SOLD Jeff Rowland Continuum 500 Integrated Amplifier (used)
For Sale
Jeff Rowland Continuum 500 integrated amp
Condition: 9/10 comes with remote and original box
Price: SOLD
Other international sellers going for 20+ 25k+- (https://www.hifishark.com/search?q=jeff+rowland+continuum)
Reason for sale: downgrading to 1 box amp/dac/streamer
Location: For Johor and KL and in between, audition with your own system is possible, i will bring the amplifier. I am half JB KL based.
Contact: Eugene 0127088256
Price: SOLD
Output Power @ 8 ohms Continuous RMS 500 watts, both channels driven
Output Power @ 4 ohms Continuous RMS 1000 watts, both channels driven
Frequency Response 5 Hz – 45 kHz, -3 dB @ 8 ohms
Peak Output Current 40 amps
Dynamic Range 120 dBa
Load Impedance Range 3 ohms – 16 ohms
Input Impedance 48 k ohms
THD & Noise, 0.1 watts to Max Output < 0.1%, Typically .01% @ 1 kHz
Damping Factor @ 1 kHz > 1000
Gain Structure Preamplifier Section 14 dB, Amplifier Section 26 dB
Volume Control Range 99.5 dB
Volume Control Resolution 0.5 dB +/- 0.05 dB Over Entire Range
Common Mode Rejection Ratio > 85 dB, 20 Hz to 20 kHz
Inputs 2 pair Balanced (XLR), 2 pair Unbalanced (RCA) / 1 pair Unbalanced (RCA), Unity Gain (Bypass)
Outputs 1 pair Balanced (XLR), 1 pair Unbalanced (RCA) / 1 pair CE-Approved Speaker Wire Clamp
Power Consumption Idle – 60 watts, Max – 2000 watts
Power Supply Switch Mode (SMPS) with active power factor correction (PFC) and universal AC input voltage
Amplifier Weight 44 lbs / 20 kg
Amplifier Dimensions (H) x (W) x (D) 5.3″ x 15.5” x 15.0” (135mm x 394mm x 380mm)
apocalypzeus- New Member
- Number of posts : 6
Registration date : 2009-07-02
Re: SOLD Jeff Rowland Continuum 500 Integrated Amplifier (used)
Bump! Price reduced
» Jeff Rowland Continuum 500 Integrated Amplifier (Used)(Sold)
» Jeff Rowland Continuum S2 Integrated Amplifier SOLD
» Jeff Rowland Continuum 500 Integrated Amplifier (Used) (SOLD)
» Jeff Rowland Continuum 500 integrated amp (Used) SOLD
» Jeff rowland Continuum 250 (Sold)
