Dali Rubicon 8 - Dali Flagship Rubicon Speakers
Dali Rubicon 8 - Dali Flagship Rubicon Speakers Empty Dali Rubicon 8 - Dali Flagship Rubicon Speakers
Post by raymond88 on Sun Jun 09, 2019 6:45 pm
Item: Dali Rubicon 8 - Dali Flagship Rubicon Speakers
Condition: 9/10. Item is in excellent condition. Comes with the original boxes and packaging/accessories. 1+ year old. This is the more expensive black piano finishing version.
This pair of speakers provies mind blowing large soundstage and an impressive deep, physical bass. Hear it to believe it.
Price: RM16.8k RM14.5k RM13.5k or swap/topup. Bought new for RM31k.
Dali Rubicon 8 - Dali Flagship Rubicon Speakers Dali1110
Dali Rubicon 8 Loudspeakers
DRIVERS
Assembled in-house, every driver in each of the RUBCION models are configured to match the model they are destined for. The three 6½ inch drivers used in RUBICON 8 all work together to reproduce a clean, detailed sound with no colouration. The RUBICON series draws upon the heritage from the SMC based ‘Linear Drive System, which was introduced with the EPICON series. With the use of the technology from the SMC drivers, we have taken a step closer to remove a very large part of the unwanted distortion. The bass drivers are optimized for long excursion, and the midrange driver for a large useful frequency range insuring that the roll-off is handled in the crossover and not in the driver. All this ensures that the benefit from SMC can be enjoyed by even more Hi-Fi lovers around the world.
TWEETERS
In the RUBICON series, DALI makes use of both the soft dome tweeter working alone, and the hybrid tweeter configuration an amazing rendering of the high frequencies. The voice coil used in the RUBICON series is designed to be very light and agile in order to achieve a broader bandwidth. This lighter voice coil is placed inside a powerful ferrite magnet that keeps a tight control of its movements. The ribbon tweeter is the master of wide dispersion and combining it with the soft dome, the tweeter module starts working as low as 2.5 KHz. This extreme bandwidth combined with the ultra wide dispersion is an important part of the DALI sound philosophy.
CABINET
The gracefully elegant exterior of the RUBICON works as the base for the low-loss drivers. In every cabinet, the mid-range and bass drivers are separated into their own chambers. Turbulence is minimized through a bass reflex port, which is placed directly behind every woofer, and the timing between the woofer and the bass port is thereby also optimized.
Speaker TypeFront
Rear
Surround
Frequency Range (+/-3 dB) [Hz]38 - 34.000
Sensitivity (2,83 V/1 m) [dB]90.5
Nominal Impedance [Ω]4
Maximum SPL [dB]112
Recommended Amplifier Power [W]40 - 250
Crossover Frequency [Hz]500/800/2.500/14.000
Crossover Principle2½ + ½ + ½ way
High Frequency Drivers1 x 17 x 45 mm  Ribbon
1 x 29 mm  Soft Textile Dome
Low Frequency Driver3 x 6½"  Wood Fibre Cone
Enclosure TypeBass Reflex
Bass Reflex Tuning Frequency [Hz]33,5
Connection input(s)Bi-Wire
Magnetic ShieldingNo
Recommended PlacementFloor
Recommended Distance From Wall [cm]20 - 180
Dimensions With Base (HxWxD) [mm]1,100 x 220 x 445
Weight [kg]27.3
Accessories IncludedManual
Micro Fibre Cloth
Rubber Bumpers
Spikes M8
FinishBlack High Gloss Lacquer
Rosso Veneer
Walnut Veneer
White High Gloss Lacquer
The floor standing flagship of the RUBICON series, the RUBICON 8, will provide you with a mind blowing large soundstage and an impressive deep, physical bass. Inherited from the EPICON series, the RUBICON series utilizes the same SMC technology and soft dome diaphragm. The RUBICON 8 has no less than three drivers that all kick in at different frequencies. This setup ads up to what in effect is a 2½+½+½-way construction, and generates an amazing range and impressive sound pressure. The RUBICON 8 is for those seeking the extraordinary in size and sound.
Upping the audio ante to the extreme, the RUBICON 8 is quite simply stunning in terms of the epic soundstage it presents. The trio of woofers work by kicking in at different frequencies, making the RUBICON 8 loudspeaker, the pinnacle of your entry into the world of high-end audio at a mid-range price.
Delivering a totally transparent image with a richness of detail that recreates the passion of a live performance, the wider sound dispersion afforded by our hybrid tweeter helps the RUBICON 8 fill even the most sizeable of spaces with the purest audio your ears will ever witness.
Product series RUBICON
Frequency Range (+/-3 dB) [Hz] 38 - 34.000
Sensitivity (2,83 V/1 m) [dB] 90.5
Nominal Impedance [ohms] 4
Maximum SPL [dB] 112
Recommended Amplifier Power [W] 40 - 250
Crossover Frequency [Hz] 500 / 800 / 2.500 / 14.000
Crossover Principle 2½ + ½ + ½ way
Hybrid tweeter module, Super high freq. driver, Quantity 1 x 17 x 45 mm
Hybrid tweeter module, Super high freq. driver, Diaphragm type Ribbon
Hybrid tweeter module, High frequency driver, Quantity 1 x 29 mm
Hybrid tweeter module, High frequency driver Diaphragm type Soft Textile Dome
Low frequency driver, Quantity 3 x 6½"
Low frequency driver, Diaphragm type Wood Fibre Cone
Enclosure type Bass Reflex
Bass Reflex Tuning Frequency [Hz] 33.5
Connection Input Bi-Wiring
Magnetic Shielding No
Recommended Placement Floor
Recommended Distance From Wall [cm] 20 - 180
Dimensions With Base (HxWxD) [mm] 1,100 x 220 x 445
Weight [kg] 27.3
Accessories Included Manual
Micro Fibre Cloth
Rubber Bumpers
Spikes M8
Dali Rubicon 8 - Dali Flagship Rubicon Speakers Dali110
Dali Rubicon 8 - Dali Flagship Rubicon Speakers Dali210
Dali Rubicon 8 - Dali Flagship Rubicon Speakers Dali310
Dali Rubicon 8 - Dali Flagship Rubicon Speakers Dali410
Dali Rubicon 8 - Dali Flagship Rubicon Speakers Dali510
Dali Rubicon 8 - Dali Flagship Rubicon Speakers Dali610
Websites:
https://www.dali-speakers.com/loudspeakers/rubicon/rubicon-8/
https://forums.audioholics.com/forums/threads/dali-rubicon-8-floorstanding-tower-speaker-overview.93943/
https://www.hifix.co.uk/dali-rubicon-8-speakers
https://www.ebay.com/itm/Dali-Rubicon-8-Floor-standing-Loudspeakers-/391975598214
https://www.soundandvision.com/content/dali-rubicon-8-speaker-system-review
https://www.stereophile.com/content/dali-rubicon-8-loudspeaker
Number of posts : 5025
Dali Rubicon 8 - Dali Flagship Rubicon Speakers Empty Re: Dali Rubicon 8 - Dali Flagship Rubicon Speakers
Post by raymond88 on Sun Jun 16, 2019 11:16 am
Post by raymond88 on Sun Jun 23, 2019 2:45 pm
Price reduced
Post by raymond88 on Sun Jun 30, 2019 1:33 am
Post by raymond88 on Mon Jul 08, 2019 12:31 pm
Post by raymond88 on Thu Jul 18, 2019 9:33 pm
