlar® cone is modelled on the cone in the Silver
Signature loudspeaker - a proven design that eliminates the build-up of standing waves for
a more authentic reproduction of recorded sound.
● As well as the 600 Series standard features the DM 602 also boasts flared reflex ports
which dramatically increase bass efficiency and power handling. Added to this is rounded profile zinc clamping rings which connect the drivers to the cabinet and minimise the effect
of diffraction around the drive unit as sound waves travel out across the face of the speaker cabinet.
The DM 602 is recommended for shelf or stand mounted applications and is ideally suited
as front channel speakers in a Home Cinema system.
D e s c r i p t i o n
Drive units : 2 way vented-box system
                  1 x 25mm metal dome - high fre q u e n c y
                  1 x 180mm Kevlar® cone -bass / midrange
Frequency re s p o n s e : 52Hz – 20kHz ± 3dB on reference axis
Sensitivity : 90dB spl (2.83V 1m)
Nominal impedance : 8 ohms (minimum 4.3 ohms)
Power handling : 25W –120W into 8 ohms on unclipped programme
D i m e n s i o n s
Height: 490mm Width: 236mm
Depth: 306mm
Finishing  : Cherrywood vinyl
Grille: Black Cloth
Kevlar®: B&W developed and patented the method of using Kevlar® for
loudspeaker cones to reduce unwanted standing waves. DuPont originally
created Kevlar® for use in bulletproof vests.
HiFiLab
Number of posts : 2541
B&W Bower & Wilkins DM602 England Standmount Stereo Speaker Empty Bump
Post by HiFiLab on Fri May 03, 2019 9:09 am
Up
HiFiLab
