Epos (sold)
Epos (sold)
Traditionally the core of any Epos speaker series, the M12i is the ideal loudspeaker for those
enthusiasts who prefer a stand-mount over a floor-stand option.
As with all speakers in the Mi range, the 12i is designed to meet all the demands of today's two-
channel and home-theatre audio. It is equally at home with music or movies and is fully
magnetically shielded. If the M12i is to be used in a home theatre application, the M8i centre
channel and M5i, used for rears, make ideal choices.
The M12i uses the revised Epos 25mm (1 in.) low distortion metal dome tweeter, designed to have
smooth, clear and extended treble. Featuring a strong die-cast aluminium alloy face plate, moulded
surround, ferrite magnet and Ferrofluid cooling, it is a significant improvement over the earlier M
tweeter. The upper frequency crossover is centred on 5kHz and the minimalistic 1st order
crossover is simply a polypropylene film capacitor.
Epos has designed a robust new 165mm (6.5in.) mid-range woofer with die-cast aluminium alloy
chassis, phase plug and moulded polypropylene cone. Its curved cone profile and graduated
thickness were engineered to 'roll off' high frequencies mechanically, in a smooth fashion. It also
has very high power handling. As such, the woofer requires no electrical crossover to reproduce
dynamic, natural bass and mid-range frequencies in this model. To reproduce bass cleanly and
powerfully, it is loaded at the rear with a port flared at both ends, which reduces turbulence and
distortion.
The bi-wirable input panel is made from solid anodised aluminium alloy, with sturdy high-spec
terminals suited for spade lug or other types of plugs. High-grade metal links join the terminals
together and can be removed for separate connection to each driver.
Equally attractive with or without the silk cloth grilles, the M12i is offered in a choice of three
beautiful real-wood veneers. It seamlessly wraps around the front edges of the pattern matched
cabinets. The front and rear baffles are 25mm (1 in.) thick to reduce unwanted vibration and
colouration.
Configuration 2 way.
Power Handling 75 W max. Speech and Music.
Frequency Range 54 Hz – 20 kHz.
Impedance 8 Ohm nominal.
Sensitivity 87dB/2.83V/1m.
Amplifier Compatibility 50 – 150 Watts.
Positioning Not less than 20 cm (8″) from rear wall.
Finish : Red Cherry, real wood veneer.
Cabinet 18mm MDF wrap and 25mm MDF front baffle with real wood finish.
Size HxWxD 375 x 185 x 250mm / 14.8 x 7.3 x 10″ (without grille).
Packaged One pair per carton.
Weight 8.1 kg / 17.8 lb per single speaker.
21 kg / 44 lb per carton packed.
- Number of posts : 2967
Up
Up
Up
Up
Up
» Epos ES14 Speaker with Epos speaker Stand (sold)
» Epos M5 with Epos ST35 speaker stand
» Epos ES 14 (sold)
» Epos - SOLD
» Epos M16 (SOLD)
» Epos ES 14 (sold)
» Epos - SOLD
» Epos M16 (SOLD)
