AC Power Supply Optimization Service
AC Power Supply Optimization Service Empty AC Power Supply Optimization Service
Post by AndrewLK on Wed Jul 10, 2019 10:29 pm
HiFi system runs on AC power. It is imperative we optimize AC power supply as perfectly as possible to realize it’s full potential.
An electrical engineer by profession but HiFi is my passion. With proven experience in optimizing AC power for HiFi systems, I wish to share my knowledge for DIY enthusiasts and also offer my power supply optimization services, for a small fee, for those who requires it. My solution is suitable for mid to high-end HiFi system. I work on single phase AC supply only.
My implementation minimizes the number of contact point, fuse and ELCB while enhances contact integrity, reduces cable resistance and lowering noise, resulting in an optimized foundation for building your system.
Once optimized, you can then connect it to power distributor / power regenerator / noise filter ... etc follow by rest of the HiFi components. My design follow closely the activities stated in the PSAudio article (https://www.psaudio.com/ps_how/how-to-install-a-dedicated-ac-line/) which was installed in Stereophile Listening Room in 1991. The transformation in performance I experienced was very similar to what the PSAudio article described. Without it, I did not enjoy listening to my system at all.
I operate from a café name MyEspresso (address :  63 Jalan USJ 21/11, Subang Jaya) every Saturday from 1pm till 7pm. Feel free to come for a sharing session. I will go through the PSAudio article and explain the technical compromises found in many components that cause harsh and uninvolving sound. I like to meet you, talk HiFi, share and learn. Absolutely no obligation
If you wish to meet some other time, please WhatsApp's me at 012-6608497 (Andrew Teow) to schedule.
Meeting at your home is also possible for a fee of $50 where I can review your AC power supply and grounding, and recommend solution if needed. Full explanation will be given for each recommendation. Will also bring along some HiFi accessories and cables for trying (not for sales).
My offerings are as follows :
1) AC wire Hook up per Configuration A
 AC Power Supply Optimization Service Config10
Cost : RM 600 (exclude power plugs). Variation can be discussed, depending on your system's requirements.
2) Dedicated power line from circuit breaker box
AC Power Supply Optimization Service Dedica10
Cost : Estimate RM 500 to RM 1200  --- (length and configuration dependent)
           Note :
           * exclude paint / painting cost.
           * additional $ 180 for circuit breaker box with 20 amp breaker if order together.
3) Dedicated grounding For HiFi system
AC Power Supply Optimization Service Ground13
Cost : RM 250
Expected buyback : lower noise, more details, darker background.
4) AC selector switch bypass
AC Power Supply Optimization Service Ac_sel12
Cost : RM 180
5) Change 3 pin socket to receptacle outlet
AC Power Supply Optimization Service Socket13
Cost : RM 280
6) Fuse bypass
AC Power Supply Optimization Service Fuse_b12
Cost : RM 25 per piece
7) Modify Keces DC116 power supply
AC Power Supply Optimization Service Wechat10
Cost :
RM 600 for Level 1 (big improvement)
  • Star grounding for 6 components
  • Replace Reference cap, output caps with 8 Rubicon ZL capacitors
  • Bypass AC voltage selector
  • Bypass on/off switch (if owner agree)
  • Hard-wire all connectors (if owner agree)
  • Fine tuning results at your home (1 time)
RM 1000 for Level 2 (ultimate)
  • All Level 1 upgrade plus add 1000uF, 16V Oscon capacitor at output.
  • Star ground more components.
  • Use 4 more Rubicon ZL caps.
  • DC voltage selector switch bypass (if owner agree)
  • Fine tuning results at your home (2 times)
I did Level 2 for my system. Complete transformation from so so to exceptional sound quality.
Thanks for reading.  WhatsApps me at 012-6608497 for more info.
Come to MyEspresso (address : 63 Jalan USJ 21/11, Subang Jaya) every Saturday from 1pm till 7pm for discussion.  Very Happy
Note : Take photo of your AC outlet and connection before coming.
AndrewLK
Number of posts : 3
Registration date : 2009-03-07
Source(s): Modified Auralic Aries
Amplification: Devialet 200
Speakers: Sonus Faber Olympica 3
