Audio Research VT100 Tube Stereo Power Amplifier
Audio Research VT100 Tube Stereo Power Amplifier Empty Audio Research VT100 Tube Stereo Power Amplifier
Post by raymond88 on Wed Jun 12, 2019 4:44 pm
Item: Audio Research VT100 Tube Stereo Power Amplifier
Condition: 8/10. Item is in excellent condition. This unit have been fully serviced and retubed with factory spec NEW Electro Harmonix 6550EH and ECC88 at a cost of around RM3k a couple of months ago. Owner selling due to upgrade.
Price: RM7300 RM6900 or swap/topup
Audio Research VT100 Tube Stereo Power Amplifier Audio113
Audio Research VT100 Tube Stereo Power Amplifier Audio213
Audio Research VT100 Tube Stereo Power Amplifier Audio310
Audio Research VT100 Tube Stereo Power Amplifier Audio410
Audio Research VT100 Tube Stereo Power Amplifier Audio511
Audio Research VT100 Tube Stereo Power Amplifier Audio611
Power output    100 watts per channel continuous from 20Hz to 20kHz.
Approximate actual power available at "clipping" 110 watts (1kHz)
Power bandwidth    (-3dB points) 15Hz to 80kHz
Frequency response (-3dB points at 1 watt) 1Hz to 100 kHz
Input sensitivity 1.9V RMS (Bal or SE) for rated output. (23.5 dB gain
into 8 ohms.)
Input impedance    200K ohms Balanced, 100K ohms Single-ended.
Output taps 8 ohms, 4 ohms
Output regulation    Approximately 0.8dB 8 ohm load to open circuit
Overall negative feedback 10 dB
Damping factor    11
Distortion    1kHz total harmonic distortion typically 1% at 100 watts, below
.05% at 1 watt
Slew rate    15 Volts/µs
Rise time    3 µs
Hum & noise    Less than 0.5mV RMS 95dB below rated output (IHF
weighted, input shorted)
Power supply energy storage    VT100: 270 joules.
Power requirements    105-125VAC 60Hz (210-250VAC 50Hz) 585
watts at rated output, 750 watts maximum, 380 watts at "idle"
Tube complement    VT100: (4 matched pairs) 6550 power output, (Audio Research VT100 Tube Stereo Power Amplifier Icon_cool
6922
Dimensions    19" (48.3 cm) W x 8.75" (22.2 cm) H x 19.5" (49.5 cm)
Weight    65 lbs. (29.5 kg)
http://www.arcdb.ws/VT100/VT100.html
https://www.youtube.com/watch?v=29kCOctD_-g
https://www.youtube.com/watch?v=Q0SnBWkMLZY
https://www.youtube.com/watch?v=bOBBI6eDP1s
Number of posts : 4770
Audio Research VT100 Tube Stereo Power Amplifier Empty Re: Audio Research VT100 Tube Stereo Power Amplifier
Post by raymond88 Yesterday at 11:00 pm
