KEF R500 Walnut ~price reduced
5 posters
I have a used KEF R500 floorstanding for sale. Very rare in M'sia, I bought this back personally from the states. Comes with feet spikes. One of the feet hole is damaged but I believe can be repaired with some effort, plls see the picture. Woofer and driver is in perfect condition. Cabinet has the usual scratch here and there.
SOLD.
Uni-Q Driver Array
Developed by KEF in 1988, the Uni-Q driver array acts as a single point source, providing pristine sound across a wider area. The R Series benefits from a new incarnation of this driver array, with advantages over its predecessors that include a new midrange motor system that drastically reduces distortion.
Air moving across the minute gaps between Uni-Q’s separate elements creates tiny resonances, but KEF engineers have reduced the impact of these necessary gaps by opening a cavity behind the drivers and adding resonance-absorbing damping material for more precise, purer treble.
Shadow Flare
Derived from the Reference Series, the Shadow Flare reduces harmful cabinet diffraction and allows the Uni-Q to work at its highest level.
More than just a trim ring, Shadow flare is a precision-designed surface that extends the waveguide effect of Uni-Q. The tweeter no longer has line of sight of the cabinet edges, creating a ‘shadow region’ at the points where the potential for diffraction is highest, minimising the acoustic impact to negligible levels.
The result is improved clarity, particularly when it comes to the subtle nuances of plucked strings and percussive sounds.
Low Frequency Drivers
The R Series’ dedicated low-frequency drivers have a two-part structure, where a shallow concave aluminium skin sits atop a paper cone. This adds stiffness, while the cone’s unique geometry reduces resonances and delivers the pistonic movement that makes these drivers time so well.
The new drivers also have a completely redesigned magnet system that creates a more even magnetic field, and a design of spider that reduces harmonic distortion for a cleaner, more precise sound.
Cabinet Bracing
The R Series benefits from Constrained Layer Damping bracing originally developed for the multiple award-winning LS50, and a new internal bracing layout. This combination brings the R Series closer to the internal structure of the Reference Series, and helps it deliver music as it is supposed to sound, without any unwanted extras.
Flexible Port Technology
KEF engineers computer-modeled the ideal crossover networks before exhaustively auditioning every high grade component, individually and together, to select those with the lowest distortion and the smoothest response. Perfectionism takes time, but the difference is plain to hear. Nothing is overlooked - Reference crossovers are even mounted on separate boards and decoupled from the cabinet walls to minimize vibration and crosstalk.
SOLD.
Uni-Q Driver Array
Shadow Flare
Cabinet Bracing
dexth77- Frequent Contributor
- Number of posts : 115
Registration date : 2011-07-04
Re: KEF R500 Walnut ~price reduced
such of beautiful speaker , heart paint when see last photo
khlim_77- Frequent Contributor
- Number of posts : 262
Registration date : 2010-03-09
Yo lor ..damaged goods..
mofaz- Frequent Contributor
- Number of posts : 497
Registration date : 2009-02-11
So say all these second hand dealers above hoping to score a good one - it is not hard to fix this
- Number of posts : 137
Amplification: Nuprime STA-9
Speakers: B&W 706 /AVI DM 10
Very kind words, tqsamazzah wrote:So say all these second hand dealers above hoping to score a good one - it is not hard to fix this
To clarify, The speaker is 100% working condition, with cosmetic defect. I don't find the sound change in any way with or without the spike feet. It still stand proper without feet installation. Tq.
You may only bump once every seven days please. With 89 posts, you must read the rules and adhere by all of them.
Thank you.
Bal (moderator)
Thank you.
Bal (moderator)
bal- Moderator
- Number of posts : 1275
Speakers: maggie 1.7
» Zu Audio Druid V floorstand speaker (used)
» PMC-DB1+ speaker
» Mitsubishi -VLT-HC3800 FULL HD DLP projector
» Linn Akito
» (Final reduction) Harmonix X-DC Studio Master power cord, 1.5m, preowned
» PMC-DB1+ speaker
» Linn Akito
