REL T9 Subwoofer (used) SOLD
2 posters
Standing at the top of the REL T-Series, the T9 packs mighty punch.
Active and passive cones
Inside its compact cabinet, the REL T9 uses a downward- firing, active 10" bass cone paired with a forward-firing, passive 10" cone. Together these cones offer a surface area equivalent to a 15" bass cone. What this means for the sound is deep, effortlessly powerful bass that's loud enough to get your household an ASBO!
300W of bass power
Keeping the downward-firing bass cone under tight control is REL's tried and tested 300W Class A/B amplifier. REL has used traditional Class A/B transistor design and although more expensive to produce, the upshot is class-leading attack and control. Unlike lesser subs, the bass starts and stops exactly when it should with superb agility and no 'overhang'. An extra-large heatsink on the rear keeps the T9 cool, for years of reliable performance.
Separate inputs for hi-fi and home cinema
Traditionally, the problem with using a sub with both home cinema and music systems is the difference in presence required. Films often require the sub to be turned up for the greatest thrills, while music demands a more subtle approach. With the REL T9 you not only have separate inputs for high and low level sources you also have separate level controls for stereo and LFE .1 surround, so you get the ideal levels for both hi-fi and AV.
High quality finish
Boasting REL's legendary build quality and finish, the T9 has to be one of the most attractive-looking subwoofers in its class. With its deep, piano gloss finish and contrasting aluminium feet, this is one subwoofer you'll be proud to have on show.
For deep, effortless bass with musicianship to match, the REL T9 strikes the perfect balance.
Conditions: 7/10 (USED)
Last edited by choyaudiovisual on Sat Jan 18, 2020 4:14 pm; edited 1 time in total
- Number of posts : 5622
Re: REL T9 Subwoofer (used) SOLD
Very Powerful Subwoofer, must buy if you're afford
Mian- Frequent Contributor
- Number of posts : 216
Registration date : 2012-06-05
» Auralex Subdude subwoofer platform and QED Reference subwoofer cable (sold)
» Subwoofer -NHT10 Active subwoofer(sold)
» Rel T3 subwoofer (sold)
» NHT Ten subwoofer (Used) SOLD
» SVS SB-2000 Ported Subwoofer - Profesional Subwoofer Calibration
