Mark Levinson Pre & Power
On sale here is the matching combination of the Mark Levinson Pre and Power - specifically the No. 38S Pre-amplifier and the Dual Mono No. 332 Power amplifier with 200 watts/channel, doubling it's output at 4 Ohms & 800 watts/channel down to 2 Ohms. As a combination, the sonics are a sheer delight to listen to: great sound staging with images way beyond the confines of the loudspeakers; cavernous depth with tactile placements of singers and instruments; the music reproduced by the set up is extremely refined, gentle, and with great image palpability. These are the hallmarks, among others, of high-end hifidelity!
(Mark Levinson No.38S Pre)
(Mark Levinson No.332 Power Amp)
No. 38S Pre-Amplifier
Gain: –73.1dB to +18.9dB plus "off."
Inputs: two stereo balanced (XLR), four single-ended (RCA), one MarkLevinson Link communications connector, one 1/8" minijack for external IR repeater.
Outputs: one balanced stereo main output pair (XLR), one single-ended stereo main output pair (RCA), two stereo record outputs (RCA), one MarkLevinson Link communication connector. Input impedance: 100k ohms.
Weight: 35 lbs (16kg).
No. 332 Dual Mono Power Amp:
200 w/ch continuous rms power @ 8Ω
400 w/ch continuous rms power @ 4Ω
800 w/ch continuous rms power @ 2Ω
Weight: 150 lbs. (68.2kg)
Power consumption: 325W (±5%) at idle, 200W (±5%) in standby
Both items are in excellent condition, well kept and carefully used by the owner in a smoke-free air-conditioned environment.
Asking for RM30,000 for the combination ono. Separate item sales can be considered.
Contact: Greg at 03-76104466 or 011-39300083 / George 012-2955266 to deal
superfi- Dealer\Reseller\Trader\Service Provider
- Number of posts : 520
» Mark Levinson ML 23 power amp
» Mark Levinson ML3 power amp (Used)
» mark levinson 27.5 power amp (used)
» Mark Levinson No.23 power amp
» Mark Levinson No 23 power amp (Used)
