Optoma HD92 LED Full HD 3D Projector with Optoma ZF2100 3D Glasses(USED)
Optoma HD92 LED Full HD 3D Projector with Optoma ZF2100 3D Glasses(USED) Empty Optoma HD92 LED Full HD 3D Projector with Optoma ZF2100 3D Glasses(USED)
Post by choyaudiovisual on Fri Mar 29, 2019 5:35 am
Optoma HD92 LED Full HD 3D Projector with Optoma ZF2100 3D Glasses(USED) Img_3020Optoma HD92 LED Full HD 3D Projector with Optoma ZF2100 3D Glasses(USED) Img_3019
Optoma HD92 LED Full HD 3D Projector with Optoma ZF2100 3D Glasses(USED) Img_3110
Optoma HD92 LED Full HD 3D Projector  Optoma ZF2100 3D Glasses (1 PAIR) (USED)
*lamp remain 18,000 hours
HD92
LED Home Cinema projector
  • Enhanced image quality – 2nd generation
  • Fantastic Full 3D 1080p image quality made ultra-smooth with PureMotion
  • Total control – Advanced Colour Management System CMS+
  • Easy Installation – Lens shift & shorter throw ratio
Superior Performance
The HD92 incorporates our second generation LED light source. The new LEDs further improve the image performance with consistent, breath-taking, perfectly balanced colours from the first time, every time and for years to come. Whether you just fancy a relaxed movie night or immersing yourself in adrenaline-pumping 3D, the HD92 is the perfect choice for recreating the big-screen experience.
Superior LED Technology
Powered by 3 x LED’s, the HD93 delivers enhanced image quality with a wide colour gamut, superior colour saturation and outstanding brightness using separate Red, Blue and Green LEDs to produce intense yet accurate colours. Advanced switching of these LED’s provides increased image stability that rivals the performance of 3 chip DLP projectors.
Performance is nothing without consistency. Unlike traditional lamp technology the LED illumination in the HD93 provides consistent brightness and colour performance, so maintaining its out-of-the-box image quality throughout its lifetime and saving you from costly calibrations.
The lamp-less LED illumination engine that powers the HD93 does not require the inconvenience and cost of frequent lamp changes to maintain its optimal performance. It also doesn’t need lengthy warm-up and cool down cycles before and after every viewing due to its almost instant start up and shut down times.
Enormous Pure Engine Generation
• Ultra Detail — A unique image processing algorithms and a dedicated image detail processor gives the impression of extremely high image quality without the artifacts associated with moving pixel systems. It analyzes the difference of characteristics and scene of each frame, then creates and combines extra 36 new frames with original 24 frames into a new 60 frames / Sec dynamic images, to create a “124 Mega extreme Pixel” image.
• Pure Motion–The technology provides advanced motion control processing that eliminates motion blurring or image judder, even in high-speed action sequences and 3D modes.
• PureColor–This mode makes it possible for the projector to reproduce more detailed shades of color; to provide vivid, balanced color for vibrant, natural looking images.
Precise color
On start-up the HD93 colour and white point and automatically calibrated to ensure the most accurate and consistent colour reproduction over its entire lifetime.
Color Management System (CMS)
Display accurate life-like colours to best match your viewing environment. This unique feature provides you with the flexibility to fine-tune the colour settings to the Rec. 709 standard for optimal precision.
Dynamic Black
Dynamic Black IV smoothly adjusts the lamp output automatically, based on the brightness information of each frame; to create a stunning contrast ratio. Bright scenes are crisp and clear, while dark scenes remain detailed with deep blacks which gives exceptional light and shade detail.
Conditions: 9/10 (USED)
Price: RM3950 inclusive postage to West Malaysia
Whatsapp: Choy 012-5685484
Last edited by choyaudiovisual on Tue Jan 14, 2020 4:51 am; edited 2 times in total
Number of posts : 1039
Optoma HD92 LED Full HD 3D Projector with Optoma ZF2100 3D Glasses(USED) Empty Re: Optoma HD92 LED Full HD 3D Projector with Optoma ZF2100 3D Glasses(USED)
Post by choyaudiovisual on Thu Apr 18, 2019 4:26 am
Post by choyaudiovisual on Fri May 17, 2019 6:55 am
Post by choyaudiovisual on Tue Jun 11, 2019 4:37 am
UP
Post by choyaudiovisual on Thu Jul 04, 2019 4:18 am
Post by choyaudiovisual on Tue Jul 23, 2019 9:16 am
Post by choyaudiovisual on Tue Aug 27, 2019 4:28 am
Post by choyaudiovisual on Wed Sep 18, 2019 4:18 am
Post by choyaudiovisual on Fri Oct 11, 2019 4:05 am
Post by choyaudiovisual on Wed Nov 13, 2019 6:02 am
Post by choyaudiovisual on Fri Dec 06, 2019 4:35 am
Post by choyaudiovisual on Tue Jan 14, 2020 4:51 am
