PAD - Purist Audio Design Luminist Revision Genesis Phono Cables - 1m pair
PAD - Purist Audio Design Luminist Revision Genesis Phono Cables - 1m pair Empty PAD - Purist Audio Design Luminist Revision Genesis Phono Cables - 1m pair
Post by raymond88 on Fri Apr 12, 2019 1:25 am
Item: PAD - Purist Audio Design Luminist Revision Genesis Phono Cables - 1m pair
Condition: 8.5/10. Item is in near MINT condition. One owner. Lightly used. Selling due to upgrade to another PAD.
Price: sold
[ltr]Purist Audio Design Luminist Revision Genesis - 1.0m / RCA or XLR[/ltr]
[ltr]PAD - Purist Audio Design Luminist Revision Genesis Phono Cables - 1m pair Image.aspx?width=350&filename=gen_rca_shotc
The Genesis series introduces cables with detailed musical sound at a low price. Over the past 26 years, Purist Audio Design has never stopped improving and expanding wire technology.
Working with advanced computer models, they were able to construct a cable design employing finely stranded alloy conductors of copper and gold. The design for the Genesis interconnects makes use of these alloys with the primary conductors encased in a santoprene dielectric. The design for the Genesis speaker cables also uses the same alloy design for the conductors, and utilizes a PVC dielectric. As with all Purist Audio Design cables, the custom designed connectors function harmoniously with the materials in the cable.
The Genesis cables give a level of performance that is unheard of, for its price point, in the Audiophile community!
PAD - Purist Audio Design Luminist Revision Genesis Phono Cables - 1m pair Image.aspx?width=200&height=200&filename=gen_bal_shotc
Click image to enlarge
Conductors: OFC
Metals: Cu
Shielding: Braid 98%
Dielectric Material: Santoprene
Gauge (effective): 24 AWG
Dampening Material: N/A
Capacitance: 45 pF/FT (pin to shield)
Resistance: 0.0842 O/m (conductor)
Estimated Break-In Time: 150 Hours
Cable Diameter: 5/16" OD
Connector Type: Gold RCA / Gold 3-Pole XLR
Material Treatment: Triple (3x) Cryomag©
PAD - Purist Audio Design Luminist Revision Genesis Phono Cables - 1m pair Pad112
PAD - Purist Audio Design Luminist Revision Genesis Phono Cables - 1m pair Pad212
https://www.thecableco.com/genesis-luminist-interconnect-pair.html
http://recordclean.com.au/purist-audio-design-genisis-luminist-revision-interconnect-cable.html
https://absolutehiend.com/index.php/brands/purist-audio-design/cables/venustas-ac-power-cord.html
All my items can be found here:[/ltr]
[ltr]http://www.hifi4sale.net/st/raymond88[/ltr]
Thank you[/ltr]
Number of posts : 4883
PAD - Purist Audio Design Luminist Revision Genesis Phono Cables - 1m pair Empty Re: PAD - Purist Audio Design Luminist Revision Genesis Phono Cables - 1m pair
Post by raymond88 on Thu Apr 18, 2019 10:53 am
Post by raymond88 on Wed May 08, 2019 1:47 pm
