Audioquest SUB-3 Subwoofer Cable (3meter) (Used) SOLD
Audioquest SUB-3 Subwoofer Cable (3meter) (Used) SOLD Empty Audioquest SUB-3 Subwoofer Cable (3meter) (Used) SOLD
Post by choyaudiovisual on Sat May 11, 2019 10:14 am
Audioquest SUB-3 Subwoofer Cable (3meter) (Used) SOLD Img_3512Audioquest SUB-3 Subwoofer Cable (3meter) (Used) SOLD Img_3511Audioquest SUB-3 Subwoofer Cable (3meter) (Used) SOLD Img_3510
[size=18]Sub-3 is Audioquest's Best Subwoofer Cable! [/size]
Designed specifically for use with subwoofers and the low-frequency signals they handle, Audioquest's SUB-3 is a bit different than Audioquest's regular audio interconnects.  SUB-3 uses larger conductors for better low-frequency reproduction, heavy silver-plating for greater snap and slam, PE Air Tubes for greater speed and articulation and is DBS enabled for the ultimate in resolution and dynamics.
Sub-3 uses 21AWG solid-core LGC conductors which offer greater bass definition than stranded designs, very heavy 6.1% silver plating greatly improves speed and slam characteristics, the PE Air Tubes minimize time-domain smearing improving pitch definition and articulation, the DBS packs improve shielding and reduce distortion for greater transparency and dynamic range, SUB-3's three conductor design insures optimum performance, whether single-ended (RCA plugs) or balanced (XLR plugs), 100% coverage shield insures noise-free performance.  Topping it all off, Audioquest's silver-plated RCA plugs are welded to SUB-3 using 8,000 ampere, reducing distortion and improving conductivity.
SUB-3 uses three solid 6.1% Silver conductors inside PE Air Tubes. Solid conductors eliminate strand-interaction distortion. PE Air Tubes minimize information smearing caused by any solid or foam insulation. The 36V electrostatic field on the PE tubes eliminates almost all remaining insulation induced distortion. A 100% coverage shield insures noise-free performance.
Audioquest cables are legendary in audiophile circles for their neutrality and resolution. For 28 years, Audioquest has worked tirelessly to achieve sonic neutrality in all their cables, regardless of price. Ensuring that music flows unchanged and uncolored requires removing the myriad distortions that occur when a signal flows through a cable. To accomplish this, Audioquest bypassed conventional cable design and focused their efforts on both the physical properties and sonic characteristics of the conductors and connectors, as well as every other material used in the creation of their cables. This unorthodox approach has led to a number of innovations, the most celebrated of which is the Dielectric Bias System (DBS), a revolutionary and patented system of simultaneously protecting the conductors from outside interference and reducing distortion within the cable.
Conditions: 8/10 (USED)
Whatsapp: Choy 012-5685484
Number of posts : 670
