Q Acoustics 7070Si Subwoofer (New)
Q Acoustics 7070Si Subwoofer (New) Empty Q Acoustics 7070Si Subwoofer (New)
Post by yong zhen jung on Mon Apr 15, 2019 5:48 pm
Q-Acoustics 7070Si
Active Subwoofer
Q Acoustics 7070Si Subwoofer (New) 7070si10
Key Features
  • The 7000Si Subwoofer cabinet is compact cuboid shape, where the design focus is on getting the biggest sound from the smallest, best-looking enclosure and with Q Acoustics the focus is always first and foremost on getting the very best sound quality. The 7000Si will ensure you get the very best explosive bass from your 5.1 or 7.1 system.
  • Enclosure Typey: Infinite Baffle, Enclosure Materialy: MDF, LF Unitsy: 8" High-Excursion Driver, Power Handlingy: 150W Class-D, Frequencyy: 35Hz - 200Hz, Overall Dimensions (H x W x D): 320 x 460 x 198(mm), Weighty: 13.8 Kg, Power: 100V-240V 50/60Hz
Providing Explosive Bass to Your Cinema Nights
Active Subwoofer
Q Acoustics 7070Si Subwoofer (New) 7000s-10
Precision Drivers, Detailed Accuracy
This compact Subwoofer has a completely concealed 200mm driver driven by 150watt class D amplifier, capable of reproducing the speed and 'twang' of a double bass as it is the prolonged, earth moving rumble of a 'block buster' explosion so you hear whatever you are listening to, in all its glory. The controls are hidden behind a magnetic hatch except for those that are most needed, volume and phase adjustment, which discretely protrude through the cover for easy access.
Place the Bass
The Subwoofer driver is located internally in it's cabinet and is completely concealed. It faces a fixed baffle and the sound vents through a narrow grille on the top and both sides. This configuration makes the Subwoofer less sensitive to room placement, so it can be more easily hidden away in the room making the system even more discrete. The Subwoofer comes with spikes or rubber feet for stability and is available in White and Black. An optional Wall Bracket is available.
Specifications:
  • Enclosure Materialy: MDF
  • LF Unitsy: 8" High-Excursion Driver
  • Power Handlingy: 150W Class-D
  • Frequencyy: 35Hz - 200Hz
  • Overall Dimensions (H x W x D)y: 320 x 460 x 198(mm)
  • Weighty: 13.8 Kg
  • Power: 100V-240V 50/60Hz
Conditions : New in Box.
Warranty    : 1 Year
Price          :RM1899 with postage within Peninsular Malaysia.
Whatapp    :Jung 018-4604369
yong zhen jung
Number of posts : 15
Registration date : 2018-11-20
