Onkyo TX-SR393 5.2Ch Atmos AV Receiver
Onkyo TX-SR393 5.2Ch Atmos AV Receiver Empty Onkyo TX-SR393 5.2Ch Atmos AV Receiver
Post by stylelaser.com.my on Sun Jul 14, 2019 4:27 pm
Onkyo TX-SR393 5.2Ch Atmos AV Receiver Brand New. Now Selling At RM2,399. Free Shipping Within West Malaysia.
TX-SR393
5.2-Channel A/V Receiver
     Onkyo TX-SR393 5.2Ch Atmos AV Receiver Es_277     Onkyo TX-SR393 5.2Ch Atmos AV Receiver Es_475
Class-beating sound shaped to your lifestyle
Premiere Dolby Atmos:registered: and DTS:X:registered: sound at home with the TX-SR393. Choose a speaker layout to suit your room, from a space-saving 2.1-ch setup enhanced with 3D surround-sound courtesy Dolby Atmos Height Virtualizer* or DTS Virtual:X:registered: to a 3.2.2-ch system for native object-audio playback. Whatever way you play it, dynamic power is ready to thrill thanks to authentic high-current analog amps backed by a thumping custom transformer. For true-to-life video, the AVR supports 4K/60p and HDR video passthrough. If all this tech sounds scary, relax: every aspect of this product is designed to erase frustration, from the automated AccuEQ system calibration to quick connection guide. The receiver integrates your players and TV and adds practical features such as Vocal Enhancer for clear dialog. There’s even a Zone B line-out to distribute all your home cinema sources to a component with an analog RCA line in, such as a wireless headphone dock or hi-fi system. Or just sit back and stream from apps via Bluetooth:registered: technology and let Advanced Music Optimizer:tm: enrich every note of the golden Onkyo sound.
5.2聲道A / V接收器
使用TX-SR393在家中首播DolbyAtmos:registered:和DTS:X:registered:聲音。選擇適合您房間的揚聲器佈局,從節省空間的2.1聲道設置增強了3D環繞聲提供的Dolby Atmos Height Virtualizer *或DTS Virtual:X:tm:到3.2.2-ch系統,用於本機對象音頻播放。對於逼真的視頻,AVR支持4K / 60p和HDR視頻直通。從自動AccuEQ系統校準到快速連接指南。接收器集成了您的播放器和電視,甚至還有一個B區輸出可以將所有家庭影院信號源分配到帶有模擬RCA線路的組件,例如無線耳機底座​​或高保真係統。或者只是坐下來從應用程序流式傳輸藍牙 :registered:技術讓Advanced Music Optimizer:tm:豐富了金色Onkyo聲音的每一個音符。
Dolby Atmos:registered: and DTS:X:registered: sound is here
The TX-SR393 supercharges your Dolby Atmos:registered: and DTS:X:registered: experience. Object-based audio is mixed in 3D space and lets any sound play through any speaker, tracking the action, localizing effects, and moving around you. Dolby Surround:registered: and DTS Neural:X:registered: complement native 3D audio playback. These technologies find localization cues in legacy stereo or multichannel soundtracks and upmix these elements to create immersive top-to-bottom dimensionality.
杜比全景聲(DolbyAtmos:registered:)和DTS:X:registered:
TX-SR393可增強您的杜比全景聲(DolbyAtmos:registered:)和DTS:X:registered:體驗。基於對象的音頻在3D空間中混合,讓任何聲音通過任何揚聲器播放,跟踪動作,本地化效果以及在您周圍移動。DolbySurround:registered:和DTS:registered:Neurical:X補充原生3D音頻播放。這些技術在傳統立體聲或多聲道音軌中找到了本地化線索,並將這些元素上混,以創建身臨其境的從上到下的維度。
Onkyo TX-SR393 5.2Ch Atmos AV Receiver Img_393-1
Ready for 4K HDR entertainment
Enjoy comprehensive support for 4K/60p and HDR (High Dynamic Range) video formats including HDR10, HLG, Dolby Vision:registered:, and BT.2020. The 4:4:4 color-space is also supported. All four HDMI:registered: inputs and ARC-ready output pass video from player to your compatible TV, unlocking everything the latest films and games have to offer. You can easily confirm A/V input-output status via a new OSD window.
