WireWorld Silver Electra 5.2 Power Cables - 1.5m
WireWorld Silver Electra 5.2 Power Cables - 1.5m Empty WireWorld Silver Electra 5.2 Power Cables - 1.5m
Post by raymond88 on Mon Apr 15, 2019 10:29 pm
Item: WireWorld Silver Electra 5.2 Power Cables - 1.5m
Condition: 8.5/10. Item is in excellent condition.
Price: RM1500 or swap/topup
WireWorld Silver Electra 5.2 Power Cables - 1.5m Ww111
WireWorld Silver Electra 5.2 Power Cables - 1.5m Ww211
WireWorld Silver Electra 5.2 Power Cables - 1.5m Ww311
Wireworld has taken a fresh look at the power cord, and in so doing has produced a line that runs counter to conventional wisdom. The five models in the 52 Series bear little physical relation to the heavy and unwieldy things audiophiles are used to. Wireworld’s AC cords are defiantly lightweight and flat in profile, and pliable enough to negotiate corners—critical when hunting for outlets. I listened to two of the new models—the secondfrom- the-top Silver Electra ($700) and the entry-level Stratus ($100).
The Silver Electra uses OCC (Ohno Continuous Casting) silver-clad copper conductors and silver-clad brass contacts in a composite insulation, which was chosen over single-material insulation for its ability to absorb high-frequency energy. As David Salz, president and chief designer for Wireworld, explains, the flat geometry reflects a coiled conductor design which “exploits inductive and capacitive filtering effects.” In other words, the point is to pass only the 50/60Hz AC power signal, while attenuating other frequencies to prevent line noise and harmonics from “infiltrating the component’s power supply.”
The Silver Electra has a balanced midrange, a rich bass response that’s solid and well defined in pitch but not overly controlled, and excellent dynamics. Backgrounds and silences between notes are as quiet as I’ve experienced. The Silver Electra is mellow and dark in overall character; sibilance is kept in check; and hard transients are lightly rounded rather than honed to a razor edge. As a result, when a player’s hand glides up the fingerboard of a string bass the metallic growl of the strings is not quite as pronounced. Soundstaging is unerringly neutral, neither laid-back nor forward. However, during Patricia Barber’s “Hunger” from Mythologies [Blue Note], the high-octane rhythm section wasn’t presented with quite the pinpoint imaging I expect from this track.
The Silver Electra elegantly balances the qualities of two of my favorite power cords—delivering the hard-charging dynamism of the Virtual Dynamics Reference and the naturalistic spatial qualities of the Kimber Palladian. Although it doesn’t quite capture the full impact of the snare from Elton John’s “Someone Saved My Life Tonight” on Captain Fantastic and the Brown Dirt Cowboy [Island], or the sustained piano notes during Tom Waits’ “Take It With Me” on Mule Variations [Anti/Epitaph], in both instances the differences are subtle. In keeping with the Silver Electra’s slightly darker personality, cymbals suggested a different flare pattern and pitch with the Wireworld than with the Kimber—the Wireworld imparting a broader spread and slightly deeper tonality, while the Kimber seeming to be pitched a little higher and crisper, with a more compact spread.
See my other power cords here:
Wireworld Stratus 7 Power Cable - 1.5m
NBS Monitor 0 Power Cable - 2m
XLO Reference 2 Power Cable - 1.5m
Number of posts : 5025
WireWorld Silver Electra 5.2 Power Cables - 1.5m Empty Re: WireWorld Silver Electra 5.2 Power Cables - 1.5m
Post by raymond88 on Mon Apr 22, 2019 9:37 am
Post by raymond88 on Wed May 08, 2019 1:41 pm
Post by raymond88 on Wed May 15, 2019 1:41 pm
Post by raymond88 on Sun May 26, 2019 1:22 am
Post by raymond88 on Sat Jun 01, 2019 5:43 pm
Post by raymond88 on Sun Jun 09, 2019 2:13 am
Post by raymond88 on Sat Jun 15, 2019 4:58 pm
Post by raymond88 on Sat Jun 29, 2019 3:18 pm
