Musical Fidelity 750K Supercharger Monoblock Power Amplifier
Musical Fidelity 750K Supercharger Monoblock Power Amplifier  Empty Musical Fidelity 750K Supercharger Monoblock Power Amplifier
Post by raymond88 on Thu Jul 18, 2019 11:26 pm
Item: Musical Fidelity 750K Supercharger Monoblock Power Amplifier
Condition: 8.5/10. Item is in excellent condition. Comes with original boxes.
Price: sold
Musical Fidelity 750K Supercharger Monoblock Power Amplifier  S811
Musical Fidelity 750K Supercharger Monoblock Power Amplifier  S911
Description:
Solid-state, monoblock power amplifier with balanced and unbalanced line-level inputs and 1 pair speaker-level inputs.
Maximum power output: 750W into 8 ohms (28.75dBW), 1150W into 4 ohms (24.7dBW).
Maximum output voltage: 78V RMS, 20Hz–20kHz; 222V peak–peak.
Maximum current: 250 amps peak–peak.
Frequency response: 20Hz–30kHz, +0/–0.2dB.
THD+noise: <0.01%, 20Hz–20kHz.
Damping factor: 220.
Input impedance: 50k ohms (line), 50 ohms (speaker).
Input sensitivity for full power out into 8 ohms: 2.5V (line), 35V (speaker).
Signal/noise (no reference level quoted): >120dB (line), >115dB (speaker), both figures A-weighted.
The original 550K Power Amplifier created a huge stir and got great reviews. Little wonder since the improvement it made to general sound quality and dynamic range was outstanding.
The 750K Power Amplifier is an even bigger version using exactly the same circuitry as our kW750. And it measures almost identically as well.
The 750K has an extraordinary sound. It is sweet and light with very extended and tight bass. The soundstage is deep and wide. The dynamics are awe inspiring. Because the 750K has such a sweet and almost unassuming, sound it’s all too easy to forget the impact that over 1kW of dynamic power can have. We think the 750K has it all; neutral sweet uncoloured sound with massive headroom.
The load driving ability is virtually limitless. 260 amps peak to peak current with a peak 120 volts capacity. 3kW peak is quite reachable for this huge amplifier.
The 750K offers effortless performance. Driven by a super integrated such as an A1 the results are spectacular.
The 750K Power Amplifier has 3 inputs; line level, fully balanced and loudspeaker level. This gives great flexibility of usage. The 750K uses the same proven music sensing circuit as employed in the 550K Power Amplifier.
The 750K Power Amplifier represents extraordinary value for money. There are few amplifiers, regardless of price, which come anywhere near the performance potential of the 750K.
It achieves its extraordinary performance at such a competitive price by being an extremely efficient design. There is no compromise whatever in the electronics, the components inside are top quality. The efficiency comes in the metalwork/heatsink design. The metalwork is the heatsink. This saves huge amounts of money on unnecessary metalwork and “bling” factor. The 750K Power Amplifier has two fans inside which have temperature controlled continuously variable speed.
Output
Power750 Watts into 8 Ohms (29 dBW)
1150 Watts into 4 Ohms
Voltage, RMS78 Volts 20 Hz to 20 kHz
Voltage, Peak-to-peak222 Volts
Current peak-to-peak260 amps
Damping factor220
Output devices20
Thermal cut out (internal temp)70°C
Line input [ Balanced and RCA ]:
THD + noise, 20 Hz to 20 kHz<0.010%
Signal / noise ratio> 120 dB 'A'-weighted
Input sensitivity for 750 watts2.5V
Input impedance50k Ohms
Frequency response20 Hz to 30 kHz, +0, -0.2 dB
Speaker input
Signal / noise ratio> 115 dB 'A'-weighted
Input sensitivity for 550 Watts35V
Input impedance50 Ohms
Connections
Line level inputs1line level RCA connector
Balanced inputs1 line level XLR DIN socket
Speaker inputs1 pair 4 mm banana plug/binding posts
Speaker outputs2 pair 4 mm banana plug/binding posts
Power requirement100 / 115 / 230Volts AC 50 / 60 Hz (factory pre-set),
1000 Watts maximum into 8 Ohms, 53 watts idle
Weight:
17.2 kg, 37 3/4 lbsunit only, unboxed
19.5 kg, 43 lbsin shipping carton
Dimensions
215 mm, 8 1/2 inches diameter
560 mm, 22inches high including feet
220 mm, 8 3/4 inches deep (front to back) including terminals
Musical Fidelity 750K Supercharger Monoblock Power Amplifier  S114
Musical Fidelity 750K Supercharger Monoblock Power Amplifier  S214
Musical Fidelity 750K Supercharger Monoblock Power Amplifier  S412
Musical Fidelity 750K Supercharger Monoblock Power Amplifier  S512
Musical Fidelity 750K Supercharger Monoblock Power Amplifier  S612
Musical Fidelity 750K Supercharger Monoblock Power Amplifier  S711
Websites:
https://www.stereophile.com/solidpoweramps/1208mf/index.html
https://www.studio-22.com/musical_fidelity/750k.htm
https://www.ebay.co.uk/itm/323853524264
https://hifiwigwam.com/forum/topic/66834-musical-fidelity-750k-super-chargers/
https://www.canuckaudiomart.com/details/649474301-musical-fidelity-750k-supercharger-amplifiers/
https://www.musicalfidelity.com/uploads/manuals/English/750k_manual_english.pdf
Number of posts : 5720