準備好4K HDR娛樂
全面支持4K / 60p和HDR(高動態範圍)視頻格式,包括HDR10,HLG,DolbyVision:registered:和BT.2020。還支持4:4:4色彩空間。所有四個HDMI:registered:輸入和ARC就緒輸出都將視頻從播放器傳輸到兼容電視,解鎖了最新電影和遊戲所提供的一切。您可以通過新的OSD窗口輕鬆確認A / V輸入輸出狀態。
Onkyo TX-SR393 5.2Ch Atmos AV Receiver Img_393-2
More power, more realism, more magic
It’s tempting to see watts as the most important figure on an amp’s spec sheet. However, watts are an indication of loudness, not sound quality. Amperes—electrical current—tell the real story. The more current an amplifier develops, the better it controls the speakers. Better control equals fast transient response, wide dynamic range, and clear, accurate sound. The high-output transformer, large capacitors, and discrete amps inside the TX-SR393 produce the most current in its class. And that’s one  big reason why it sounds as good  as it does.
更強大,更現實,更神奇
很有可能將瓦特視為放大器規格表上最重要的數字。但是,瓦特表示響度,而不是聲音質量。安培 - 電流 - 講述真實故事。放大器產生的電流越大,控制揚聲器的效果就越好。更好的控制等於快速瞬態響應,寬動態範圍和清晰,準確的聲音。TX-SR393內部的高輸出變壓器,大電容和分立放大器產生同類產品中的最大電流。這就是它聽起來和它一樣好的一個重要原因。
Onkyo TX-SR393 5.2Ch Atmos AV Receiver Img_393-4
Smooth and easy Bluetooth:registered: streaming
Whatever audio is playing on your phone, tablet, or PC app can be streamed to the TX-SR393 with Bluetooth wireless technology. Once the receiver has paired with and remembered your device, it will start playback automatically whenever it detects an incoming Bluetooth audio stream.
流暢輕鬆的藍牙 :registered:流媒體
無論您的手機,平板電腦或PC應用程序上播放的音頻是什麼,都可以通過藍牙無線技術流式傳輸到TX-SR393 。一旦接收器與您的設備配對並記住,它將在檢測到傳入的藍牙音頻流時自動開始播放。
Decompress with Advanced Music Optimizer:tm:
When an audio file is squeezed into a small container (such as MP3), high-frequency data is lost. This can affect sound quality. Onkyo’s Advanced Music Optimizer DSP listening mode reconstructs the missing bit data. Playback quality is greatly improved, while you enjoy the same convenient file sizes. This mode also optimizes Bluetooth streaming playback quality.
用於流式加密狗的USB電源
如果您沒有足夠的功率點,後面板上的USB端口可以為插入相鄰HDMI輸入的任何媒體流棒提供動力。
USB power for streaming dongles
A USB port on the rear panel powers any media streaming stick plugged into an adjacent HDMI input—great if you don’t have enough power-points.
使用Advanced Music Optimizer:tm:解壓縮
當音頻文件被擠壓到小容器(例如MP3)中時,高頻數據會丟失。這會影響音質。Onkyo的高級音樂優化器DSP監聽模式可重建丟失的位數據。播放質量大大提高,同時您享受相同的方便文件大小。此模式還可優化藍牙流式播放質量。
Onkyo TX-SR393 5.2Ch Atmos AV Receiver Img_393-6
AccuEQ Room Acoustic Calibration  with AccuReflex:tm:
AccuEQ creates a harmonious soundfield in your room. It detects speaker presence, size, and distance from a measurement position, and sets sound-pressure levels. It then selects the ideal subwoofer crossover and applies equalization to all speakers. AccuReflex optimizes object-based audio reproduction through Dolby Atmos-enabled speakers. It resolves phase-shift arising from path differences between directional and non-directional sounds. Enjoy improved localization and a 3D field with vertical movement and overhead dimensionality.
