Rega MAIA 3 Audiophile Power Amplifier (used) - RM1650
Rega MAIA 3 Audiophile Power Amplifier (used) - RM1650 Empty Rega MAIA 3 Audiophile Power Amplifier (used) - RM1650
Post by hwee65 Jan2019 on Wed Apr 24, 2019 5:14 pm
Rarely available audiophile high performance power amplifier  Very Happy Smile Cool Exclamation
Whatapps only : Mr Tan - 011 5169 5393
Asking price :  RM2650  No negotiable,
now reduced to No RM2350  bounce  RM2150  bounce  RM1850 RM1650
[size=34]REGA MAIA 3[/size]
The Rega Maia 3 is an 85 watt per channel high performance audio power amplifier housed in the Rega custom built extruded aluminium case. The amplifier has a fully protected output stage with DC and electronic thermal protection, and a power monitor for both transformers. High quality Evox capacitors have been used in the signal path throughout.
Rega MAIA 3 Audiophile Power Amplifier (used) - RM1650 20190413
Rega MAIA 3 Audiophile Power Amplifier (used) - RM1650 20190415
Rega MAIA 3 Audiophile Power Amplifier (used) - RM1650 20190414
The Maia 3 uses the Rega "common base driver stage" circuit design. Rega used circuit modelling and listening tests to design this amplifier resulting in superb reliability and exceptional sound quality. Sanken 200w output transistors are used in a high current output stage and will drive the most awkward of speaker systems.
Rega MAIA 3 Audiophile Power Amplifier (used) - RM1650 20190417
Rega MAIA 3 Audiophile Power Amplifier (used) - RM1650 20190416
Rega MAIA 3 Audiophile Power Amplifier (used) - RM1650 20190418
The power supply uses two generously rated toroidal transformers with 28,200mF of parallel connected smoothing capacitors, which will provide enough current to drive the hardest of loads:
[*]85w RMS per channel into 8W
[*]Rega Custom built extruded aluminium case
[*]Dual Toroidal transformer power supply
[*]200w Sanken output transistors
[*]High thermal efficiency heat sink
[*]System compatible with a gain of 28dB
[*]Full flexibility within the range
[*]BI-Amp upgrade for the Rega Mira amplifier
[*]Forms a pre-power system with the Rega Cursa pre-amplifier or pair with any high quality pre-amplifier
Last edited by hwee65 Jan2019 on Sat Jun 22, 2019 1:46 pm; edited 4 times in total (Reason for editing : price reduction)
hwee65 Jan2019
Number of posts : 13
Registration date : 2019-01-22
Rega MAIA 3 Audiophile Power Amplifier (used) - RM1650 Empty Re: Rega MAIA 3 Audiophile Power Amplifier (used) - RM1650
Post by hwee65 Jan2019 on Sat Jun 22, 2019 2:01 pm
hwee65 Jan2019
