Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Empty Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model
Post by raymond88 on Mon Jun 24, 2019 5:55 pm
Item: Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model
With Onboard DAC, Bluetooth, DSD capable PC-USB, USB iPod input, phono stage input (MM), dual subwoofer outputs, 200W @ 8 ohms.
Condition: 9/10. Item is in MINT condition. Comes in original box and packaging, manual, remote control, power cord and all accessories. The unit was purchased in May last year and was used as a preamp and DAC only.
Bought new for RM9200
Price: RM6500 RM5900 RM5200 or swap/topup
INTEGRATED AMPLIFIER
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Ra-1592_black-web
The RA-1592 Integrated Amplifier leverages the strengths of our award winning RC-1590 preamplifier and RB-1582 MkII power amplifier in a sleek single chassis design.
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Rotel-feature%20icons_ab-power2 x 200 Watts of
robust power
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Rotel-feature%20icons_class-a-b-audioClass AB amplifier
design
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Rotel-feature-icons_bluetoothBluetooth with aptX
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Rotel-feature%20icons_d-a-converter_0AKM premium 32-bit/768kHz
Digital to Analog Converter
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Rotel-feature%20icons_balanced-xlr_0Balanced XLR inputs
[size=40]Engineered with care.
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Ra1592_guts
DIMENSIONS (W × H × D)
431 × 144 × 425mm
17" × 5.7" × 16"
FRONT PANEL HEIGHT
3U / 132.6mm (5.25")
POWER REQUIREMENTS
120V, 60Hz
POWER CONSUMPTION
500W
STANDBY POWER CONSUMPTION
<0.5W
NET WEIGHT
16.8kg (37lbs.)
BTU RATING
1239 BTU/h
CONTINUOUS POWER OUTPUT
200W/Ch (All channels driven, 8Ω)
TOTAL HARMONIC DISTORTION (THD)
(20Hz–20kHz) <0.03%
FREQUENCY RESPONSE
Line Level Inputs: 10Hz - 100kHz ±0.5dB
Digital Inputs: 10Hz - 90kHz ±2dB
Phono Input: 20Hz - 20kHz ±0.5dB
S/N RATIO (IHF "A" Weighted)
Line Level Inputs: 103dB
Digital Inputs: 102dB
Phono Input: 80dB
here has never been a better time to be a music lover. Today’s source options provide limitless audiophile quality music. CD-or-better quality streaming, high resolution download sites, inexpensive mass storage devices, the still resilient CD and the resurgence of classic vinyl are all providing a wealth of content at impressively high fidelity. To hear all this music as the artist intended requires an extraordinarily flexible, sonically capable component.
The RA-1592 Integrated Amplifier is exactly that component. It leverages the strengths of our award winning RC-1590 preamplifier and RB-1582 MkII power amplifier in a sleek single chassis design. With a powerful 200 watt per channel Class AB amplifier using performance audio grade components, the RA-1592 can effortlessly drive large speaker systems. The impressive Rotel manufactured toroidal transformer is a key element in the power supply design which also includes custom slit-foil storage capacitors and a dual-monoblock topology. All of this helps to ensure the amplifier performance stands up to even the most complex music and real world playback conditions.
To complement the amplifier section, the RA-1592’s preamplifier incorporates the superb 32-bit/768kHz AKM digital-to-analog converter (DAC) and analog stages of the highest quality. The DAC and surrounding circuitry supports a vast array of source inputs including DSD capable PC-USB (24-bit/192kHz), 3 coaxial, 3 optical, integrated aptX:registered: Bluetooth and front mounted USB iPod input. In recognition of the faithful analog music lovers, there is a phono stage input (MM), XLR balanced input and 3 analog RCA source inputs.
User selectable A-B speaker outputs with 5-way binding posts, RCA pre-output and dual subwoofer outputs provide the ultimate flexibility in installation. The amplifier protection circuits monitor DC offset, overcurrent, short circuit and temperature to protect both the electronics and attached speakers.
Custom integration features include RS232 and Ethernet IP control, 2 trigger outputs, remote IR input and automated digital signal sense power control for easy integration with streaming sources and control systems.
The RA-1592 is the finest integrated amplifier yet in Rotel’s 55 year history of producing performance audio components.
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Rotel112
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Rotel212
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Rotel311
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Rotel410
http://www.rotel.com/product/ra-1592
https://www.cnet.com/news/rotel-ra-1592-stereo-amplifier/
https://hometheaterhifi.com/reviews/amplifier/integrated-amplifiers/rotel-ra-1592-integrated-amplifier-review/
https://www.hifigear.co.uk/rotel-ra1592.html
https://www.paragonsns.com/product/rotel-ra-1592-integrated-amplifier/
https://www.audioadvice.com/ra-1592.html
https://www.theabsolutesound.com/articles/rotel-ra-1592-integrated-amplifier/
https://www.audiot.co.uk/products/rotel-ra1592-amplifier-12091.aspx
https://www.youtube.com/watch?v=UxKjDDk_xSU
[/size]
Number of posts : 4873
Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model Empty Re: Rotel RA-1592 Integrated Stereo Amplifier - Current Flagship Model
Post by raymond88 on Tue Jul 02, 2019 1:56 am
Post by raymond88 on Mon Jul 08, 2019 12:28 pm
Post by raymond88 Yesterday at 2:35 pm