使用AccuReflex:tm:進行AccuEQ室內聲學校準
AccuEQ在您的房間內創造一個和諧的聲場。它可以檢測揚聲器的存在,大小和距測量位置的距離,並設置聲壓級別。然後選擇理想的超低音揚聲器分頻器並對所有揚聲器應用均衡。AccuReflex通過支持杜比全景聲(Dolby Atmos)的揚聲器優化基於對象的音頻再現。它解決了由定向和非定向聲音之間的路徑差異引起的相移。享受改進的本地化和具有垂直移動和頭頂維度的3D場。
Hear dialog clearly at the touch of a button
Finally, a fast and effective solution to inaudible dialog in TV programs and movies. The TX-SR393 features DSP-controlled Vocal Enhancer that identifies vocal frequencies and allows you to raise or lower them to taste using keys on the remote or via the tone controls on the receiver’s front panel.
只需按一下按鈕,即可清晰地聽到對話框
快速有效地解決了電視節目和電影中的聽不見對話問題。TX-SR393具有DSP控制的Vocal Enhancer,可識別人聲頻率,並允許您使用遙控器上的按鍵或通過接收器前面板上的音調控制來升高或降低它們的味道。
Onkyo TX-SR393 5.2Ch Atmos AV Receiver Img_393-7
Share the atmosphere or relax in privacy
A fantastic addition to the TX-SR393 is a Zone B line-out. It connects a component with an analog RCA line input to audio sources available to the receiver, including HDMI and digital audio. Share sound to a hi-fi in a nearby space, or connect a supported charging transmitter dock for wireless headphones and enjoy your entertainment without disturbing anybody.
分享氛圍或在隱私中放鬆身心
TX-SR393的一個出色的補充是B區輸出。它將具有模擬RCA線路輸入的組件連接到接收器可用的音頻源,包括HDMI和數字音頻。將聲音分享到附近空間的高保真音響,或者將支持的充電發射器底座連接到無線耳機,享受娛樂,而不會打擾任何人。
Onkyo TX-SR393 5.2Ch Atmos AV Receiver Img_393-8
Simple steps to sweet sound
The TX-SR393 simplifies your room’s entertainment setup. Components plug into labelled ports while your TV connects via one easy-to-conceal HDMI cable. Hook up your speakers as shown by a friendly diagram next to the numbered speaker terminals. Setup takes moments, enjoyment is limitless.
甜美聲音的簡單步驟
TX-SR393簡化了您房間的娛樂設置。當您的電視通過一根易於隱藏的HDMI線連接時,組件插入帶標籤的端口。如編號揚聲器端子旁邊的友好圖表所示,將揚聲器連接起來。設置需要時刻,享受是無限的。
Onkyo TX-SR393 5.2Ch Atmos AV Receiver Img_393-9
Peter  012-2536225
Fong   016-3098668
Onkyo TX-SR393 5.2Ch Atmos AV Receiver Trade
     Onkyo TX-SR393 5.2Ch Atmos AV Receiver Es_166     Onkyo TX-SR393 5.2Ch Atmos AV Receiver Es_380SPECIFICATIONS:
  • Power output (Front L/R / Center / Surround L/R): 155 W/Ch (6 ohms, 1 kHz, 10% THD, 1 channel driven), 80 W/Ch (8 ohms, 20 Hz–20 kHz, 0.08% THD, 2 channels driven, FTC)
  • THD+N: 0.08% (20 Hz–20 kHz, Half Power)
  • Input sensitivity and impedance” 200 mV rms/47 k-ohms (Line)
  • Frequency response: 10 Hz–100 kHz/+1 dB, -3 dB (Direct Mode)
  • Tone control: ±10 dB, 20 Hz (Bass) ±10 dB, 20 kHz (Treble)
  • Signal-to-noise ratio: 109 dB (Line, IHF-A)
  • TUNER
  • Tuning frequency range: FM 87.5 MHz–107.9 MHz, AM 530 kHz–1,710 kHz
  • FM/AM preset memory: 40 Stations
  • GENERAL
  • Power supply: AC 220–240 V~, 50/60 Hz
  • Power consumption: 445 W
  • Standby power consumption: 0.1 W
  • Dimensions (W x H x D): 17.13 x 6.31 x 12.94
  • Weight: 18.1 lbs
  • Supplied Accessories:• Indoor FM antenna • AM loop antenna • Quick Start Guide • Setup Mic for AccuEQ • Remote controller • AAA (R03) batteries x 2
  • MPN: TX-SR393
          Onkyo TX-SR393 5.2Ch Atmos AV Receiver Es_552
Number of posts : 588
