Emotiva XPA-3 Power Amplifier, 200W x2, Class AB
Emotiva XPA-3 Power Amplifier, 200W x2, Class AB Empty Emotiva XPA-3 Power Amplifier, 200W x2, Class AB
Post by actsessory on Tue Jun 11, 2019 6:43 pm
Emotiva XPA-3 Power Amplifier, 200W x2, Class AB Emotiva-xpa-amplifier-image3-lg
– Modular Based Power Amplifier
– Fully Discrete
– Dual Differential (Balanced)
– High Current
– Short signal path Class A/B
– 850VA transformer
– 60,000uF of secondary capacitance
– Six output devices per channel
Translated into plain English, that is a WHOLE LOTTA POWER!
Emotiva XPA-3 Power Amplifier, 200W x2, Class AB Xpa3c
– 200 Watts RMS into 8 Ohms
– Balanced XLR and Single-ended RCA inputs (Gold-Plated), independent switching
– Audiophile grade 5-Way gold-plated binding posts
Emotiva XPA-3 Power Amplifier, 200W x2, Class AB Xpa3a
– Engineered for true audiophile-quality sound for movies and music.
– Refined short signal path Class AB topology for exceptional detail and resolution.
– Heavy duty power supply with oversized toroidal transformer for exceptional power reserves.
– Stealth mode lets you disable status LEDs for discreet operation.
– Soft touch power supply.
– Heavy steel 4RU chassis with milled aluminum face plate.
– Heavy duty Audiophile quality gold plated 5 way binding posts with clear shields.
– Solid machined gold-plated RCA input connectors.
– Remote trigger input and output for easy integration.
– Audiophile-grade fault management for transparent protection against all common fault conditions.
Dimension: H186 x W430 x D480 mm
Weight : 26.0kg
Emotiva XPA-3 Power Amplifier, 200W x2, Class AB Xpa3b
The Emotiva did bring out a subtle but noticeable increase in imaging, and a more coherent soundstage, particularly with multi-channel music recordings.
***Selling as Stereo OR 2-Channel Amp, as center channel is internally set bypassed (not working)
Welcome for audition
RM2200
Subang Jaya ss 14
**Credit Card accepted
Contact 0126116917
https://www.facebook.com/Actsessory/
actsessory
Number of posts : 1480
http://www.actsessory.com
