Parasound Halo A52+ Five-Channel Power Amplifier
Parasound Halo A52+ Five-Channel Power Amplifier Empty Parasound Halo A52+ Five-Channel Power Amplifier
Post by actsessory on Sun Jul 14, 2019 3:14 pm
*180 watts RMS x 5, 8 Ohms
*225 watts RMS x2, 8 Ohms
*Circuitry designed by legendary John Curl
*High bias Class A/AB operation
*Balanced inputs of discrete circuits and XLR connectors
*Direct Coupled for cleanest signal
*MOSFET driver stage and JFET input stage, hand-matched
Parasound Halo A52+ Five-Channel Power Amplifier A52a
  • Circuitry designed by legendary John Curl
  • High bias Class A/AB operation
  • Balanced inputs with discrete circuits and XLR connectors
  • Direct Coupled – no capacitors or inductors in signal path
  • Hand-matched MOSFET driver stage and JFET input stage
  • Full power is rated all the way down to 5Hz for unrestricted low-end bass
  • Beta-matched 15 amp, 60 MHz bipolar output transistors
  • 1.5 kVA encapsulated toroid power transformer with independent secondary windings for each channel
  • 100,000 μF power supply filter capacitance
  • DC Servo and relay protection circuits
  • Heavy-duty 24k gold-plated 5-way speaker terminals
  • 3u Chassis, rack mountable
Parasound Halo A52+ Five-Channel Power Amplifier A52c
Continuous power output:
180 watts RMS x 5, 20 Hz – 20 kHz, 8 Ω, all channels driven
225 watts RMS x 2, 20 Hz – 20 kHz, 8 Ω, all channels driven
225 watts RMS x 5, 20 Hz – 20 kHz, 4 Ω, all channels driven
350 watts RMS x 2, 20 Hz – 20 kHz, 4 Ω, all channels driven
Current capacity:
45 amperes peak per channel
Power bandwidth:
5 Hz – 100 kHz, +0/-3 dB
Total harmonic distortion:
< 0.05 % at full power
IM distortion: balanced 16 V rms
< 0.04 %
Slew rate:
> 130 V/µsecond
Dynamic headroom:
> 1.5 dB
Interchannel crosstalk:
> 78 dB at 1 kHz;
> 63 dB at 20 kHz
Input sensitivity:
1 V for 28.28 V
Input impedance:
47 k Ω unbalanced; 94 k Ω balanced
S/N ratio:
112 dB, input shorted, IHF A-weighted
Damping factor:
> 1100 at 20 Hz
Dimensions:
17-1/4″ w x 5-1/4″ h x 20″ d, 5-7/8″ h without feet
Net weight: 55 lb. (25.0kg)
Parasound Halo A52+ Five-Channel Power Amplifier A52b
Multi-awarded & reviews:
HiFi Review (HK) December 2018
Enjoy the Music July 2018
Stereophile May 2018
Sound and Vision April 2018
and more…
Price:  RM15,000
2 Years local warranty.
Chong 0126116917 @ Subang Jaya SS14
actsessory
Number of posts : 1530
http://www.actsessory.com
Parasound Halo A52+ Five-Channel Power Amplifier Empty Re: Parasound Halo A52+ Five-Channel Power Amplifier
Post by actsessory on Mon Aug 19, 2019 9:51 am
Ready stock
actsessory
