Exposure 3010 S2 Integrated Amplifier - Made In England
Exposure 3010 S2 Integrated Amplifier - Made In England Empty Exposure 3010 S2 Integrated Amplifier - Made In England
Post by raymond88 Thu May 23, 2019 4:09 pm
Item: Exposure 3010 S2 Integrated Amplifier - Made In England
Condition: 8.5/10. Item is in excellent condition. No dents or scratches. Comes complete with original box, manual, remote control and power cord.
Price: sold
Exposure 3010 S2 Integrated Amplifier - Made In England Exposurehgggifilogo%20copy
Exposure 3010S2 D Integrated Amplifier
Exposure has just announced the fourth generation of their flagship integrated amplifier – the new 3010S2-D.  The new 3010S2-D carries over with six line level inputs; however, one of these is now a direct AV input (home-theatre pass through).  This latest model now offers the option to fit a MM or MC phonostage, or an integrated DAC (192/24 bit PCM and DSD 64 via two inputs: USB and BNC).  A preamp output is provided for the option to add a separate power amplifier. Speaker terminals are doubled to allow bi-wiring.
The Exposure 3010S2-D has been built using high-quality capacitors within the signal path and circuit topology that has been laid out to keep supply paths short; with cascade circuitry for improved power supply immunity.  A brand new circuit board with all discrete components is now used and the power amp features a fast bipolar transistor output stage.  A new power supply adds extra stages of regulation for improved performance.
Exposure 3010 S2 Integrated Amplifier - Made In England Th41421323824Exposure3010s2Amplifier
Technical specifications
Power output (stereo) 110 Watts per channel at 1KHz into 8 Ohms
Input impedance 17K Ohms minimum (line input)
Input sensitivity 250mV
Pre-amplifier output 1V for rated input (gain + 18dB full volume)
Frequency response 20Hz – 20KHz ± 0.5dB
Total harmonic distortion <0.03% at rated output, ref. 1KHz
Signal to noise ratio >100dB, ref. rated output
Channel separation >60dB, 20Hz – 20KHz
Mains supply 110/120V or 220/240V, 50/60Hz (factory set)
Power consumption <400VA, 8 Ohms load, both channels driven
Dimensions 115mm (h) x 440mm (w) x 300mm (d)
Net weight (unpacked) 12kg
Gross weight (packed) 14kg
Exposure 3010 S2 Integrated Amplifier - Made In England Exposu13
Exposure 3010 S2 Integrated Amplifier - Made In England Exposu10
Exposure 3010 S2 Integrated Amplifier - Made In England Exposu11
Exposure 3010 S2 Integrated Amplifier - Made In England Exposu12
https://www.analogueseduction.net/integrated-amplifiers/exposure-3010s2-d-integrated-amplifier.html
http://www.theabsolutesound.com/articles/exposure-3010s2d-integrated-amplifier/
https://www.exposurehifi.com/products/item/3010s2d-integrated-amplifier.html
Number of posts : 10022
Exposure 3010 S2 Integrated Amplifier - Made In England Empty Re: Exposure 3010 S2 Integrated Amplifier - Made In England
Post by raymond88 Thu May 30, 2019 2:53 pm
