Sun Audio SV-6L6SX Int Tube Amp (Used)
Sun Audio SV-6L6SX Int Tube Amp (Used) Empty Sun Audio SV-6L6SX Int Tube Amp (Used)
Post by samhiew2000 on Tue May 07, 2019 2:23 pm
collector item
condition:8/10 (like new)
good working
photos taken are actual item
can test functionality after agreeing price
RM 4600
COD : Johor Bahru
whatsapp : sam  019 7723676
SV-6L6SX 是日本 SUNAUDIO 最新推出的型號,看來是以此機取代已經生產近三十年並已停產的兩款舊機種,分別是 VT-6V6SE 及 SV-EL34。這款機所採用的功率管6L6GC能提供 6.5瓦的輸出,比6V6 4.5瓦高出近50%,而只略低於EL34的8瓦輸出而已。線路方面與SV-EL34差不多一個模様,差別只在於陰極及負回輸電阻的數值吧了。
Sunaudio has recently introduced a new model SV-6L6SX to replace the old model SV-6V6SE and SV-EL34 which had been in the product line for more than twenty years. The use of 6L6GC tube is a very good choice since it has an output power of 6.5W which is nearly 50% more than what we get from 6V6 (4.5W)and come close to the 8 watts output from EL34. The circuit construction remains nearly the same as the SV-EL34 with only some minor charge in the value of feedback resistors.
Sun Audio SV-6L6SX Int Tube Amp (Used) 59375710
Sun Audio SV-6L6SX Int Tube Amp (Used) 59739610
samhiew2000
Number of posts : 112
